It seems you are using the custom board for Jetson Nano.
Actually, you should not use SDK Manager to flash your custom board due to this BSP package designed for the devkit from NVIDIA.
You may just refer to the instruction from Waveshare.
Our Jetson Nano devkit carrier board would not have both eMMC and SD at the same time, they may enable the config for SD card.
