Required Info:
Software Version
DRIVE OS 6.0.8.1
Target OS
Linux
SDK Manager Version
1.9.2.10884
Host Machine Version
native Ubuntu Linux 20.04 Host installed with DRIVE OS DOCKER Containers
Describe the bug
running helloworld cgf example showing errors
Actual behavior
the stm_master.log shows
av/stm/runtime/src/master/main.c:809 assertion failure, errno=11 (Resource temporarily unavailable)
[STM] Opening NvSciIpc endpoints...
[STM] Start schedule manager now.
[STM] Waiting for schedule manager : CGF-ScheduleManager ...
[STM] Registered CGF-ScheduleManager with pid 6222
[STM] Schedule manager starting state logic.
[STM] Start clients now.
[STM] Master waiting for all clients to start...
[STM] Waiting for client helloworld_process0...
[STM] Registered client helloworld_process0
[STM] Waiting for client sum_process0...
raised PROGRAM_ERROR : unhandled signal
Additional context
The issue often happes but doesn’t always happen.
qst1. what’s the error mean?
qst2. how to take a work around to avoid this error?
@SivaRamaKrishnaNV
Could you help this stability issue ASAP
Dear @lizhensheng ,
Could you share the reproduce steps and files.
here is the core part of the code, you could make some changes to make it run.
team_node.zip (77.0 KB)
@SivaRamaKrishnaNV Friendly ping for updates.
@SivaRamaKrishnaNV
I think any helloworld demo could reproduce the bug.
CGF-presentation.pdf (1.2 MB)
you could refer to this official slides from the forum to start.
Dear @lizhensheng ,
Do you see any loaderLite process instances are running using ps -aux?
Dear @lizhensheng ,
When you see this issue, could you share output of ps -aux ?
When I run the app successfully(which is a big cgf app rather than helloworld)
There is no resource error in the log. The I checked the ps -aux
It shows
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.1 0.0 168620 10624 ? Ss 03:04 0:01 lib/systemd/systemd
root 2 0.0 0.0 0 0 ? S 03:04 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? I< 03:04 0:00 [rcu_gp]
root 4 0.0 0.0 0 0 ? I< 03:04 0:00 [rcu_par_gp]
root 5 0.0 0.0 0 0 ? I< 03:04 0:00 [slub_flushwq]
root 7 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/0:0H-kblockd]
root 8 0.1 0.0 0 0 ? I 03:04 0:01 [kworker/u24:0-events_unbound]
root 9 0.0 0.0 0 0 ? I< 03:04 0:00 [mm_percpu_wq]
root 10 0.0 0.0 0 0 ? S 03:04 0:00 [rcu_tasks_kthre]
root 11 0.0 0.0 0 0 ? S 03:04 0:00 [rcu_tasks_rude_]
root 12 0.0 0.0 0 0 ? S 03:04 0:00 [rcu_tasks_trace]
root 13 0.2 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/0]
root 14 0.0 0.0 0 0 ? I 03:04 0:00 [rcu_preempt]
root 15 0.0 0.0 0 0 ? S 03:04 0:00 [rcub/0]
root 16 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/0]
root 17 0.0 0.0 0 0 ? S 03:04 0:00 [migration/0]
root 18 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/0]
root 19 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/0]
root 20 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/1]
root 21 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/1]
root 22 0.0 0.0 0 0 ? S 03:04 0:00 [migration/1]
root 23 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/1]
root 24 0.1 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/1]
root 26 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/1:0H-kblockd]
root 27 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/2]
root 28 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/2]
root 29 0.0 0.0 0 0 ? S 03:04 0:00 [migration/2]
root 30 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/2]
root 31 0.1 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/2]
root 33 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/2:0H-kblockd]
root 34 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/3]
root 35 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/3]
root 36 0.0 0.0 0 0 ? S 03:04 0:00 [migration/3]
root 37 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/3]
root 38 0.1 0.0 0 0 ? S 03:04 0:00 [ksoftirqd/3]
root 40 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/3:0H-events_highpri]
root 41 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/4]
root 42 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/4]
root 43 0.0 0.0 0 0 ? S 03:04 0:00 [migration/4]
root 44 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/4]
root 45 0.1 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/4]
root 47 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/4:0H-kblockd]
root 48 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/5]
root 49 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/5]
root 50 0.0 0.0 0 0 ? S 03:04 0:00 [migration/5]
root 51 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/5]
root 52 0.2 0.0 0 0 ? S 03:04 0:02 [ksoftirqd/5]
root 54 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/5:0H]
root 55 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/6]
root 56 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/6]
root 57 0.0 0.0 0 0 ? S 03:04 0:00 [migration/6]
root 58 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/6]
root 59 0.1 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/6]
root 60 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/6:0-mm_percpu_wq]
root 61 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/6:0H-kblockd]
root 62 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/7]
root 63 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/7]
root 64 0.0 0.0 0 0 ? S 03:04 0:00 [migration/7]
root 65 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/7]
root 66 0.1 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/7]
root 68 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/7:0H-kblockd]
root 69 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/8]
root 70 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/8]
root 71 0.0 0.0 0 0 ? S 03:04 0:00 [migration/8]
root 72 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/8]
root 73 0.1 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/8]
root 76 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/9]
root 77 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/9]
root 78 0.0 0.0 0 0 ? S 03:04 0:00 [migration/9]
root 79 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/9]
root 80 0.1 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/9]
root 82 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/9:0H-kblockd]
root 83 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/10]
root 84 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/10]
root 85 0.0 0.0 0 0 ? S 03:04 0:00 [migration/10]
root 86 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/10]
root 87 0.1 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/10]
root 89 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/10:0H-kblockd]
root 90 0.0 0.0 0 0 ? S 03:04 0:00 [cpuhp/11]
root 91 0.0 0.0 0 0 ? S 03:04 0:00 [irq_work/11]
root 92 0.0 0.0 0 0 ? S 03:04 0:00 [migration/11]
root 93 0.0 0.0 0 0 ? S 03:04 0:00 [rcuc/11]
root 94 0.1 0.0 0 0 ? S 03:04 0:01 [ksoftirqd/11]
root 96 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/11:0H-kblockd]
root 97 0.0 0.0 0 0 ? S 03:04 0:00 [kdevtmpfs]
root 98 0.0 0.0 0 0 ? I< 03:04 0:00 [inet_frag_wq]
root 99 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/0:1-events]
root 102 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/9:1-mld]
root 105 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/8:1-mm_percpu_wq]
root 107 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/10:1-mm_percpu_wq]
root 108 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/7:1-mm_percpu_wq]
root 109 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/3:1-events]
root 110 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/11:1-events_long]
root 111 0.0 0.0 0 0 ? S 03:04 0:00 [kauditd]
root 112 0.0 0.0 0 0 ? S 03:04 0:00 [irq/13-2c00000.]
