Azure IoT SDK on Drive Orin with Wifi and Ethernet
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I have made one application which is having Azure IoT SDK used in it, and when the drive Orin is connected to Wifi, my application is working fine.
But when I am connecting my Drive Orin to both ethernet and wifi, then the application is unable to connect to the internet.
So, requesting help in this regard
We haven’t tested the Azure IoT SDK on the DRIVE platform, so we can’t confirm its behavior in this context. Could you clarify if the issue you’re experiencing is specific to Azure or if it’s related to network configuration when both Ethernet and Wi-Fi are connected?
I have tried with a python application also which just connects to github.com, in that also I am facing the issue, So this is the issue related to the network configuration
How did you enable Wi-Fi on the devkit? As far as I know, Wi-Fi isn’t officially supported on the DRIVE platform. Could you clarify what you meant by “connecting to github.com”? Are you using a script to access a repository, or is it a simple network connectivity test?
