I am starting to work with the Replicator Docker image, v1.6.3. I am running the attached script like this on an OVX:
docker run --gpus all --env HTTP_PROXY="$HTTP_PROXY" --env HTTPS_PROXY="$HTTPS_PROXY" -v .:/data omniverse-replicator-cached:1.6.3 --/omni/replicator/script=/data/simulate.py
The simulation generates images and metadata, seemingly correctly, but I get a lot of warnings and errors in the log (see attached file).
For example:
2023-04-27 07:38:58 [1,350ms] [Error] [omni.splash.plugin] startupManagerImpl: Couldn't create connection with display.
2023-04-27 07:38:58 [1,350ms] [Error] [omni.splash.plugin] startupManagerImpl: ISplashScreen interface failed to properly initialize.
2023-04-27 07:38:58 [1,350ms] [Error] [omni.kit.window.splash.ext.plugin] Failed to create splash screen!
2023-04-27 07:38:58 [1,718ms] [Warning] [omni.platforminfo.plugin] failed to open the default display. Can't verify X Server version.
2023-04-27 07:39:10 [13,860ms] [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Sphere_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
2023-04-27 07:39:10 [13,860ms] [Warning] [omni.kit.widget.layers.layer_model] /Replicator/SphereLight_Xform.xformOp:scale is overridden in a stronger layer (Root Layer).
2023-04-27 07:39:10 [13,860ms] [Warning] [omni.kit.widget.layers.layer_model] /Replicator/SphereLight_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
2023-04-27 07:39:10 [13,860m[14.865s] RTX ready
s] [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Cube_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
2023-04-27 07:39:10 [13,860ms] [Warning] [omni.kit.widget.layers.layer_model] /Replicator/SphereLight_Xform_01.xformOp:scale is overridden in a stronger layer (Root Layer).
2023-04-27 07:39:10 [13,860ms] [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Torus_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
2023-04-27 07:39:10 [13,860ms] [Warning] [omni.kit.widget.layers.layer_model] /Replicator/SphereLight_Xform_01.xformOp:translate is overridden in a stronger layer (Root Layer).
2023-04-27 07:39:10 [13,860ms] [Warning] [omni.kit.widget.layers.layer_model] /Replicator/Camera_Xform.xformOp:translate is overridden in a stronger layer (Root Layer).
Do you know what the cause of these is and whether they are significant?
Thanks for any help
Bruno
simulate.log (37.6 KB)
simulate.py (1.3 KB)
