'Auto On' disable support
Does Jetson Orin NX devkit still support the ‘Auto on’ disable feature. (Jetson Nano devkit has a jumper that had to be linked to disable the ‘Auto on’ feature.)
The question is asking whether the Jetson Orin NX devkit still supports the Auto on disable feature, which was present in the Jetson Nano devkit.
After reviewing the provided context, I couldn’t find any specific information about the Auto on disable feature in the Jetson Orin NX devkit. However, I can provide some insights based on the available information.
The Jetson Orin NX devkit is mentioned in the context as one of the supported devices, along with the Jetson AGX Orin devkit. However, there is no explicit mention of the Auto on disable feature in the context.
In contrast, the Jetson Nano devkit is mentioned as having a jumper that needs to be linked to disable the Auto on feature. This suggests that the Auto on feature is present in the Jetson Nano devkit, and it can be disabled using a jumper.
Since the Jetson Orin NX devkit is not explicitly mentioned as having the Auto on disable feature, it is unclear whether this feature is supported or not. However, it is possible that the feature is present but not documented in the provided context.
To confirm whether the Jetson Orin NX devkit supports the Auto on disable feature, I would recommend checking the official NVIDIA documentation or contacting their support team for more information.
In comparison to the Jetson Nano devkit, the Jetson Orin NX devkit may have different hardware or software configurations that could affect the availability of the Auto on disable feature. Without further information, it is difficult to determine whether the feature is supported or not.
In summary, while the Jetson Nano devkit has a documented Auto on disable feature, the Jetson Orin NX devkit’s support for this feature is unclear based on the provided context. Further investigation is needed to confirm whether the feature is supported or not.
Hi @markg3 !
Taken from: Jetson Orin Nano Developer Kit Carrier Board Specification, you can connect Pin 5 and 6 from the J14 button header to disable Auto-power-on.
Hope this helps!
Nico
Best regards
Hi Nico,
Thanks for pointed this out. We tested this feature on devkit. It works.
Mark
Hi @markg3 !
Great to hear it is working now. When you get a chance, could you mark the reply as the accepted solution? It’ll help others searching for the same issue.
Best regards,
Nico