root 113 0.0 0.0 0 0 ? S 03:04 0:00 [irq/147-3c00000]
root 114 0.0 0.0 0 0 ? S 03:04 0:00 [irq/148-3c00000]
root 115 0.0 0.0 0 0 ? S 03:04 0:00 [irq/149-1600000]
root 116 0.0 0.0 0 0 ? S 03:04 0:00 [irq/150-1600000]
root 117 0.0 0.0 0 0 ? S 03:04 0:00 [irq/151-b950000]
root 118 0.0 0.0 0 0 ? S 03:04 0:00 [oom_reaper]
root 119 0.0 0.0 0 0 ? I< 03:04 0:00 [writeback]
root 120 0.0 0.0 0 0 ? S 03:04 0:00 [kcompactd0]
root 121 0.0 0.0 0 0 ? SN 03:04 0:00 [ksmd]
root 130 0.0 0.0 0 0 ? I< 03:04 0:00 [cryptd]
root 146 0.0 0.0 0 0 ? I< 03:04 0:00 [kintegrityd]
root 147 0.0 0.0 0 0 ? I< 03:04 0:00 [kblockd]
root 148 0.0 0.0 0 0 ? I< 03:04 0:00 [blkcg_punt_bio]
root 149 0.0 0.0 0 0 ? I< 03:04 0:00 [tpm_dev_wq]
root 150 0.0 0.0 0 0 ? I< 03:04 0:00 [ata_sff]
root 151 0.0 0.0 0 0 ? I< 03:04 0:00 [edac-poller]
root 152 0.0 0.0 0 0 ? I< 03:04 0:00 [devfreq_wq]
root 153 0.0 0.0 0 0 ? S 03:04 0:00 [watchdogd]
root 154 0.2 0.0 0 0 ? I 03:04 0:01 [kworker/u24:1-events_unbound]
root 156 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/3:1H-kblockd]
root 157 0.0 0.0 0 0 ? I< 03:04 0:00 [rpciod]
root 158 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/u25:0]
root 159 0.0 0.0 0 0 ? I< 03:04 0:00 [xprtiod]
root 187 0.0 0.0 0 0 ? S 03:04 0:00 [kswapd0]
root 188 0.0 0.0 0 0 ? I< 03:04 0:00 [nfsiod]
root 190 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/2:2-events]
root 191 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/2:3-events]
root 194 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 195 0.0 0.0 0 0 ? S 03:04 0:00 [irq/16-arm-smmu]
root 196 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 197 0.0 0.0 0 0 ? S 03:04 0:00 [irq/18-arm-smmu]
root 198 0.0 0.0 0 0 ? I< 03:04 0:00 [vfio-irqfd-clea]
root 199 0.0 0.0 0 0 ? I< 03:04 0:00 [dm_bufio_cache]
root 201 0.0 0.0 0 0 ? S 03:04 0:00 [pr/ttyS2]
root 206 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/u24:3-flush-252:0]
root 207 0.0 0.0 0 0 ? S 03:04 0:00 [irq/221-wakeup-]
root 401 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/1:2-events]
root 404 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 405 0.0 0.0 0 0 ? I< 03:04 0:00 [vblk_req_wq0]
root 406 0.0 0.0 0 0 ? S 03:04 0:00 [irq/242-vblk]
root 407 0.0 0.0 0 0 ? S 03:04 0:00 [irq/16-arm-smmu]
root 408 0.0 0.0 0 0 ? I< 03:04 0:00 [vblk_req_wq1]
root 409 0.0 0.0 0 0 ? S 03:04 0:00 [irq/239-vblk]
root 410 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 411 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/0:1H-kblockd]
root 413 0.0 0.0 0 0 ? I< 03:04 0:00 [vblk_req_wq2]
root 414 0.0 0.0 0 0 ? S 03:04 0:00 [irq/240-vblk]
root 415 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 416 0.3 0.0 0 0 ? I 03:04 0:03 [kworker/0:3-events]
root 417 0.0 0.0 0 0 ? I< 03:04 0:00 [vblk_req_wq50]
root 418 0.0 0.0 0 0 ? S 03:04 0:00 [irq/241-vblk]
root 419 0.0 0.0 0 0 ? I< 03:04 0:00 [vblk_req_wq3]
root 420 0.0 0.0 0 0 ? S 03:04 0:00 [irq/243-vblk]
root 422 0.0 0.0 0 0 ? I< 03:04 0:00 [vblk_req_wq20]
root 423 0.0 0.0 0 0 ? S 03:04 0:00 [irq/233-vblk]
root 424 0.0 0.0 0 0 ? I< 03:04 0:00 [vblk_req_wq21]
root 425 0.0 0.0 0 0 ? S 03:04 0:00 [irq/234-vblk]
root 428 0.0 0.0 0 0 ? I< 03:04 0:00 [vblk_req_wq22]
root 429 0.0 0.0 0 0 ? S 03:04 0:00 [irq/235-vblk]
root 430 0.0 0.0 0 0 ? I< 03:04 0:00 [vblk_req_wq30]
root 431 0.0 0.0 0 0 ? S 03:04 0:00 [irq/237-vblk]
root 433 0.0 0.0 0 0 ? S 03:04 0:00 [irq/229-bpmp_ir]
root 434 0.1 0.0 0 0 ? I 03:04 0:01 [kworker/u24:4-events_unbound]
root 435 0.0 0.0 0 0 ? S 03:04 0:00 [irq/230-bpmp_ir]
root 436 0.0 0.0 0 0 ? S 03:04 0:00 [irq/231-bpmp_ir]
root 438 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/9:3-mm_percpu_wq]
root 440 0.0 0.0 0 0 ? S 03:04 0:00 [irq/204-c1e0000]
root 441 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 443 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 445 0.0 0.0 0 0 ? S 03:04 0:00 [irq/94-c240000.]
root 446 0.0 0.0 0 0 ? S 03:04 0:00 [irq/104-gpcdma.]
root 447 0.0 0.0 0 0 ? S 03:04 0:00 [irq/105-gpcdma.]
root 449 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 450 0.0 0.0 0 0 ? S 03:04 0:00 [irq/96-3190000.]
root 451 0.0 0.0 0 0 ? S 03:04 0:00 [irq/108-gpcdma.]
root 452 0.0 0.0 0 0 ? S 03:04 0:00 [irq/109-gpcdma.]
root 453 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 454 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/3:2-events]
root 455 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 456 0.0 0.0 0 0 ? S 03:04 0:00 [irq/97-31b0000.]
root 457 0.0 0.0 0 0 ? S 03:04 0:00 [irq/110-gpcdma.]
root 458 0.0 0.0 0 0 ? S 03:04 0:00 [irq/111-gpcdma.]
root 459 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 461 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 462 0.0 0.0 0 0 ? S 03:04 0:00 [irq/98-31c0000.]
root 463 0.0 0.0 0 0 ? S 03:04 0:00 [irq/112-gpcdma.]
root 464 0.0 0.0 0 0 ? S 03:04 0:00 [irq/113-gpcdma.]
root 465 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 466 0.0 0.0 0 0 ? S 03:04 0:00 [irq/99-c250000.]
root 467 0.0 0.0 0 0 ? S 03:04 0:00 [irq/114-gpcdma.]
root 468 0.0 0.0 0 0 ? S 03:04 0:00 [irq/115-gpcdma.]
root 469 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 470 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 471 0.0 0.0 0 0 ? S 03:04 0:00 [irq/100-31e0000]
root 472 0.0 0.0 0 0 ? S 03:04 0:00 [irq/116-gpcdma.]
root 473 0.0 0.0 0 0 ? S 03:04 0:00 [irq/117-gpcdma.]
root 475 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/6:4-events]
root 476 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 479 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 487 0.0 0.0 0 0 ? S 03:04 0:00 [irq/93-3160000.]
root 488 0.0 0.0 0 0 ? S 03:04 0:00 [irq/102-gpcdma.]
root 490 0.0 0.0 0 0 ? S 03:04 0:00 [irq/103-gpcdma.]
root 492 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 493 0.0 0.0 0 0 ? S 03:04 0:00 [irq/95-3180000.]
root 494 0.0 0.0 0 0 ? S 03:04 0:00 [irq/106-gpcdma.]
root 495 0.0 0.0 0 0 ? S 03:04 0:00 [irq/107-gpcdma.]
root 496 0.0 0.0 0 0 ? I< 03:04 0:00 [nvme-wq]
root 497 0.0 0.0 0 0 ? I< 03:04 0:00 [nvme-reset-wq]
root 498 0.0 0.0 0 0 ? I< 03:04 0:00 [nvme-delete-wq]
root 500 0.0 0.0 0 0 ? S 03:04 0:00 [irq/18-arm-smmu]
root 504 0.5 0.0 0 0 ? S 03:04 0:04 [irq/210-xhci-hc]
root 505 0.0 0.0 0 0 ? S 03:04 0:00 [irq/211-3610000]
root 506 0.0 0.0 0 0 ? S 03:04 0:00 [irq/211-s-36100]
root 507 0.0 0.0 0 0 ? S 03:04 0:00 [irq/208-3610000]
root 508 0.0 0.0 0 0 ? S 03:04 0:00 [irq/57-mgbe0_0.]
root 509 0.0 0.0 0 0 ? S 03:04 0:00 [irq/58-mgbe0_0.]
root 510 0.0 0.0 0 0 ? S 03:04 0:00 [irq/59-mgbe0_0.]
root 511 0.0 0.0 0 0 ? S 03:04 0:00 [irq/60-mgbe0_0.]
root 512 0.0 0.0 0 0 ? S 03:04 0:00 [irq/61-mgbe0_0.]
root 513 0.0 0.0 0 0 ? S 03:04 0:00 [irq/62-mgbe0_0.]
