Hi, i have a Jetson Nano J101 V2 board and i’m finding it hard to make it boot from the SD card.
Originally, this SD card was in a B01 board and i want to use the same native Ubuntu OS image in J101 Board.
What will be the correct procedure/method to do this ?
Thanks in advance.
Is the sdcard slot on J101 carrier board itself or it is on the module?
Yes, It’s in the carrier Board
Then please contact the board vendor for help.
I just explained same thing in this post few mins ago.
Regarding the microSD issue, I think there are some misunderstanding here.
There are two kinds of jetson nano modules. One is sdcard module with sdcard slot on the module.
Another one is emmc module which does not have sdcard slot but only emmc.
The website which tells you that you can flash a “sdcard image” on Windows machine is basically for sdcard module. Not for emmc module.
Then the next problem is, then why you have a sdcard slot there. That is the uncertain part. I guess it i…
@pulzappcheck890
Sorry that I just read your reply again. And I don’t know what you are talking about.
We don’t have anything called “carrier module”.
The module and carrier board are two different things. Please do understand what I am asking first. And reply…
Your answer could only be either “carrier board” or “module”. There is no something called “carrier module”…
Sorry, my bad. It is the board. Thanks for the info.
Ok. Then please contact the board vendor.
system
Closed
February 21, 2023, 6:17pm
9
