I tried to create the corresponding dtbs, using my Ubuntu VMware and the corresponding sdkmanager environment; also it is required to sync with git, creating your own development environment for ‘just updating’ the network speed.
After all, I struggled with all those steps, always ending up in additional error messages, as inludes are missing or need to be renamed or it seems even makefiles need updates :-(
–> As I’m probably not the only one to build a new kernel, DTB files, root file system:
Is there any best practises showing ‘easy steps’, also with the corresponding difference between SDKmanager directory structure and thor git-sources, e.g. when to copy which files between those sources and where to?
Any help would be highly apprectiated!
(I have basic Linux know.how, but am not a full time software developer, sorry)
One important recommendation is to use a machine with Native Ubuntu. Using VM for flashing Jetson devices may cause many issues due to the instability of the USB connection. It may randomly disconnect during flashing or the board may not even get recognized.
You can follow the next steps to set up your Linux_for_Tegra build directory to apply the changes you need.
Download JetPack 7 sources from NVIDIA’s official page: JetPack 7 sources. From the drivers tab download: Driver package (BSP) and Sample root Filesystem. The files downloaded are called:
dtc --help
Usage: dtc [options] <input file>
Options: -[qI:O:o:V:d:R:S:p:a:fb:i:H:sW:E:@AThv]
-q, --quiet
Quiet: -q suppress warnings, -qq errors, -qqq all
-I, --in-format <arg>
Input formats are:
dts - device tree source text
dtb - device tree blob
fs - /proc/device-tree style directory
-o, --out <arg>
Output file
-O, --out-format <arg>
Output formats are:
yaml - device tree encoded as YAML
asm - assembler source
-V, --out-version <arg>
Blob version to produce, defaults to 17 (for dtb and asm output)
-d, --out-dependency <arg>
Output dependency file
-R, --reserve <arg>
Make space for <number> reserve map entries (for dtb and asm output)
-S, --space <arg>
Make the blob at least <bytes> long (extra space)
-p, --pad <arg>
Add padding to the blob of <bytes> long (extra space)
-a, --align <arg>
Make the blob align to the <bytes> (extra space)
-b, --boot-cpu <arg>
Set the physical boot cpu
-f, --force
Try to produce output even if the input tree has errors
-i, --include <arg>
Add a path to search for include files
-s, --sort
Sort nodes and properties before outputting (useful for comparing trees)
-H, --phandle <arg>
Valid phandle formats are:
legacy - "linux,phandle" properties only
epapr - "phandle" properties only
both - Both "linux,phandle" and "phandle" properties
-W, --warning <arg>
Enable/disable warnings (prefix with "no-")
-E, --error <arg>
Enable/disable errors (prefix with "no-")
-@, --symbols
Enable generation of symbols
-A, --auto-alias
Enable auto-alias of labels
-T, --annotate
Annotate output .dts with input source file and line (-T -T for more details)
-h, --help
Print this help and exit
-v, --version
Print version and exit
This was extremely helpful and really assisted me in solving the task — there were a few minor points left, but I was able to handle those myself.
I managed to flash the Thor; however, there is still the issue that after boot, the console remains dark.
(I already applied the Console-patch with
SOC Display Hand-Off Mode: Auto
SOC Display Hand-Off Method: efifb
but it didn’t help too much: at least I could see some more output over the screen,
but no login screen/ Ubuntu Logo etc.)
Because of this, the final setup steps are not executed, and I end up without a user / login.
Is there any additional option I could try?
Thanks in advance!
Claus
That was exactly the answer I needed.
(the only hint I would give to others is, that the order when you start that script is important:
it is not only before flashing, but also before the ‘final’ recompile; otherwise it won’t be taken under consideration…)
So, finally I managed to implement my changes to 100 GbE and also bring Thor up and running :-)!
Besides this next topics are:
Console screen still is dark after reboot; is there any option I’ll need to implement into the kernel,
to have that x-window visible after a reboot?
I also found out, that now I have 4 25 GbE Ports available.
However, documentation doesn’t show, that if you use a 100 GbE cable and not
100 GbE → 4 25 GbE, that you’ll need another configuration than the one documented.
The 4 * 25GbE Ports will need to show up as one 100 GbE Port for any “100 GbE” switch connected.
ChatGPT gave recommendations for the individual additional values, such as