root 519 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/1:1H-kblockd]
root 520 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/5:1H-kblockd]
root 521 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/2:1H-kblockd]
root 522 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/4:1H-kblockd]
root 523 0.0 0.0 0 0 ? S 03:04 0:00 [jbd2/vblkdev0p1]
root 524 0.0 0.0 0 0 ? I< 03:04 0:00 [ext4-rsv-conver]
root 526 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/10:1H-kblockd]
root 535 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/8:1H-kblockd]
root 536 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/6:1H-kblockd]
root 537 0.0 0.0 0 0 ? I< 03:04 0:00 [mld]
root 538 0.0 0.0 0 0 ? I< 03:04 0:00 [ipv6_addrconf]
root 539 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/9:1H-kblockd]
root 557 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/11:1H-kblockd]
root 582 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/7:2-mm_percpu_wq]
root 586 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/10:2-events]
root 589 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 590 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 591 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 592 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 593 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 594 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 595 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 596 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 597 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 598 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 599 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 600 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 601 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 602 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 603 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 604 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 605 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 606 0.5 0.0 0 0 ? S 03:04 0:05 [irq/138-host1x_]
root 616 0.0 0.0 19516 5436 ? Ss 03:04 0:00 /lib/systemd/systemd-udevd
root 621 0.0 0.0 5888 3492 ? Ss 03:04 0:00 /bin/bash /etc/systemd/scripts/nv_timesync.sh save 10
root 625 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 626 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 627 0.0 0.0 0 0 ? S 03:04 0:00 [irq/247-vse]
root 628 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 629 0.0 0.0 0 0 ? S 03:04 0:00 [irq/256-vse]
root 631 0.1 0.0 62008 26288 ? S<s 03:04 0:01 /lib/systemd/systemd-journald
root 632 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 633 0.0 0.0 0 0 ? S 03:04 0:00 [irq/257-vse]
root 637 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 638 0.0 0.0 0 0 ? S 03:04 0:00 [irq/258-vse]
root 643 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 644 0.0 0.0 0 0 ? S 03:04 0:00 [irq/259-vse]
root 645 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 646 0.0 0.0 0 0 ? S 03:04 0:00 [irq/260-vse]
root 647 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 649 0.0 0.0 0 0 ? S 03:04 0:00 [irq/261-vse]
root 651 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 652 0.0 0.0 0 0 ? S 03:04 0:00 [irq/262-vse]
root 655 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 656 0.0 0.0 0 0 ? S 03:04 0:00 [irq/263-vse]
root 657 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 658 0.0 0.0 0 0 ? S 03:04 0:00 [irq/264-vse]
root 662 0.0 0.0 0 0 ? S 03:04 0:00 [hwrng]
root 663 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 664 0.0 0.0 0 0 ? S 03:04 0:00 [irq/248-vse]
root 665 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 666 0.0 0.0 0 0 ? S 03:04 0:00 [irq/251-vse]
root 668 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 670 0.0 0.0 0 0 ? S 03:04 0:00 [irq/252-vse]
root 673 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 674 0.0 0.0 0 0 ? S 03:04 0:00 [irq/253-vse]
root 675 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/7:1H-kblockd]
root 676 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 677 0.0 0.0 0 0 ? S 03:04 0:00 [irq/254-vse]
root 678 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 679 0.0 0.0 0 0 ? S 03:04 0:00 [irq/255-vse]
root 680 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 681 0.0 0.0 0 0 ? S 03:04 0:00 [irq/268-vse]
root 686 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 687 0.0 0.0 0 0 ? S 03:04 0:00 [irq/246-vse]
root 698 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 699 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 700 0.0 0.0 0 0 ? S 03:04 0:00 [irq/249-vse]
root 702 0.0 0.0 0 0 ? S 03:04 0:00 [tegra_vse_kthre]
root 703 0.0 0.0 0 0 ? S 03:04 0:00 [irq/250-vse]
root 705 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 706 0.1 0.0 0 0 ? SN 03:04 0:00 [nvmap-bz]
root 711 0.0 0.0 0 0 ? S 03:04 0:00 [irq/212-gk20a_s]
root 712 0.0 0.0 0 0 ? S 03:04 0:00 [irq/212-s-gk20a]
root 713 0.0 0.0 0 0 ? S 03:04 0:00 [irq/213-gk20a_s]
root 714 0.0 0.0 0 0 ? S 03:04 0:00 [irq/213-s-gk20a]
root 715 0.0 0.0 0 0 ? S 03:04 0:00 [irq/214-gk20a_s]
root 716 0.0 0.0 0 0 ? S 03:04 0:00 [irq/214-s-gk20a]
root 717 0.0 0.0 0 0 ? S 03:04 0:00 [irq/215-gk20a_n]
root 718 0.0 0.0 0 0 ? S 03:04 0:00 [irq/215-s-gk20a]
root 719 0.0 0.0 0 0 ? S 03:04 0:00 [scsi_eh_0]
root 720 0.0 0.0 0 0 ? I< 03:04 0:00 [scsi_tmf_0]
root 721 0.0 0.0 0 0 ? S 03:04 0:00 [usb-storage]
root 723 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/5:2-events]
root 740 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 744 0.0 0.0 0 0 ? S 03:04 0:00 [irq/136-bc00000]
root 748 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/11:2-mm_percpu_wq]
root 771 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 772 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 773 0.0 0.0 0 0 ? S 03:04 0:00 [irq/344-1588000]
root 774 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 775 0.0 0.0 0 0 ? S 03:04 0:00 [irq/345-158c000]
root 777 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 778 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 779 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 780 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 781 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 782 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 783 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 784 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 785 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 786 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 787 0.0 0.0 0 0 ? S 03:04 0:00 [capture-control]
root 788 0.0 0.0 0 0 ? S 03:04 0:00 [capture]
root 789 0.0 0.0 0 0 ? I< 03:04 0:00 [pva_task_status]
root 790 0.0 0.0 0 0 ? S 03:04 0:00 [irq/335-pva-isr]
root 791 0.0 0.0 0 0 ? S 03:04 0:00 [irq/336-pva-isr]
root 793 0.0 0.0 0 0 ? S 03:04 0:00 [irq/337-pva-isr]
root 794 0.0 0.0 0 0 ? S 03:04 0:00 [irq/338-pva-isr]
root 795 0.0 0.0 0 0 ? S 03:04 0:00 [irq/339-pva-isr]
root 796 0.0 0.0 0 0 ? S 03:04 0:00 [irq/340-pva-isr]
root 797 0.0 0.0 0 0 ? S 03:04 0:00 [irq/341-pva-isr]
root 798 0.0 0.0 0 0 ? S 03:04 0:00 [irq/342-pva-isr]
root 799 0.0 0.0 0 0 ? S 03:04 0:00 [irq/343-pva-isr]
root 805 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 806 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 807 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 811 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 812 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 813 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 816 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/5:3-events]
root 835 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 837 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 838 0.0 0.0 0 0 ? S 03:04 0:00 [irq/209-3550000]
root 839 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/8:2-cgroup_destroy]
root 840 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 841 0.0 0.0 0 0 ? S 03:04 0:00 [irq/122-gpcdma.]
root 842 0.0 0.0 0 0 ? S 03:04 0:00 [irq/123-gpcdma.]
root 843 0.0 0.0 0 0 ? S 03:04 0:00 [irq/91-3210000.]
root 844 0.0 0.0 0 0 ? S 03:04 0:00 [spi0]
root 845 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 846 0.0 0.0 0 0 ? S 03:04 0:00 [irq/124-gpcdma.]
root 847 0.0 0.0 0 0 ? S 03:04 0:00 [irq/125-gpcdma.]
root 849 0.0 0.0 0 0 ? S 03:04 0:00 [irq/92-c260000.]
