Hello everybody.
I’m new to this forum and hope someone can help me.
I recently got a Dell laptop with NVIDIA Quadro GPU on which I installed RHEL 6.8 and to use its 3D capabilities I downloaded NVIDIA-Linux-x86_64-370.28.run (but also tried with version 367 and 352) and followed all instructions but could not manage to get it working.
I always get a fatal error as you can see form a part of the Xorg.0.log:
[ 52.552] (II) LoadModule: “wfb”
[ 52.552] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 52.562] (II) Module wfb: vendor=“X.Org Foundation”
[ 52.562] compiled for 1.17.4, module version = 1.0.0
[ 52.562] ABI class: X.Org ANSI C Emulation, version 0.4
[ 52.562] (II) Loading sub module “ramdac”
[ 52.562] (II) LoadModule: “ramdac”
[ 52.562] (II) Module “ramdac” already built-in
[ 52.564] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 52.564] (==) NVIDIA(0): RGB weight 888
[ 52.564] (==) NVIDIA(0): Default visual is TrueColor
[ 52.564] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 52.565] () NVIDIA(0): Enabling 2D acceleration
[ 53.867] (–) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 53.867] (–) NVIDIA(0): CRT-0
[ 53.867] (–) NVIDIA(0): DFP-0
[ 53.867] (–) NVIDIA(0): DFP-1
[ 53.867] (–) NVIDIA(0): DFP-2
[ 53.867] (–) NVIDIA(0): DFP-3
[ 53.868] (–) NVIDIA(0): CRT-0: disconnected
[ 53.868] (–) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 53.868] (–) NVIDIA(0): DFP-0: disconnected
[ 53.868] (–) NVIDIA(0): DFP-0: Internal TMDS
[ 53.868] (–) NVIDIA(0): DFP-0: 165.0 MHz maximum pixel clock
[ 53.868] (–) NVIDIA(0): DFP-1: disconnected
[ 53.868] (–) NVIDIA(0): DFP-1: Internal TMDS
[ 53.868] (–) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 53.868] (–) NVIDIA(0): DFP-2: disconnected
[ 53.868] (–) NVIDIA(0): DFP-2: Internal DisplayPort
[ 53.868] (–) NVIDIA(0): DFP-2: 960.0 MHz maximum pixel clock
[ 53.868] (–) NVIDIA(0): DFP-3: disconnected
[ 53.868] (–) NVIDIA(0): DFP-3: Internal DisplayPort
[ 53.868] (–) NVIDIA(0): DFP-3: 960.0 MHz maximum pixel clock
[ 53.869] (II) NVIDIA(0): NVIDIA GPU Quadro M2000M (GM107GL-A) at PCI:1:0:0 (GPU-0)
[ 53.869] (–) NVIDIA(0): Memory: 4194304 kBytes
[ 53.869] (–) NVIDIA(0): VideoBIOS: 82.07.8f.00.1b
[ 53.869] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 53.870] (EE) NVIDIA(0): Failed to assign any connected display devices to X screen 0.
[ 53.870] (EE) NVIDIA(0): Set AllowEmptyInitialConfiguration if you want the server
[ 53.870] (EE) NVIDIA(0): to start anyway
[ 53.870] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 53.951] (II) UnloadModule: “nvidia”
[ 53.951] (II) UnloadSubModule: “wfb”
[ 53.951] (II) UnloadSubModule: “fb”
[ 53.951] (EE) Screen(s) found, but none have a usable configuration.
[ 53.951] (EE)
Fatal server error:
[ 53.951] (EE) no screens found(EE)
I looked at different forums where could find similar problem but so far nothing good. I also posted similar question to RED HAT support and waiting -:(.
Any idea ?
Pietro
