At high temperatures, the Jetson AGX Xavier does boot pigs
At high temperatures, the Jetson AGX Xavier does boot pigs.
I’m having issues with the Jetson AGX Xavier not booting at temperatures above 60″.
NVIDIA Jetson AGX Xavier Developer Kit
When I look at the Carrier Board datasheet, it says [Developer Kit Operating Temperature Range: • 0 ⁰C to 50 ⁰C], I wonder if the bootable temperature is 0~50℃.
This is out of spec as you seen at the datasheet.