root 851 0.0 0.0 0 0 ? S 03:04 0:00 [spi1]
root 853 0.0 0.0 0 0 ? S 03:04 0:00 [irq/205-2190000]
root 861 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 862 0.0 0.0 0 0 ? S 03:04 0:00 [irq/219-tegra_d]
root 863 0.0 0.0 0 0 ? S 03:04 0:00 [irq/220-tegra_d]
root 864 0.0 0.0 0 0 ? I< 03:04 0:00 [dce-async-ipc-w]
root 865 0.0 0.0 0 0 ? I< 03:04 0:00 [kworker/8:2H]
root 875 0.0 0.0 0 0 ? S 03:04 0:00 [nv_queue]
root 876 0.0 0.0 0 0 ? S 03:04 0:00 [nv_queue]
root 877 0.0 0.0 0 0 ? S 03:04 0:00 [irq/19-tegra-p2]
root 878 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 879 0.0 0.0 0 0 ? S 03:04 0:00 [irq/20-tegra-p2]
root 880 0.0 0.0 0 0 ? S 03:04 0:00 [irq/21-tegra-p2]
root 881 0.0 0.0 0 0 ? S 03:04 0:00 [irq/22-tegra-p2]
root 882 0.0 0.0 0 0 ? S 03:04 0:00 [irq/23-tegra-p2]
root 883 0.0 0.0 0 0 ? S 03:04 0:00 [irq/24-tegra-p2]
root 884 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 885 0.0 0.0 0 0 ? S 03:04 0:00 [irq/25-tegra-p2]
root 886 0.0 0.0 0 0 ? S 03:04 0:00 [irq/26-tegra-p2]
root 887 0.0 0.0 0 0 ? S 03:04 0:00 [irq/27-tegra-p2]
root 888 0.0 0.0 0 0 ? S 03:04 0:00 [irq/28-tegra-p2]
root 889 0.0 0.0 0 0 ? S 03:04 0:00 [irq/44-tegra-pc]
root 890 0.0 0.0 0 0 ? S 03:04 0:00 [irq/44-s-tegra-]
root 891 0.0 0.0 0 0 ? S 03:04 0:00 [irq/29-tegra-p2]
root 892 0.0 0.0 0 0 ? S 03:04 0:00 [irq/30-tegra-p2]
root 893 0.0 0.0 0 0 ? S 03:04 0:00 [irq/31-tegra-p2]
root 894 0.0 0.0 0 0 ? S 03:04 0:00 [irq/32-tegra-p2]
root 895 0.0 0.0 0 0 ? S 03:04 0:00 [irq/33-tegra-p2]
root 896 0.0 0.0 0 0 ? S 03:04 0:00 [irq/34-tegra-p2]
root 897 0.0 0.0 0 0 ? S 03:04 0:00 [irq/35-tegra-p2]
root 898 0.0 0.0 0 0 ? S 03:04 0:00 [irq/36-tegra-p2]
root 899 0.0 0.0 0 0 ? S 03:04 0:00 [irq/37-tegra-p2]
root 900 0.0 0.0 0 0 ? S 03:04 0:00 [irq/38-tegra-p2]
root 901 0.0 0.0 0 0 ? S 03:04 0:00 [irq/39-tegra-p2]
root 902 0.0 0.0 0 0 ? S 03:04 0:00 [irq/40-tegra-p2]
root 903 0.0 0.0 0 0 ? S 03:04 0:00 [irq/41-tegra-p2]
root 904 0.0 0.0 0 0 ? S 03:04 0:00 [irq/42-tegra-p2]
root 905 0.0 0.0 0 0 ? S 03:04 0:00 [irq/363-lm90]
root 906 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 907 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 908 0.0 0.0 0 0 ? S 03:04 0:00 [irq/228-tegra_h]
root 909 0.0 0.0 0 0 ? S 03:04 0:00 [irq/364-sipl_de]
root 910 0.0 0.0 0 0 ? S 03:04 0:00 [irq/365-sipl_de]
root 911 0.0 0.0 0 0 ? S 03:04 0:00 [irq/366-sipl_de]
root 912 0.0 0.0 0 0 ? S 03:04 0:00 [irq/367-sipl_de]
root 913 0.0 0.0 0 0 ? S 03:04 0:00 [irq/224-tegra_h]
root 914 0.0 0.0 0 0 ? S 03:04 0:00 [irq/368-sipl_de]
root 915 0.0 0.0 0 0 ? S 03:04 0:00 [irq/369-sipl_de]
root 916 0.0 0.0 0 0 ? S 03:04 0:00 [irq/370-sipl_de]
root 917 0.0 0.0 0 0 ? S 03:04 0:00 [irq/371-sipl_de]
root 918 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/1:3-events]
root 919 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 928 0.0 0.0 0 0 ? S 03:04 0:00 [irq/44-PCIe PME]
root 929 0.0 0.0 0 0 ? S 03:04 0:00 [irq/44-aerdrv]
root 930 0.0 0.0 0 0 ? S 03:04 0:00 [irq/44-s-aerdrv]
root 931 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 932 0.0 0.0 0 0 ? S 03:04 0:00 [irq/46-tegra-pc]
root 933 0.0 0.0 0 0 ? S 03:04 0:00 [irq/46-s-tegra-]
root 934 0.0 0.0 0 0 ? S 03:04 0:00 [irq/372-tegra_p]
root 935 0.0 0.0 0 0 ? S 03:04 0:00 [irq/17-arm-smmu]
root 936 0.0 0.0 0 0 ? S 03:04 0:00 [irq/48-tegra-pc]
root 937 0.0 0.0 0 0 ? S 03:04 0:00 [irq/48-s-tegra-]
root 944 0.0 0.0 0 0 ? S 03:04 0:00 [irq/48-PCIe PME]
root 945 0.0 0.0 0 0 ? S 03:04 0:00 [irq/48-aerdrv]
root 946 0.0 0.0 0 0 ? S 03:04 0:00 [irq/48-s-aerdrv]
root 968 0.0 0.0 0 0 ? S 03:04 0:00 [irq/15-arm-smmu]
root 969 0.0 0.0 0 0 ? S 03:04 0:00 [irq/43-tegra-pc]
root 970 0.0 0.0 0 0 ? S 03:04 0:00 [irq/43-s-tegra-]
root 971 0.0 0.0 0 0 ? S 03:04 0:00 [irq/373-tegra_p]
root 975 0.0 0.0 0 0 ? S 03:04 0:00 [irq/374-lan743x]
root 976 0.0 0.0 0 0 ? S 03:04 0:00 [irq/375-lan743x]
root 977 0.0 0.0 0 0 ? S 03:04 0:00 [irq/376-lan743x]
root 978 0.0 0.0 0 0 ? S 03:04 0:00 [irq/377-lan743x]
root 979 0.0 0.0 0 0 ? S 03:04 0:00 [irq/378-lan743x]
root 980 0.0 0.0 0 0 ? S 03:04 0:00 [irq/379-lan743x]
root 981 0.0 0.0 0 0 ? S 03:04 0:00 [ptp1]
_rpc 1020 0.0 0.0 7132 3224 ? Ss 03:04 0:00 /sbin/rpcbind -f -w
root 1022 0.0 0.0 238120 8476 ? Ssl 03:04 0:00 /usr/lib/accountsservice/accounts-daemon
message+ 1023 0.0 0.0 16152 4704 ? Ssl 03:04 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
syslog 1045 0.0 0.0 219956 3844 ? Ssl 03:04 0:00 /usr/sbin/rsyslogd -n -iNONE
root 1057 0.0 0.0 9736 5068 ? Ss 03:04 0:00 /usr/sbin/smartd -n -q never
root 1072 0.0 0.0 17112 7056 ? Ss 03:04 0:00 /lib/systemd/systemd-logind
root 1084 0.0 0.0 391664 12144 ? Ssl 03:04 0:00 /usr/lib/udisks2/udisksd
root 1087 0.0 0.0 0 0 ? S 03:04 0:00 [sw-quiesce]
root 1092 0.0 0.0 12400 4620 ? Ss 03:04 0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
root 1096 0.1 0.0 0 0 ? S 03:04 0:01 [nvgpu_channel_p]
root 1098 0.0 0.0 2060 524 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_fsicom_daemon.sh
root 1102 0.0 0.0 2060 584 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh crypto-asym-service
root 1103 0.0 0.0 2060 576 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh crypto-sym-service
root 1104 0.0 0.0 2060 464 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh gp-se
root 1105 0.0 0.0 0 0 ? S 03:04 0:00 [irq/73-mgbe2_0.]
root 1106 0.0 0.0 0 0 ? S 03:04 0:00 [irq/74-mgbe2_0.]
root 1107 0.0 0.0 0 0 ? S 03:04 0:00 [irq/75-mgbe2_0.]
root 1112 0.0 0.0 0 0 ? S 03:04 0:00 [irq/76-mgbe2_0.]
root 1115 0.0 0.0 0 0 ? S 03:04 0:00 [irq/77-mgbe2_0.]
root 1117 0.0 0.0 0 0 ? S 03:04 0:00 [irq/78-mgbe2_0.]
