I wanted to create a discussion on what everyone has done to get high volume camera data into the Jetson.
Currently, we have created a camera-based navigation system. We have resorted to using 1 ZED and 3 Realsense D435i to accomplish this. However, I would like to created a system that takes advantage of the CSI-2 lanes on the Jetson.
How I have done it
My setup uses data from 4 stereo cameras (1 ZED and 3 RealSense D435i cameras). When using the TX2, I used a PCIe USB 3.0 expansion hub with 4 USB 3.0 host controllers and can support the bandwidth required from these 4 cameras.
The USB 3.0 Hub: https://www.amazon.com/StarTech-com-Express-SuperSpeed-Dedicated-Channels/dp/B00HJZEA2S
How to do it better?
1. CPU Consumption
Because I’m using these cameras over USB, simply capturing data consumes a large chunk of the CPU. Is there a better way to do this?
2. Using CSI-2 lanes is expensive
I understand that there are a few solutions (Leopard Imaging, e-con, etc.) out there that allow you to take advantage of the CSI-2 lanes, but their price points are ridiculous. What has the community done, to get a cheap(er) solution to take advantage of the CSI-2 lanes on the Jetson line?
