Hello.
@pcallender
@dennis.lynch
I have noticed that in Isaac Sim 4.0.0 (Replicator 1.11.8) that the Replicator Materials, such as “Project PBR Material”, “Project Mask”, “Project Normals” are no longer shown under the “Replicator” section when I open the Material Graph tab.
Actually, the “Replicator” section that used to exist in the previous Replicator version (or Isaac Sim 2023.1.1) no longer exists when I open the Material Graph tab.
However, in the previous Replicator version(1.10.10) in Isaac Sim 2023.1.1, and according to the Replicator documentation, there should be a “Replicator” section when I open the Material Graphs tab as shown below:
https://docs.omniverse.nvidia.com/extensions/latest/ext_replicator/replicator_materials.html#replicator-materials
Also, when I run the following “rep.modify.projection_material” sample code in the Replicator API document, “ProjectPBRMaterial” is not created as it should.
import os
torus = rep.create.torus()
cube = rep.create.cube(position=(50, 100, 0), rotation=(0, 0, 90), scale=(0.2, 0.2, 0.2))
sem = [('class', 'shape')]
with torus:
projection = rep.create.projection_material(cube, sem)
with projection:
rep.modify.projection_material(diffuse=os.path.join(rep.example.TEXTURES_DIR, "smiley_albedo.png"))
Instead of the proper ProjectPBRMaterial, I am given this weird shader with just the diffuse_texture parameter as shown in the Material Graph and the error message, which I copy pasted below.
2024-07-18 06:18:06 [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
2024-07-18 06:18:06 [Error] [carb] [Plugin: omni.sensors.nv.lidar.ext.plugin] Dependency: [omni::sensors::lidar::IGenericModelOutputIOFactory v0.1] failed to be resolved.
2024-07-18 06:18:07 [Warning] [omni.kit.profiler.window] remove _SpanInstance.__lt__ and use insort 'key' arg instead
2024-07-18 06:18:25 [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated key:'ALT + S (On Press)'
2024-07-18 06:18:25 [Warning] [omni.kit.hotkeys.core.registry] -- Global [omni.kit.window.script_editor] omni.kit.window.script_editor::Save.ALT + S
2024-07-18 06:18:25 [Warning] [omni.kit.hotkeys.core.registry] -- Global [omni.anim.curve.core-1.1.13] omni.anim.curve.core-1.1.13::add_key.ALT + S
2024-07-18 06:18:25 [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.window.script_editor] omni.kit.window.script_editor::Save.ALT + S, error code: Duplicated key definition
2024-07-18 06:18:45 [Warning] [omni.fabric.plugin] No source has valid data array=0000020AB4E8D638 usdValid=0 cpuValid=0
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ab2e99ed0(38,10): C120 could not find module '::replicator_definitions' in module path
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ab2e99ed0(146,22): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ab2e99ed0(147,19): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ab2e99ed0(148,24): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ab2e99ed0(151,17): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ab2e99ed0(169,45): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ab2e99ed0(169,126): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ab2e99ed0(173,55): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (rtx_scope0) failed: ::Z73file_3A::Z16C_3A::users::admin::appdata::local::ov::pkg::Z34isaac_2Dsim_2D4_2E0_2E0::extscache::ZB3omni_2Ereplicator_2Ecore_2D1_2E11_2E8_2B106_2E0_2E0_2Ewx64_2Er_2Ecp310::mdl::project_pbr_material
2024-07-18 06:18:45 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (rtx_scope0): ::Z73file_3A::Z16C_3A::users::admin::appdata::local::ov::pkg::Z34isaac_2Dsim_2D4_2E0_2E0::extscache::ZB3omni_2Ereplicator_2Ecore_2D1_2E11_2E8_2B106_2E0_2E0_2Ewx64_2Er_2Ecp310::mdl::project_pbr_material
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad32ad430(38,10): C120 could not find module '::replicator_definitions' in module path
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad32ad430(146,22): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad32ad430(147,19): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad32ad430(148,24): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad32ad430(151,17): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad32ad430(169,45): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad32ad430(169,126): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad32ad430(173,55): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:18:45 [Error] [omni.hydra] Failed to create MDL shade node for prim '/World/Looks/ProjectPBRMaterial/Shader'. createMdlModule failed.
