No SD card populated
hi, so recently i have gotten the jetson j202 carrier board then latter on i have gotten the nano 4gb module and have went thought the whole sd card set up how ever now im having an issue where there is no sd card even populated on the nano module, and i cant find any information about part number or package size.
If you use a custom board, you need to contact with the board vendor for their customized BSP package so that their package will enable sdcard.
NV official image does not enable it.
Also, a custom board means any kind of carrier board that is not NV devkit.
on the physical on the nano module there is no place to put the SD card.
Yes, because the module you are using is not the one that could use sdcard… That is a emmc module.
Had a post to explain it here…
i see, so i would have to boot from the 16gb emmc?
Just to clarify this again.
  1. Yes, your module is a 16gb emmc module and has no sdcard slot.
  2. Because your board is a custom base board, I still need you to check with the board vendor if they have any customized BSP to make their board work fine.
  3. Generally emmc module could be flashed with sdkmanager + Jetpack from another x86 host PC.
    But that is by default only for NV developer kit. We don’t really guarantee that would work fine on a custom board. If the vendor claims sdkmanager can flash it, then you could try.
