Autocompletion/IntelliSense for omni.isaac.* Modules
Hello, I am currently working myself through the Isaac Sim Python Tutorials.
Everything works fine, however, I do not have any autocompletion for the omni.isaac.* modules.
For example: from omni.isaac.wheeled_robots.robots import WheeledRobot here VSCode tells me the module could not be found.
Is there a way to include those modules such that the autocompletion/IntelliSense features of VSCode work for those modules?
Isaac Sim 2022.2.1 on Windows 10.
I really appreciate any help you can provide.
Hi @valentino.geuenich1
I also tried to include all isaac libraries using * with no luck. What I ended up doing is including the full path to each isaac library that I’m using in .vscode/settings.json. It’s also what the custom VS code workspace for Isaac does:
"python.analysis.extraPaths": [
        "~/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.wheeled_robots",
Thank you very much @dgarcialopez. This helped a lot.
For anyone who wants to do the same:
I found the .vscode folder inside the isaac_sim-2022.2.1 folder containing all the relevant extraPaths.
I replaced the relative paths with absolute paths in the settings.json such that it works from all locations. This way I can copy the .vscode folder to anywhere where I opened the VSCode editor.
