I have been struggling getting all of the various test apps to run before breaking out and building my own app. My first question is what is the best practice for file permissions within the samples directories. If you follow the instructions DeepStream ends up getting installed into /opt/nvidia/deepstream/* and when you go to edit any config files I have to use sudo. Very annoying with vscode as it prompts to switch to sudo to save and if you don’t see this you go on to test without the file being saved. Nowhere in the instructions does it say to chown any of the tree but I did find an Nvidia response to another issue where it suggested sudo chown -R user:user /opt/nvidia/. Is this the right thing to do or can/should it be done on a smaller part of the tree?
I’m wondering if this is also leading to a problem with running deepstream-test3 where it takes several minutes to start. I’m wondering if this is because it is on-demand compiling a model and then fails to write it out for the next run.
This comes to the other part of my question. I want to start my own app but NOT have it nested down in /opt/nvidia/deepstream. If I create a git repo up in my users home directory then what do I need to do for access down into the /opt/nvidia/deepstream tree? I was kind of surprised the python samples git repo needed to be cloned down into the nvidia tree vs anywhere. What breaks and what needs to be patched if that was cloned elsewhere. It’s a very rigid structure with a lot of tentacles.
• Hardware Platform (Jetson / GPU) Jetson OWIN
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2-b104
