Hi there, I have notice, the tab for NVIDIA Assets is not showing up in USDComposer, even if the extension shows as active. It is showing up and working fine when I build USDExplorer App. I tried to add the extension directly in dependencies and setting.ext directly in the kit file, but didnt work. The extension shows as active, but it just cant be find anywhere.
The NVIDIA Asset browser should show up just fine if you enable the correct Extension. It will not show up automatically, even with the extension loaded. You have to go to “Window > Browsers” and turn it on.
Thanks Richard! I added it directly to my default layout in the code to showing up :).
Great again !!
