BMM150 init fail in Jetson NX
I recently purchased a bmm150 compass from seed grove to interface it with my jetson NX. When i connect using i2c port I2C1_SDA I2C Bus 8 , the device is getting detected using sudo i2cdetect -r -y 8 as
i2c1
But when i run the compass code, it throws me an init error. I am not sure if the issue exists with jetson or with compass library. The below is the error message where 0x08 represents the bus and 0xD represents the address.
It works perfectly in rpi but not in jetson devices (http://www.pibits.net/code/raspberry-pi-and-bmm150-digital-geomagnetic-sensor-python-example.php).
I could see many questions on the same topic but no accurate response/suggestion was given.
Looking forward for help.
Regards
Niranjan
If the slave address is 13 you need to modify it to 0x13 like sensorObj.BMM150(0x8,0x13)
Hi @ShaneCCC ,
I have tried it as well, its not working. Same init error is repeating.
Its not the issue with compass hardware but quite unsure how to overcome this error.
What’s the line 896 in pyupm_bmm150.py?
Hi @ShaneCCC ,
def init(self, bus=0, addr=0x10, cs=-1): line 895
this = _pyupm_bmm150.new_BMM150(bus, addr, cs) line 896
In line 895, i changed bus to 8, addr = 0x13 as well. But it does not take any effect and still displays init fail error.
This function looks like for SPI instead of i2c?
