Following the video tutorials to create blend morphs for my custom head, but in the console, I receive this error:
[Error] [asyncio] [f:\omniverse\library\audio2face-2021.3.3\kit\python\lib\asyncio\base_events.py:1619] Task exception was never retrieved
future: <Task finished coro=<transfer_blendshapes() done, defined at f:\omniverse\library\audio2face-2021.3.3\exts\omni.kit.charTransfer\omni\kit\charTransfer\tools.py:265> exception=RuntimeError(‘Accessed invalid null prim’)>
File “f:\omniverse\library\audio2face-2021.3.3\exts\omni.kit.charTransfer\omni\kit\charTransfer\tools.py”, line 354, in transfer_blendshapes
if world_outPrim.HasAttribute(“xformOp:translate”):
RuntimeError: Accessed invalid null prim
Only the browLowerL_01 mesh is created in the stage.
Hi @cgjd18, seems like this is related to the prim name path. I guess your custom head has some naming issue that is not compatible to the current code.
Can you screen capture the stage view of your working stage? or attach the .usd file of your custom head, so we can check it out?
If you follow this way, it will work. Start a new scene → +MALE TEMPLATE → drag&drop your head asset into stage view → follow the blendshape generation process (as in the tutorial video). Please see the attached image of the successful blendshape transfer.
In your scene, it seems like you first open your head asset file → +MALE TEMPLATE → follow the blendshape generation process. In this case, the tool makes that error due to prim name (currently right under the World)
We will fix the code to handle this case in the next release.
Hi. I’m having the same problem.
I did try to follow your method by creating a “New Stage” > + Skin Template > Drag&Drop head file but I keep getting new errors.
