My Jetson AGX Orin (JetPack 6.2, Ubuntu 22.04) shows abnormal temperature readings in the Jetson Power GUI during low-temperature burn-in testing while operating in MAXN mode.
Are you using AGX Orin industrial module?
Are you talking about that iwlwifi reading in the GUI?
yes,I’m using the AGX Orin Industrial
Only the iwlwifi temperature readings are normal; other sensors show abnormal values.
You pushed the loading to 100% and whole board is under 52W. why do you think the temperature would stay low there…
These sensors are for chip temperature… not for your chamber
The only problem I saw here is iwlifi should not be listed on the list…
Good point! I should’ve thought of that.
I’m using a custom board. It has this Wi-Fi module installed.
Please ignore that wifi module result on the GUI. That one is not part NVIDIA thermal solution so we don’t guarantee that thing is really correct.
