I’ve just downloaded and installed Nsight Visual Studio Edition 4.0. However, when I tried to start Graphics Debugging, a window popped-up said that “Attaching the Graphics debugger to process ‘XXX’ on machine ‘YYY’ failed” (XXX and YYY are my application and machine’s name).
I’m not sure if I didn’t do the setting properly, but I think I did everything as the document written.
Is there anyone know what I should do? I’m using Visual Studio 2012.
I am very new to this, so cannot help much.
These are settings on an Android tablet which is attached via USB to my PC. I think it is the case that the package/program has to be downloaded to a tablet, or phone, and run from there - and that the debugger is expecting that kind of scenario.
This is a visual studio error we are getting sometimes - and the team is trying to better root cause/qualify what may cause this. It seems like running the following command has helped in some cases (but not all the time) - can you please give it a shot and let us know if it helps?
When I start Graphics Debugging, it seems like the debugger tries to open a lot of files. After a while (less than 20 files), it stops, then that window appears.
Anyway, thank you for your answer. I’m looking forward to hearing from you again.
