nvidia-bug-report.log.gz (475.0 KB)
So I can boot into my wayland DE if I am using the following displays,
1 DP display
2 DP displays
1 HDMI display
But if I do
1 DP and 1 HDMI displays
2 DP and 1 HDMI displays
Once I login via sddm, all the monitors will turn black and have ‘no signal’ displayed. Plus, I cannot switch tty.
But if I login with 2 DP displays first, then physically connect my HDMI display, it works
With 2 DP and 1 HDMI displays, I can use KDE plasma 6 on X11 with no problem at all. I assume hardware is not the issue here.
The journalctl -b -1 output journalctl -b -1 - Pastebin.com
Mar 08 14:34:22 desktop kernel: nvidia-modeset: WARNING: GPU:0: Lost display notification (0:0x00000000); continuing.
This may be the cause.
