Assistance with Gemini 2 3D Camera SDK Installation
I have Gemini 2 3D camera. I am using Jetson Orin Nano. I want to install the SDK for that version of the camera.
jetson@ubuntu:~$ uname -a
Linux ubuntu 5.15.148-tegra #1 SMP PREEMPT Thu Sep 18 15:08:33 PDT 2025 aarch64 aarch64 aarch64 GNU/Linux
Technically Jetson Orin Nano is aarch64. I did not see that architecture among the assets releases in the following link. Releases · orbbec/OrbbecSDK_v2 · GitHub
Has anyone had experience installing and using this camera with the Jetson Orin Nano? Any help and guidance would be greatly appreciated.
Mustafa
Hello @acayci,
I would suggest you try downloading the SDK with the following command:
# Download Orbbec SDK
wget https://github.com/orbbec/OrbbecSDK_v2/releases/download/v2.4.11/OrbbecSDK_v2.4.11_202508040936_058db73_linux_aarch64.zip
# Unzip the SDK
unzip OrbbecSDK_v2.4.11_202508040936_058db73_linux_aarch64.zip
Found it on this SeedStudio wiki. Although you might not be using a SeedStudio board, they are NVIDIA Jetson’s with custom carrier boards, so I am confident that it will work for you.
Please let me know if you encounter any other issues, would love to help.
best regards,
Andrew
@proventusnova Hello Andrew, I was able to complete the installation as shown in the wiki you shared. Thank you so much. Just to confirm …. I connect the camera to USB C port in Jetson Orin Nano. Am I correct?
jetson@ubuntu:~/OrbbecSDK_v2.4.11_202508040936_058db73_linux_aarch64/bin$ ./ob_quick_start
function:ob_create_pipeline
args:
message:No device found
type:2
Press any key to exit.
Mustafa
Hello Mustafa @acayci,
Yes, that is the only interface the camera has.
Is weird that no device is being found.
Can you try checking lsusb to verify the camera shows up on USB hub?
best regards,
Andrew
Hi Andrew,
This is the output from it.
jetson@ubuntu:~$ lsusb
Bus 002 Device 002: ID 0bda:0489 Realtek Semiconductor Corp. 4-Port USB 3.0 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13d3:3549 IMC Networks Bluetooth Radio
Bus 001 Device 007: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 006: ID c0f4:01f5 Usb KeyBoard Usb KeyBoard
Bus 001 Device 005: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 004: ID 10c4:0005 Silicon Labs USB OPTICAL MOUSE
Bus 001 Device 002: ID 0bda:5489 Realtek Semiconductor Corp. 4-Port USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Do you see camera?
Mustafa
Falls alarm! I did not plug it firmly. It works now.
@acayci,
That’s great! Glad everything is working now as expected.
Now what’s next? How else can I help?
best regards,
Andrew