root 1118 0.0 0.0 2060 492 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh nvmacsec
nvidia 1120 0.0 0.0 11504 1744 ? Sl 03:04 0:00 /usr/local/bin/NvFsiCom
root 1126 0.0 0.0 2060 464 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk1
root 1128 0.0 0.0 2060 476 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk10
root 1130 0.0 0.0 2060 484 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk11
root 1132 0.0 0.0 2060 580 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk12
root 1138 0.0 0.0 2060 584 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk13
root 1144 0.0 0.0 2060 476 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk14
root 1148 0.0 0.0 2060 480 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk15
root 1151 0.0 0.0 2060 472 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk16
root 1154 0.0 0.0 2060 468 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk17
root 1157 0.0 0.0 8724 3492 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta nvmacsec
root 1159 0.0 0.0 2060 520 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk18
root 1164 0.0 0.0 2060 584 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk19
root 1166 0.0 0.0 8724 3428 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta gp-se
root 1169 0.0 0.0 2060 580 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta nvmacsec
root 1170 0.0 0.0 2060 472 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk2
nvidia 1172 0.0 0.0 80736 1644 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta nvmacsec
root 1174 0.0 0.0 8724 3464 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk11
root 1175 0.0 0.0 2060 584 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk20
root 1178 0.0 0.0 2060 504 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta gp-se
nvidia 1179 0.0 0.0 80736 1636 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta gp-se
root 1183 0.0 0.0 8724 3500 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk1
root 1184 0.0 0.0 2060 504 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk21
root 1187 0.0 0.0 2060 468 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk22
root 1188 0.0 0.0 0 0 ? S 03:04 0:00 [irq/301-ivc530]
root 1189 0.0 0.0 0 0 ? S 03:04 0:00 [irq/301-s-ivc53]
root 1190 0.0 0.0 0 0 ? S 03:04 0:00 [irq/299-ivc521]
root 1191 0.0 0.0 2060 460 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk11
root 1194 0.0 0.0 2060 468 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk1
root 1195 0.0 0.0 0 0 ? S 03:04 0:00 [irq/299-s-ivc52]
nvidia 1196 0.0 0.0 80736 1644 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk11
root 1199 0.0 0.0 8724 3432 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta crypto-asym-service
nvidia 1202 0.0 0.0 80736 1636 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk1
root 1203 0.0 0.0 0 0 ? S 03:04 0:00 [irq/312-ivc139]
root 1204 0.0 0.0 0 0 ? S 03:04 0:00 [irq/312-s-ivc13]
root 1205 0.0 0.0 2060 468 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk23
root 1208 0.0 0.0 0 0 ? S 03:04 0:00 [irq/302-ivc129]
root 1209 0.0 0.0 0 0 ? S 03:04 0:00 [irq/302-s-ivc12]
root 1211 0.0 0.0 2060 468 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk24
root 1213 0.0 0.0 2060 468 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta crypto-asym-service
root 1215 0.0 0.0 8724 3440 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk10
nvidia 1217 0.0 0.0 80752 1576 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta crypto-asym-service
root 1220 0.0 0.0 2060 580 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk25
root 1222 0.0 0.0 0 0 ? S 03:04 0:00 [irq/295-ivc522]
root 1223 0.0 0.0 0 0 ? S 03:04 0:00 [irq/295-s-ivc52]
root 1226 0.0 0.0 2060 504 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk26
root 1227 0.0 0.0 8724 3492 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta crypto-sym-service
root 1228 0.0 0.0 2060 580 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk10
root 1230 0.0 0.0 0 0 ? S 03:04 0:00 [nvidia-modeset/]
root 1231 0.0 0.0 0 0 ? S 03:04 0:00 [nvidia-modeset/]
nvidia 1234 0.0 0.0 80736 1584 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk10
root 1235 0.0 0.0 2060 580 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk27
root 1237 0.0 0.0 8724 3520 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk25
root 1239 0.0 0.0 0 0 ? S 03:04 0:00 [irq/311-ivc138]
root 1240 0.0 0.0 0 0 ? S 03:04 0:00 [irq/311-s-ivc13]
root 1241 0.0 0.0 2060 500 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk28
root 1245 0.0 0.0 2060 500 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta crypto-sym-service
nvidia 1246 0.0 0.0 80736 1640 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta crypto-sym-service
root 1247 0.0 0.0 2060 468 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk29
root 1250 0.0 0.0 8724 3432 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk12
root 1251 0.0 0.0 0 0 ? S 03:04 0:00 [irq/297-ivc523]
root 1253 0.0 0.0 0 0 ? S 03:04 0:00 [irq/297-s-ivc52]
root 1254 0.0 0.0 2060 468 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk25
root 1255 0.0 0.0 2060 476 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk3
root 1259 0.0 0.0 8724 3472 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk13
nvidia 1261 0.0 0.0 80736 1644 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk25
root 1265 0.0 0.0 0 0 ? S 03:04 0:00 [irq/326-ivc153]
root 1266 0.0 0.0 2060 476 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk12
root 1267 0.0 0.0 2060 472 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk30
root 1268 0.0 0.0 0 0 ? S 03:04 0:00 [irq/326-s-ivc15]
root 1271 0.0 0.0 8724 3452 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk14
nvidia 1273 0.0 0.0 80736 1584 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk12
root 1275 0.0 0.0 2060 468 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk31
root 1277 0.0 0.0 2060 520 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk13
root 1278 0.0 0.0 0 0 ? S 03:04 0:00 [irq/313-ivc140]
root 1279 0.0 0.0 0 0 ? S 03:04 0:00 [irq/313-s-ivc14]
nvidia 1280 0.0 0.0 80736 1580 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk13
root 1282 0.0 0.0 8724 3460 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk15
root 1285 0.0 0.0 2060 580 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk32
root 1286 0.0 0.0 0 0 ? S 03:04 0:00 [irq/314-ivc141]
root 1287 0.0 0.0 0 0 ? S 03:04 0:00 [irq/314-s-ivc14]
root 1289 0.0 0.0 2060 584 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk14
nvidia 1291 0.0 0.0 80736 1604 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk14
root 1294 0.0 0.0 8724 3400 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk16
root 1295 0.0 0.0 2060 496 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk33
root 1296 0.0 0.0 0 0 ? S 03:04 0:00 [irq/315-ivc142]
root 1297 0.0 0.0 0 0 ? S 03:04 0:00 [irq/315-s-ivc14]
root 1298 0.0 0.0 2060 500 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk15
nvidia 1302 0.0 0.0 80736 1640 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk15
root 1303 0.0 0.0 2060 484 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk4
root 1305 0.0 0.0 8724 3460 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk17
root 1306 0.0 0.0 0 0 ? S 03:04 0:00 [irq/316-ivc143]
root 1307 0.0 0.0 0 0 ? S 03:04 0:00 [irq/316-s-ivc14]
root 1308 0.0 0.0 2060 484 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk16
root 1311 0.0 0.0 2060 464 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk5
nvidia 1313 0.0 0.0 80736 1644 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk16
root 1314 0.0 0.0 0 0 ? S 03:04 0:00 [irq/317-ivc144]
root 1315 0.0 0.0 0 0 ? S 03:04 0:00 [irq/317-s-ivc14]
root 1318 0.0 0.0 8724 3496 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk18
root 1320 0.0 0.0 2060 468 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk6
root 1322 0.0 0.0 2060 580 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk17
nvidia 1323 0.0 0.0 80736 1584 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk17
root 1325 0.0 0.0 8724 3400 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk19
root 1327 0.0 0.0 2060 504 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk7
root 1328 0.0 0.0 0 0 ? S 03:04 0:00 [irq/318-ivc145]
root 1329 0.0 0.0 0 0 ? S 03:04 0:00 [irq/318-s-ivc14]
root 1331 0.0 0.0 2060 464 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk18
root 1334 0.0 0.0 8724 3488 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk2
root 1335 0.0 0.0 2060 496 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk8
nvidia 1336 0.0 0.0 80736 1572 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk18
root 1339 0.0 0.0 2060 492 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk19
root 1340 0.0 0.0 0 0 ? S 03:04 0:00 [irq/319-ivc146]
root 1341 0.0 0.0 0 0 ? S 03:04 0:00 [irq/319-s-ivc14]
root 1344 0.0 0.0 2060 524 ? Ss 03:04 0:00 /bin/sh /etc/systemd/scripts/nv_tzvault_daemon.sh pkcs11-keystore-tk9
root 1346 0.0 0.0 8724 3476 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk20
nvidia 1347 0.0 0.0 80736 1632 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk19
root 1349 0.0 0.0 2060 500 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk2
