Graphic debugger can't successfully launch any program.
Once I clicked ‘Start Graphics debugging’, Target application gets minimal launched and just stay freezed. there is no memory increasement and does not consume any cpu time.
It just stays still.
Here is my visual studio info and system info
Visual studio Enterprise 2017 Version 15.3.2
NVIDIA Nsight Visual Studio Edition 5.4.0.17240
Windows 7 enterprise
6.1.7601 SP1
any way to solve this problem would be appreciated.
by the way there is no Window visible.
Hi ly9637,
I’m sorry for the problem you met.
Can you provide more information please?
  • Did the sample run fine without nsight?
  • Did the issue also happen on other platforms? such as WIN10.
  • Did it stay freezed all the time? Did the app crash or exit in the last?
  • Can we have your sample please? then we can identify the issue quickly.
Thanks,
Letitia
Hi letitia
It is the same problem described in the post:
https://devtalk.nvidia.com/default/topic/1025140/nsight-visual-studio-edition/nsight-5-4-on-visual-studio-2017-hangs-when-launching-the-debugger/post/5220274/.
I switch to 5.3, everything works fine.
OP says he solves the problem by changing permission, is it about Nsight or Target application?
Hi ly9637,
I’m afraid that the permission problem is not related with nsight, he said his working environment cause the problem.
Regards,
Letitia
Hi letitia
Understood, appreciated.
