I am encountering some problems when running replicator via python API, it finishes without generating images, unlike in isaac-sim.
System:
- RTX geforce 4070
- python: 3.10.14
- ubuntu 24.04
- docker image: nvcr.io/nvidia/isaac-sim:4.2.0
I have taken the code available here: GitHub - NVIDIA-Omniverse/kit-extension-sample-defectsgen: Reference Extension to apply defects for synthetic data generation and modify to take out all the UI related functions. Once done that I deploy a docker container which can run the core functions which are create_defect_layer and rep.orchestator.run()
def create_defect_layer(defect_params: DefectParameters, object_params: ObjectParameters, system_params: SystemParameters):
rep.open_stage(system_params.usd_file_path)
with rep.new_layer("Defect"):
create_defects(defect_params, object_params)
create_randomizers(defect_params=defect_params, object_params=object_params)
# Create / Get camera
camera = create_camera(object_params)
render_product = rep.create.render_product(camera, (1024, 1024))
# Initialize and attach writer
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(output_dir=system_params.output_dir,
rgb=True,
semantic_segmentation=system_params.use_seg,
bounding_box_2d_tight=system_params.use_bb)
# Attach render_product to the writer
writer.attach([render_product])
# Setup randomization
with rep.trigger.on_frame(num_frames=system_params.frames, rt_subframes=system_params.rt_subframes):
rep.randomizer.move_defect()
rep.randomizer.change_defect_image()
def run_replicator(defect_params, object_params, system_params):
remove_replicator_graph(object_params)
total_frames = system_params.frames
if total_frames > 0:
create_defect_layer(defect_params, object_params, system_params)
rep.orchestrator.run()
else:
carb.log_error(f"Number of frames is {total_frames}. Input value needs to be greater than 0.")
The code seems to work, but at some point stops running and no image is generated. If I run the same stage within isaac-sim it does generate images.
Do I need any aditional steps? My final intention is to deploy a service that can take in an image and generate a new one with new defects without the necessity of the isaac-sim UI.
Please find attached the logs:
replicator-docker.txt (40.9 KB)
