I have rigged this wheelloader model in blender, the inverse kinematics work fine there. I am then using the alpha blender 4.2 branch to export the armatures to USD however when I do that the armature no longer works. Firstly the inverse kinematics completely dissappears and I dont know how to get that back. Second the body parts no longer move with the bones. I am using the “Bone” parent type in blender to attach parts to bones. Is this behaviour expected? How can I make sure my armatures work in isaac sim? I want to be able to use the replicator to randomize bucket position.
Please provide all relevant details below. This will help the community provide more accurate and timely assistance. You can check the appropriate boxes. Remember, you can always edit this post later to include additional information if needed.
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
Model: RTX 4090
Driver Version:
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
Steps to Reproduce
Create a 4 bar linkage in blender alpha branch 4.2, using armatures. When assigning bones as parents to objects select the “bone” parent type
Export the model as USD with armature option and animation turned on
Open the USD in isaac sim and try to play with the 4 bar linkage
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
