We can’t have the suggestion from one picture.
Please provide more info of your system version and environment setup, and waht have been done on device.
If you don’t know what happened to cause this, just flash the board and see if it can recover.
If it cannot, then RMA this module. We can only help if you can provide methods to reproduce issue. Also, that method should be reasonable. For example, if your steps intend to break the board, then we have nothing to help.
如果你沒辦法提供步驟複製這個問題,就請你直接reflash the board然後看看能不能恢復
如果不能恢復, 就請RMA這個module. 我們只能幫那些有提供複製方法的問題. 當然那些複製方法本身要有意義. 如果說你的複製方法本身就是要把板子毀了,那我們也沒辦法幫你
The device is a Jetson Xavier module equipped with a custom carrier, not an official developer kit. It uses the l4t3250 version, jetpcak4 5. The device is placed at minus 5 degrees and then does not start. When powered on, the bootloader shell model is displayed. After heating up the device, it starts normally. Do you want to know whether the core cannot start at minus
Can you reproduce with official developer kit?
