Black screen on Precision 3571 with Nvidia T600 GPU
I’ve just deployed Alma Linux 8.6 on a DELL Precision laptop with a T600 Nvidia GPU.
# lspci |grep -i nvidia
0000:01:00.0 3D controller: NVIDIA Corporation TU117GLM [T600 Laptop GPU] (rev a1)
I’ve installed the Nvidia drivers with:
dnf config-manager --add-repo https://developer.download.nvidia.com/compute/cuda/repos/rhel8/x86_64/cuda-rhel8.repo
dnf install nvidia-driver nvidia-settings
Now, I get a black screen at reboot time. I can connect to the laptop via ssh and list the modules loaded:
# lsmod |grep nvidia
nvidia_drm             61440  3
nvidia_modeset       1101824  3 nvidia_drm
nvidia_uvm           1204224  0
nvidia              40214528  162 nvidia_uvm,nvidia_modeset
drm_kms_helper        266240  2 nvidia_drm,i915
drm                   585728  9 drm_kms_helper,nvidia,nvidia_drm,i915,ttm
# lsmod |grep -i nouveau
I do not find information in /var/log/Xorg.0.log (no “EE” lines) nor in /var/log/mesages.
How to investigate ?
Patrick
nvidia-bug-report.log.gz (79.5 KB)
You need to install a newer kernel for your 12th gen intel igpu.
Thanks Generix for youproposition.
Indeed I have the latest available Kernel in Alma Linux 8.6 which is just a rebuild of RHEL8.6. So rhe rpm provided by nvidia reposit for RHEL8 should work no ? I do not want to use 9.0 version as some software are not available for it at this time.
What kernel version do you suggest ?
Since yesterday evening I have a new solution to test: DELL provides some nvidia drivers for their hardware. But it is a manual install, modifying several files by hand… so difficult to integrate in a PXE boot +Kickstart install workflow. But I should also test it.
Thanks again
Patrick
You don’t need any other nvidia drivers, thos are functional. The internal display is driven by the intel igpu which is missing drivers.
https://www.linuxcapable.com/how-to-install-linux-kernel-5-15-on-rocky-linux-8/
