Boot with sd card
I have a 16 gb emcc jetson nano. I flashed ubuntu 18.04 using SDK manager. I wrote an image with ubuntu 20.04 in it to sd card using etcher. I want to boot the jetson nano using sd card. please help.
Hello @y.n.s23yunus,
At this point, is the Jetson booting form EMMC ? Or not booting at all ?
regards,
Andrew
support@proventusnova.com
It is wrong to flash image from sdkmanager for that board.
Reason is explained over here.
Your are using a custom carrier board but not NV devkit.
hi Andrew,
Jetson boots from EMCC and works fine but i want to boot from sd card
So what should I do at this point? Can’t I boot using a sd card?
Please consult with the board vendor where to download their customized BSP.
This was also mentioned in the 2nd point of the post I attached…