2024-07-18 06:19:52 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad34769c0(38,10): C120 could not find module '::replicator_definitions' in module path
2024-07-18 06:19:52 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad34769c0(146,22): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:19:52 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad34769c0(147,19): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:19:52 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad34769c0(148,24): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:19:52 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad34769c0(151,17): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:19:52 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad34769c0(169,45): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:19:52 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad34769c0(169,126): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:19:52 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/C:/users/admin/appdata/local/ov/pkg/isaac-sim-4.0.0/extscache/omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310/mdl/project_pbr_material.mdl?watch=0000020ad34769c0(173,55): C108 'replicator_definitions' is not a package or module name
2024-07-18 06:19:52 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (rtx_scope0) failed: ::Z73file_3A::Z16C_3A::users::admin::appdata::local::ov::pkg::Z34isaac_2Dsim_2D4_2E0_2E0::extscache::ZB3omni_2Ereplicator_2Ecore_2D1_2E11_2E8_2B106_2E0_2E0_2Ewx64_2Er_2Ecp310::mdl::project_pbr_material
2024-07-18 06:19:52 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (rtx_scope0): ::Z73file_3A::Z16C_3A::users::admin::appdata::local::ov::pkg::Z34isaac_2Dsim_2D4_2E0_2E0::extscache::ZB3omni_2Ereplicator_2Ecore_2D1_2E11_2E8_2B106_2E0_2E0_2Ewx64_2Er_2Ecp310::mdl::project_pbr_material
2024-07-18 06:19:52 [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from C:\users\admin\appdata\local\ov\pkg\isaac-sim-4.0.0\extscache\omni.replicator.core-1.11.8+106.0.0.wx64.r.cp310\mdl\project_pbr_material.mdl
2024-07-18 06:19:56 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::infinite_pbr_material' in module path
2024-07-18 06:19:56 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (rtx_scope0) failed: ::infinite_pbr_material
2024-07-18 06:19:56 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (rtx_scope0): ::infinite_pbr_material
2024-07-18 06:19:56 [Warning] [omni.kit.window.material_graph.shader_registry.mdl_registry] Pymdl could not fetch module: infinite_pbr_material.mdl from database
2024-07-18 06:19:56 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::project_pbr_material' in module path
2024-07-18 06:19:56 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (rtx_scope0) failed: ::project_pbr_material
2024-07-18 06:19:56 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (rtx_scope0): ::project_pbr_material
2024-07-18 06:19:56 [Warning] [omni.kit.window.material_graph.shader_registry.mdl_registry] Pymdl could not fetch module: project_pbr_material.mdl from database
2024-07-18 06:19:56 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::replicator_definitions' in module path
2024-07-18 06:19:56 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (rtx_scope0) failed: ::replicator_definitions
2024-07-18 06:19:56 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (rtx_scope0): ::replicator_definitions
2024-07-18 06:19:56 [Warning] [omni.kit.window.material_graph.shader_registry.mdl_registry] Pymdl could not fetch module: replicator_definitions.mdl from database
Lastly, I have also noticed that the replicator script and the “custom projection material” that used to work just fine in the previous Isaac Sim (2023.1.1) does not work in the newer version of Isaac Sim (4.0.0)(Replicator 1.11.8).
When I load a USD file with a “custom projection material” that was made with Replicator Materials (by connecting theProject Normal, Project Mask helper nodes in Material Graph) in the previous version of Isaac Sim (2023.1.1), and run the replicator script, I get the following errors on the console tab instead of the defects being projected on to the target mesh.
(I have blurred out the viewport for confidentiality)
I have also attached the log file for your reference.
kit_20240717_175303.log (1.1 MB)
So my questions are as follows:
As shown in this post, Replicator’s “projection material” feature no longer works in the latest updates of Isaac Sim and Replicator.
If it has been modified, could you direct me to any resources or documentation that explain the new changes regarding Replicator’s “Projection Materials”?
Or, will this feature be no longer available in future updates of Isaac Sim/Replicator?
I particularly found the Replicator’s “projection material” method extremely useful for generating defect images and really hope that is not the case.
Your expertise on this would be greatly appreciated.
