Assassin's Creed Mirage is impossible to be played with 565 and the latest dev 550.40.79
Assassin’s Creed Mirage is impossible to be played with 565 and the latest dev 550.40.79. There are heavy artefacts. The game is a total mess and looks like this:
Here is the nvidia-bug-report.log:
nvidia-bug-report.log.gz (858.3 KB)
I’m on Arch with KDE but I think this doesn’t matter for I saw many people with different DE’s and distros which have the same problem.
The same problem on 565 with AC Mirage (vertex explosion). Arch (CachyOS) + Gnome.
It’s most likely broken in 565 but It “should (?)” be fixed in 550.40.79, at least for Assassins Creed Valhalla, however even with 550.50.79 I got vertex explosions after I changed graphics settings, then I restarted the game again and it was fine. I’m back to 560 now because of these issues.
I’m on CachyOS with 565.57.01 open drivers. After hours of tinkering I got this game working on Heroic Games Launcher using Proton - GE-Proton8-3. With an RTX 3090
Does anyone know if this issue has been fixed or if there is a work around. I am running linux and have the 565.77 driver installed, AC Mirage is completely unplayable, i can’t even load into the settings menu and navigae aroun
d.
No known workaround that I know of other than using the 550 Vulkan dev driver, which should work. But then you lose explicit sync and have to run Xorg for good performance.
Proton - GE-Proton8-1, 8-2 or 8-3 Eliminates the texture problems with the latest drivers 565.77.
Ok, weird tho, I suspect that the shipped vkd3d-proton in GE 8 does something different than the newer versions.
Indeed weird. Another Proton I just found that works: Sarek9-20.1
GE-Proton8-4 is indeed the one that starts showing that glitch (with 565)
it can probably be bisected further than that (easy target being obviously dxvk & dxvk-nvapi (edit: forgot that dx-vk isn’t for dx12 so issue is in there Comparing f125062ee1278ac8508ab5561e289ec4ce0f406e...f52e6482bc63d907054025c5eaf8c0d71a7a9f28 · HansKristian-Work/vkd3d-proton · GitHub )
Some nice Nvidia Art there :D I was in and tested as well. Vertex explotion left and right.
Its not that long ago, that I was playing the game, and it was fantastic