nvidia 1352 0.0 0.0 80736 1572 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk2
root 1354 0.0 0.0 8724 3484 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk22
root 1355 0.0 0.0 0 0 ? S 03:04 0:00 [irq/320-ivc147]
root 1356 0.0 0.0 0 0 ? S 03:04 0:00 [irq/320-s-ivc14]
root 1358 0.0 0.0 0 0 ? S 03:04 0:00 [irq/303-ivc130]
root 1359 0.0 0.0 0 0 ? S 03:04 0:00 [irq/303-s-ivc13]
root 1362 1.0 0.0 159256 1904 ? Sl 03:04 0:09 /usr/local/bin/nvlogclient_fast /home/nvidia/nvlog_system_log.txt
root 1363 0.0 0.0 0 0 ? S 03:04 0:00 [nvgpu_clk_arb_p]
root 1365 0.0 0.0 2060 472 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk20
root 1367 0.0 0.0 8724 3436 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk9
root 1368 0.0 0.0 2060 524 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk22
nvidia 1371 0.0 0.0 80736 1584 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk20
nvidia 1372 0.0 0.0 80736 1584 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk22
root 1375 0.0 0.0 0 0 ? S 03:04 0:00 [irq/321-ivc148]
root 1376 0.0 0.0 0 0 ? S 03:04 0:00 [irq/321-s-ivc14]
root 1377 0.0 0.0 0 0 ? S 03:04 0:00 [irq/323-ivc150]
root 1378 0.0 0.0 0 0 ? S 03:04 0:00 [irq/323-s-ivc15]
root 1380 0.0 0.0 8724 3400 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk21
root 1385 0.0 0.0 2060 460 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk9
nvidia 1386 0.0 0.0 80736 1696 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk9
root 1388 0.0 0.0 8724 3468 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk23
root 1389 0.0 0.0 0 0 ? S 03:04 0:00 [irq/310-ivc137]
root 1390 0.0 0.0 2060 468 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk21
root 1391 0.0 0.0 0 0 ? S 03:04 0:00 [irq/310-s-ivc13]
nvidia 1393 0.0 0.0 80736 1580 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk21
root 1395 0.0 0.0 0 0 ? S 03:04 0:00 [irq/238-ivc228]
root 1396 0.0 0.0 0 0 ? S 03:04 0:00 [irq/238-s-ivc22]
root 1398 0.0 0.0 0 0 ? S 03:04 0:00 [irq/322-ivc149]
root 1399 0.0 0.0 0 0 ? S 03:04 0:00 [irq/322-s-ivc14]
root 1402 0.0 0.0 8724 3504 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk24
root 1404 0.0 0.0 2060 504 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk23
nvidia 1406 0.0 0.0 80736 1656 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk23
root 1408 0.0 0.0 8724 3516 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk26
root 1409 0.0 0.0 0 0 ? S 03:04 0:00 [irq/324-ivc151]
root 1410 0.0 0.0 0 0 ? S 03:04 0:00 [irq/324-s-ivc15]
root 1411 0.0 0.0 2060 472 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk24
nvidia 1415 0.0 0.0 80736 1584 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk24
root 1416 0.0 0.0 0 0 ? S 03:04 0:00 [irq/325-ivc152]
root 1417 0.0 0.0 0 0 ? S 03:04 0:00 [irq/325-s-ivc15]
root 1419 0.0 0.0 8724 3488 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk27
root 1420 0.0 0.0 2060 584 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk26
nvidia 1424 0.0 0.0 80736 1584 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk26
root 1425 0.0 0.0 0 0 ? S 03:04 0:00 [irq/327-ivc154]
root 1426 0.0 0.0 0 0 ? S 03:04 0:00 [irq/327-s-ivc15]
root 1427 0.0 0.0 8724 3476 ? S 03:04 0:00 sudo -u #1000 -g #100 dulink_router
root 1428 0.0 0.0 8724 3352 ? S 03:04 0:00 sudo -u #1000 -g #100 dubhc_plugin
root 1429 0.0 0.0 8724 3372 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk28
root 1430 0.0 0.0 8724 3456 ? S 03:04 0:00 sudo -u #1000 -g #100 MCC_LOCATION=/usr/lib/libdu_mcc.so bootmgr
root 1432 0.0 0.0 8724 3440 ? S 03:04 0:00 sudo -u #1000 -g #100 du_decomp
root 1435 0.0 0.0 2060 500 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk27
systemd+ 1436 0.0 0.0 27052 6720 ? Ss 03:04 0:00 /lib/systemd/systemd-networkd
nvidia 1437 0.0 0.0 80736 1676 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk27
root 1439 0.0 0.0 8724 3468 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk29
root 1441 0.0 0.0 0 0 ? S 03:04 0:00 [irq/328-ivc155]
root 1442 0.0 0.0 0 0 ? S 03:04 0:00 [irq/328-s-ivc15]
root 1443 0.0 0.0 2060 500 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk28
nvidia 1444 0.0 0.0 629140 9748 ? Sl 03:04 0:00 dulink_router
nvidia 1446 0.0 0.0 148716 5424 ? Sl 03:04 0:00 dubhc_plugin
nvidia 1447 0.0 0.0 149012 5592 ? Sl 03:04 0:00 bootmgr
nvidia 1449 0.0 0.0 80736 1656 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk28
root 1450 0.0 0.0 2060 524 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk29
root 1451 0.0 0.0 0 0 ? S 03:04 0:00 [irq/329-ivc156]
root 1452 0.0 0.0 0 0 ? S 03:04 0:00 [irq/329-s-ivc15]
nvidia 1453 0.0 0.0 151772 5648 ? Sl 03:04 0:00 du_decomp
nvidia 1455 0.0 0.0 80736 1676 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk29
root 1457 0.0 0.0 8724 3468 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk3
root 1458 0.0 0.0 0 0 ? S 03:04 0:00 [irq/330-ivc157]
root 1459 0.0 0.0 0 0 ? S 03:04 0:00 [irq/330-s-ivc15]
root 1462 0.0 0.0 237468 9256 ? Ssl 03:04 0:00 /usr/lib/policykit-1/polkitd --no-debug
root 1464 0.0 0.0 8724 3400 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk30
root 1467 0.0 0.0 2060 496 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk3
root 1469 0.0 0.0 8724 3512 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk31
nvidia 1470 0.0 0.0 80736 1584 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk3
root 1472 0.0 0.0 2060 512 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk30
root 1474 0.0 0.0 0 0 ? S 03:04 0:00 [irq/304-ivc131]
root 1475 0.0 0.0 0 0 ? S 03:04 0:00 [irq/304-s-ivc13]
root 1478 0.0 0.0 8724 3440 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk32
nvidia 1479 0.0 0.0 80736 1648 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk30
root 1483 0.0 0.0 0 0 ? S 03:04 0:00 [irq/331-ivc158]
root 1484 0.0 0.0 0 0 ? S 03:04 0:00 [irq/331-s-ivc15]
root 1489 0.0 0.0 8724 3496 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk33
root 1492 0.0 0.0 2060 500 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk31
nvidia 1494 0.0 0.0 80736 1572 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk31
root 1496 0.0 0.0 8724 3488 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk4
root 1497 0.0 0.0 0 0 ? S 03:04 0:00 [irq/332-ivc159]
root 1498 0.0 0.0 0 0 ? S 03:04 0:00 [irq/332-s-ivc15]
root 1499 0.0 0.0 2060 492 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk32
root 1502 0.0 0.0 2060 584 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk33
nvidia 1503 0.0 0.0 80736 1692 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk32
nvidia 1504 0.0 0.0 80736 1580 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk33
root 1506 0.0 0.0 8724 3492 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk5
root 1523 0.0 0.0 0 0 ? S 03:04 0:00 [irq/333-ivc160]
root 1524 0.0 0.0 0 0 ? S 03:04 0:00 [irq/334-ivc161]
root 1525 0.0 0.0 0 0 ? S 03:04 0:00 [irq/226-ivc407]
root 1526 0.0 0.0 0 0 ? S 03:04 0:00 [irq/333-s-ivc16]
root 1527 0.0 0.0 0 0 ? S 03:04 0:00 [irq/226-s-ivc40]
root 1528 0.0 0.0 0 0 ? S 03:04 0:00 [irq/334-s-ivc16]
root 1532 0.0 0.0 2060 520 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk4
nvidia 1542 0.0 0.0 80736 1696 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk4
root 1558 0.0 0.0 0 0 ? S 03:04 0:00 [irq/305-ivc132]
root 1559 0.0 0.0 0 0 ? S 03:04 0:00 [irq/305-s-ivc13]
root 1562 0.0 0.0 8724 3432 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk6
root 1569 0.0 0.0 2060 468 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk5
nvidia 1571 0.0 0.0 80736 1580 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk5
root 1573 0.0 0.0 8724 3440 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk7
root 1574 0.0 0.0 0 0 ? S 03:04 0:00 [irq/306-ivc133]
root 1575 0.0 0.0 0 0 ? S 03:04 0:00 [irq/306-s-ivc13]
root 1578 0.0 0.0 2060 524 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk6
nvidia 1579 0.0 0.0 80736 1580 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk6
root 1580 0.0 0.0 8724 3440 ? S 03:04 0:00 sudo -u root -g tzvault /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk8
root 1582 0.0 0.0 0 0 ? S 03:04 0:00 [irq/307-ivc134]
root 1584 0.0 0.0 0 0 ? S 03:04 0:00 [irq/307-s-ivc13]
root 1586 0.0 0.0 2060 492 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk7
nvidia 1587 0.0 0.0 80736 1620 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk7
root 1591 0.0 0.0 0 0 ? S 03:04 0:00 [irq/308-ivc135]
root 1592 0.0 0.0 0 0 ? S 03:04 0:00 [irq/308-s-ivc13]
root 1593 0.0 0.0 3732 468 ? S 03:04 0:00 tail -f -n +1 /var/log/syslog
root 1594 0.0 0.0 2060 504 ? S 03:04 0:00 /bin/sh -c umask 0002; /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk8
root 1595 0.0 0.0 3088 788 ? S 03:04 0:00 nvlogtest_stdin
nvidia 1597 0.0 0.0 80736 1636 ? Sl 03:04 0:00 /usr/local/sbin/nvtzvault -ta pkcs11-keystore-tk8
root 1599 0.0 0.0 0 0 ? S 03:04 0:00 [irq/309-ivc136]
root 1601 0.0 0.0 0 0 ? S 03:04 0:00 [irq/309-s-ivc13]
root 1613 0.0 0.0 5372 2732 ? Ss 03:04 0:00 /bin/bash /etc/systemd/scripts/nv_fanctrl_orin.sh
systemd+ 1617 0.0 0.0 24652 11188 ? Ss 03:04 0:00 /lib/systemd/systemd-resolved
root 1618 0.0 0.0 8720 3464 ? S 03:04 0:00 sudo /usr/bin/fanctrl_orin -i 10.42.0.28 -s 10.42.0.146
root 1628 0.0 0.0 2136 508 ? S 03:04 0:00 /usr/bin/fanctrl_orin -i 10.42.0.28 -s 10.42.0.146
root 1647 0.0 0.0 0 0 ? S 03:04 0:00 [irq/81-mgbe3_0.]
