BehaviorScript.on_init is executed before USD-Scripting warning
Hey!
I just noticed that the BehaviorScript.on_init is run while a scene is loaded in IsaacSim 4.5 and before(!) the pop up is shown that asks if you really want to enable script execution.
So this popup is rather dangerous because it let’s you believe that no code was executed and that refusing could save you from malicious code.
Thank you for reporting this issue. We will fix it.
