Hi ,
Is it possible to flash & boot rootfs from the SD Card ?
Hi ,
Please elaborate more about your system.
In Jetson Nano is it possible to flash file system over External SD card directly ?
I’m using emmc binaries generated from sources released for L4T version 32.4.2. Planning to boot from External Sd card.
Thanks in advance…
Yash M J
So you are using a custom carrier board with a sdcard slot on it, right?
You can check this page.
https://elinux.org/Jetson/L4T/Boot_From_External_Device