root 1648 0.0 0.0 0 0 ? S 03:04 0:00 [irq/82-mgbe3_0.]
root 1649 0.0 0.0 0 0 ? S 03:04 0:00 [irq/83-mgbe3_0.]
root 1650 0.0 0.0 0 0 ? S 03:04 0:00 [irq/84-mgbe3_0.]
root 1651 0.0 0.0 0 0 ? S 03:04 0:00 [irq/85-mgbe3_0.]
root 1652 0.0 0.0 0 0 ? S 03:04 0:00 [irq/86-mgbe3_0.]
root 1660 0.0 0.0 0 0 ? S 03:04 0:00 [irq/65-mgbe1_0.]
root 1661 0.0 0.0 0 0 ? S 03:04 0:00 [irq/66-mgbe1_0.]
root 1662 0.0 0.0 0 0 ? S 03:04 0:00 [irq/67-mgbe1_0.]
root 1663 0.0 0.0 0 0 ? S 03:04 0:00 [irq/68-mgbe1_0.]
root 1664 0.0 0.0 0 0 ? S 03:04 0:00 [irq/69-mgbe1_0.]
root 1665 0.0 0.0 0 0 ? S 03:04 0:00 [irq/70-mgbe1_0.]
root 1667 0.0 0.0 0 0 ? S 03:04 0:00 [irq/50-eqos_0.c]
root 1668 0.1 0.0 0 0 ? S 03:04 0:01 [irq/51-eqos_0.v]
root 1669 0.0 0.0 0 0 ? S 03:04 0:00 [irq/52-eqos_0.v]
root 1670 0.0 0.0 0 0 ? S 03:04 0:00 [irq/53-eqos_0.v]
root 1671 0.0 0.0 0 0 ? S 03:04 0:00 [irq/54-eqos_0.v]
root 1678 0.0 0.0 153740 3276 ? Ssl 03:04 0:00 /usr/bin/mcc_daemon
root 1684 0.1 0.1 2149200 35336 ? Ssl 03:04 0:01 /usr/bin/containerd
root 1689 0.0 0.0 3872 1812 ttyS2 Ss+ 03:04 0:00 /sbin/agetty -o -p -- \u --keep-baud 115200,38400,9600 ttyS2 vt220
ntp 1690 0.0 0.0 73380 3028 ? Ssl 03:04 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 114:123
root 1694 0.0 0.0 236352 7672 ? Ssl 03:04 0:00 /usr/sbin/gdm3
root 1695 0.0 0.0 12220 6408 ? Ss 03:04 0:00 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
root 1726 0.0 0.0 0 0 ? I 03:04 0:00 [kworker/4:2-events]
gdm 1728 0.0 0.0 18724 8844 ? Ss 03:04 0:00 /lib/systemd/systemd --user
gdm 1729 0.0 0.0 169956 3144 ? S 03:04 0:00 (sd-pam)
gdm 1748 0.0 0.0 983288 22276 ? SNsl 03:04 0:00 /usr/libexec/tracker-miner-fs
gdm 1751 0.0 0.0 15096 3780 ? Ssl 03:04 0:00 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
gdm 1762 0.0 0.0 236016 6660 ? Ssl 03:04 0:00 /usr/libexec/gvfsd
gdm 1770 0.0 0.0 387280 11316 ? Ssl 03:04 0:00 /usr/libexec/gvfs-udisks2-volume-monitor
root 1818 0.0 0.0 164172 7896 ? Sl 03:04 0:00 gdm-session-worker [pam/gdm-launch-environment]
gdm 1823 0.0 0.0 160340 5888 tty1 Ssl+ 03:04 0:00 /usr/lib/gdm3/gdm-x-session dbus-run-session -- gnome-session --autostart /usr/share/gdm/greeter/autostart
root 1825 0.0 0.1 25317744 36764 tty1 Sl+ 03:04 0:00 /usr/lib/xorg/Xorg vt1 -displayfd 3 -auth /run/user/110/gdm/Xauthority -background none -noreset -keeptty -verbose 3
root 1826 0.0 0.0 0 0 ? S 03:04 0:00 [nvidia]
root 1827 0.0 0.0 0 0 ? S 03:04 0:00 [nv_queue]
gdm 1833 0.0 0.0 4776 1164 tty1 S+ 03:04 0:00 dbus-run-session -- gnome-session --autostart /usr/share/gdm/greeter/autostart
gdm 1834 0.0 0.0 15312 3824 tty1 Sl+ 03:04 0:00 dbus-daemon --nofork --print-address 4 --session
gdm 1835 0.0 0.0 482140 14444 tty1 Sl+ 03:04 0:00 /usr/libexec/gnome-session-binary --systemd --autostart /usr/share/gdm/greeter/autostart
root 1839 0.0 0.0 5224 2180 ? Ss 03:04 0:00 /sbin/mount.ntfs-3g /dev/sda1 /media/sda1_Elements -o rw,nosuid,nodev,sync,noatime,noexec,uid=0,gid=0,umask=000,fmask=0111,dmask=0000,user
gdm 1860 0.3 0.4 3577764 137844 tty1 Sl+ 03:04 0:02 /usr/bin/gnome-shell
gdm 1881 0.0 0.0 2924072 24252 tty1 Sl+ 03:04 0:00 /usr/bin/gjs /usr/share/gnome-shell/org.gnome.Shell.Notifications
gdm 1894 0.0 0.0 420140 19212 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-color
gdm 1895 0.0 0.0 244968 9368 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-print-notifications
gdm 1897 0.0 0.0 309812 7940 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-a11y-settings
gdm 1898 0.0 0.0 409456 18156 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-power
gdm 1899 0.0 0.0 479092 19284 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-media-keys
gdm 1900 0.0 0.0 454348 5836 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-rfkill
gdm 1902 0.0 0.0 334152 17432 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-keyboard
gdm 1904 0.0 0.0 257016 13932 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-wacom
gdm 1906 0.0 0.0 310160 7928 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-housekeeping
gdm 1908 0.0 0.0 316272 9440 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-sound
gdm 1909 0.0 0.0 371036 15008 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-datetime
gdm 1910 0.0 0.0 314156 9260 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-smartcard
gdm 1911 0.0 0.0 232660 4192 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-screensaver-proxy
gdm 1913 0.0 0.0 465228 9988 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-sharing
gdm 1941 0.0 0.0 338752 12184 tty1 Sl+ 03:04 0:00 /usr/libexec/gsd-printer
colord 1954 0.0 0.0 245092 14500 ? Ssl 03:04 0:00 /usr/libexec/colord
root 2009 0.0 0.0 0 0 ? S 03:04 0:00 [irq/90-ttyS2]
root 2039 0.0 0.0 164424 8488 ? Sl 03:04 0:00 gdm-session-worker [pam/gdm-password]
nvidia 2049 0.0 0.0 19104 9232 ? Ss 03:04 0:00 /lib/systemd/systemd --user
nvidia 2050 0.0 0.0 169956 3252 ? S 03:04 0:00 (sd-pam)
nvidia 2056 0.0 0.0 581876 22120 ? SNsl 03:04 0:00 /usr/libexec/tracker-miner-fs
nvidia 2060 0.0 0.0 15640 4368 ? Ssl 03:04 0:00 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
nvidia 2067 0.0 0.0 236116 6840 ? Ssl 03:04 0:00 /usr/libexec/gvfsd
nvidia 2087 0.0 0.0 387336 10556 ? Ssl 03:04 0:00 /usr/libexec/gvfs-udisks2-volume-monitor
root 2098 46.9 0.0 0 0 ? R 03:04 6:41 [irq/134-can0]
nvidia 2120 0.0 0.0 160340 5760 tty2 Ssl+ 03:04 0:00 /usr/lib/gdm3/gdm-x-session --run-script env GNOME_SHELL_SESSION_MODE=ubuntu /usr/bin/gnome-session --systemd --session=ubuntu
root 2122 0.7 0.1 25319356 39056 tty2 Sl+ 03:04 0:06 /usr/lib/xorg/Xorg vt2 -displayfd 3 -auth /run/user/1000/gdm/Xauthority -background none -noreset -keeptty -verbose 3
nvidia 2128 0.0 0.0 186848 13096 tty2 Sl+ 03:04 0:00 /usr/libexec/gnome-session-binary --systemd --systemd --session=ubuntu
nvidia 2249 0.0 0.0 5288 436 ? Ss 03:04 0:00 /usr/bin/ssh-agent /usr/bin/im-launch env GNOME_SHELL_SESSION_MODE=ubuntu /usr/bin/gnome-session --systemd --session=ubuntu
