I am trying to reproduce the tutorial of Defect Detection Model: Playlist | SERIES - Replicator 1.10 Workflow Tutorial | NVIDIA On-Demand
It uses the kit-extension-sample-defectsgen found on: GitHub - NVIDIA-Omniverse/kit-extension-sample-defectsgen: Reference Extension to apply defects for synthetic data generation
I follow all the steps but when I recreate the graph and then clic on preview nothing shows up. In the console I observe 4 logs:
2024-06-12 18:52:57 [Warning] [omni.example.defects.utils] No valid prim at path given: /Replicator
2024-06-12 18:52:57 [Warning] [omni.replicator.core.scripts.utils.utils] module ‘omni.replicator.core.scripts.create’ has no attribute ‘projection_material’
2024-06-12 18:52:57 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Cube_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
2024-06-12 18:52:57 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Cube_Xform.xformOp:scale is overridden in a stronger layer (Root Layer).
2024-06-12 18:52:57 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Cube_Xform.xformOp:rotateXYZ is overridden in a stronger layer (Root Layer).
While if I try to run for 1 time to generate an output image I see in the console:
2024-06-12 18:53:13 [Warning] [omni.example.defects.utils] No valid prim at path given: /World/Looks/ProjectPBRMaterial
2024-06-12 18:53:13 [Warning] [omni.example.defects.utils] No valid prim at path given: /World/Body_Panels/Good/Mesh_704/Projection
2024-06-12 18:53:14 [Warning] [omni.replicator.core.scripts.utils.utils] module ‘omni.replicator.core.scripts.create’ has no attribute ‘projection_material’
2024-06-12 18:53:14 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Cube_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
2024-06-12 18:53:14 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Cube_Xform.xformOp:scale is overridden in a stronger layer (Root Layer).
2024-06-12 18:53:14 [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Cube_Xform.xformOp:rotateXYZ is overridden in a stronger layer (Root Layer).
Setup:
- Windows 11
- Ryzen 7 7000X
- RTX 4070 12GB VRAM
- Code version: 2022.3.3
Full console log:
kit_20240612_205043.log (1.1 MB)
If you need anything else please let me know!
