Good morning :-D
I have several questions about Jetson TX2.
1. TX2 supports MIPI DSC(Display Stream Compression)?
As I known, TX1 not supports DSC.
https://devtalk.nvidia.com/default/topic/920663/?comment=4823079
2. TX2 supports Display Color depth 10bit? (RGB 30bit (RGB101010))
I found related contents in datasheet of Jetson TX2 module but it is not clear.
4.4.3 Embedded DisplayPort(eDP) Interface
eDP 1.4
- 1/2/4 lanes, single link
- RBR/HBR/HBR2
- 18/24/36 bit color depth
3. TX2 supports MIPI DSI C-PHY?
I also found related contents in datasheet but to clarify, I ask about it.
4.9 Video Input Interfaces
v1.3, protocol stack; supports both D-PHY v1.2 and C-PHY v1.0; and is paired with the 4th generation NVIDIA video input (VI)
I get the information on datasheet of TX2 Module.
About first question, TX2 supports MIPI DSC(Display Stream Compression)?
Please reply to yes or no.