root 2278 0.0 0.1 1944380 56164 ? Ssl 03:04 0:00 /usr/bin/dockerd --ip-forward=false -H fd:// --containerd=/run/containerd/containerd.sock
nvidia 2347 0.0 0.0 86332 4108 ? Ssl 03:04 0:00 /usr/libexec/gnome-session-ctl --monitor
nvidia 2348 0.0 0.0 802444 13548 ? Ssl 03:04 0:00 /usr/bin/pulseaudio --daemonize=no --log-target=journal
nvidia 2360 0.0 0.0 621700 14964 ? Ssl 03:04 0:00 /usr/libexec/gnome-session-binary --systemd-service --session=ubuntu
nvidia 2406 0.0 0.0 236356 6476 ? Sl 03:04 0:00 /usr/bin/gnome-keyring-daemon --start --components=secrets
nvidia 2422 0.9 0.6 4044308 200104 ? Ssl 03:04 0:08 /usr/bin/gnome-shell
nvidia 2529 0.0 0.0 582960 17196 ? Sl 03:04 0:00 /usr/libexec/gnome-shell-calendar-server
nvidia 2535 0.0 0.0 388660 22912 ? Ssl 03:04 0:00 /usr/libexec/evolution-source-registry
nvidia 2544 0.0 0.0 837100 27520 ? Ssl 03:04 0:00 /usr/libexec/evolution-calendar-factory
nvidia 2553 0.0 0.0 156240 4392 ? Sl 03:04 0:00 /usr/libexec/dconf-service
nvidia 2557 0.0 0.0 2924364 24708 ? Sl 03:04 0:00 /usr/bin/gjs /usr/share/gnome-shell/org.gnome.Shell.Notifications
nvidia 2570 0.0 0.0 745660 27044 ? Ssl 03:04 0:00 /usr/libexec/evolution-addressbook-factory
nvidia 2572 0.0 0.0 309992 7932 ? Ssl 03:04 0:00 /usr/libexec/gsd-a11y-settings
nvidia 2573 0.0 0.0 496648 23172 ? Ssl 03:04 0:00 /usr/libexec/gsd-color
nvidia 2575 0.0 0.0 371212 15260 ? Ssl 03:04 0:00 /usr/libexec/gsd-datetime
nvidia 2577 0.0 0.0 310296 8136 ? Ssl 03:04 0:00 /usr/libexec/gsd-housekeeping
nvidia 2580 0.0 0.0 337132 22320 ? Ssl 03:04 0:00 /usr/libexec/gsd-keyboard
nvidia 2583 0.0 0.0 826072 24488 ? Ssl 03:04 0:00 /usr/libexec/gsd-media-keys
nvidia 2584 0.0 0.0 338596 22544 ? Ssl 03:04 0:00 /usr/libexec/gsd-power
nvidia 2587 0.0 0.0 244968 9416 ? Ssl 03:04 0:00 /usr/libexec/gsd-print-notifications
nvidia 2591 0.0 0.1 635316 48456 ? Sl 03:04 0:00 /usr/libexec/evolution-data-server/evolution-alarm-notify
nvidia 2598 0.0 0.0 454348 5772 ? Ssl 03:04 0:00 /usr/libexec/gsd-rfkill
nvidia 2599 0.0 0.0 232660 5444 ? Ssl 03:04 0:00 /usr/libexec/gsd-screensaver-proxy
nvidia 2600 0.0 0.0 465536 10804 ? Ssl 03:04 0:00 /usr/libexec/gsd-sharing
nvidia 2601 0.0 0.0 314264 9432 ? Ssl 03:04 0:00 /usr/libexec/gsd-smartcard
nvidia 2603 0.0 0.0 316448 9640 ? Ssl 03:04 0:00 /usr/libexec/gsd-sound
nvidia 2604 0.0 0.0 384064 8332 ? Ssl 03:04 0:00 /usr/libexec/gsd-usb-protection
nvidia 2606 0.0 0.0 263028 21596 ? Ssl 03:04 0:00 /usr/libexec/gsd-wacom
nvidia 2612 0.0 0.0 314420 9400 ? Ssl 03:04 0:00 /usr/libexec/gsd-wwan
nvidia 2615 0.0 0.0 336620 21820 ? Ssl 03:04 0:00 /usr/libexec/gsd-xsettings
nvidia 2658 0.0 0.0 338752 12020 ? Sl 03:04 0:00 /usr/libexec/gsd-printer
nvidia 2723 0.6 0.1 468848 45492 ? Ssl 03:05 0:05 /usr/libexec/gnome-terminal-server
nvidia 2730 0.0 0.0 7528 5644 pts/0 Ss 03:05 0:00 bash
gdm 2831 0.0 0.0 158752 5588 ? Ssl 03:05 0:00 /usr/libexec/gvfsd-metadata
nvidia 2860 0.0 0.0 158648 5656 ? Ssl 03:05 0:00 /usr/libexec/gvfsd-metadata
root 2963 0.0 0.0 14644 7336 ? Ss 03:07 0:00 sshd: nvidia [priv]
nvidia 2974 0.0 0.0 14788 4632 ? S 03:07 0:00 sshd: nvidia@notty
nvidia 2975 0.0 0.0 5364 3020 ? Ss 03:07 0:00 bash
nvidia 3020 0.0 0.0 2060 496 ? S 03:07 0:00 sh /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/bin/code-server --start-server --host=127.0.0.1 --accept-server-license-terms --enable-remote-auto-shutdown --port=0 --telemetry-level off --connection-token-file /home/nvidia/.vscode-server/.abd2f3db4bdb28f9e95536dfa84d8479f1eb312d.token
nvidia 3030 30.5 9.2 3584580 2726860 ? Sl 03:07 3:28 /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/node /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/server-main.js --start-server --host=127.0.0.1 --accept-server-license-terms --enable-remote-auto-shutdown --port=0 --telemetry-level off --connection-token-file /home/nvidia/.vscode-server/.abd2f3db4bdb28f9e95536dfa84d8479f1eb312d.token
nvidia 3165 1.3 0.1 844836 54756 ? Sl 03:07 0:09 /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/node /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/bootstrap-fork --type=fileWatcher
nvidia 3255 0.4 0.2 961068 87716 ? Sl 03:07 0:03 /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/node --dns-result-order=ipv4first /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/bootstrap-fork --type=extensionHost --transformURIs --useHostProxy=false
nvidia 3266 0.9 0.2 1073116 66028 ? Sl 03:07 0:06 /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/node /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/bootstrap-fork --type=ptyHost --logsPath /home/nvidia/.vscode-server/data/logs/20231213T030751
nvidia 3329 0.0 0.0 7080 4864 pts/4 Ss+ 03:07 0:00 /bin/bash --init-file /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/vs/workbench/contrib/terminal/browser/media/shellIntegration-bash.sh
nvidia 3511 0.0 0.0 5364 3132 pts/5 Ss+ 03:08 0:00 /bin/bash -c rm -rf ./v12.13.0_dt && mkdir -p ./v12.13.0_dt && rm -rf gaworks_develop_v12.13.0_dt.tar.gz && wget --http-user='xlab' --http-password='Xlab#123' http://builds.xlab.gacrnd.com:12233/lizhensheng/gaworks_develop_v12.13.0_dt.tar.gz && tar --ignore-failed-read --strip-components=1 -xzf ./gaworks_develop_v12.13.0_dt.tar.gz -C ./v12.13.0_dt && rm -rf ./v12.13.0_dt/{docker,res,x86,xlab}
nvidia 3516 0.4 0.0 10956 3920 pts/5 S+ 03:08 0:02 wget --http-user=xlab --http-password=Xlab#123 http://builds.xlab.gacrnd.com:12233/lizhensheng/gaworks_develop_v12.13.0_dt.tar.gz
root 3627 0.0 0.0 8368 3452 pts/0 S 03:08 0:00 sudo su
root 3628 0.0 0.0 8064 2900 pts/0 S 03:08 0:00 su
root 3629 0.0 0.0 5636 3380 pts/0 S+ 03:08 0:00 bash
nvidia 4013 0.0 0.0 7064 5040 pts/6 Ss+ 03:09 0:00 bash
nvidia 5060 0.0 0.0 7080 4964 pts/7 Ss 03:09 0:00 /bin/bash --init-file /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/vs/workbench/contrib/terminal/browser/media/shellIntegration-bash.sh
nvidia 5298 0.0 0.0 5364 3144 pts/7 S+ 03:09 0:00 bash ./tmux.sh
nvidia 5303 0.1 0.0 5620 4364 ? Ss 03:09 0:00 /usr/bin/tmux new -s target_tmux -d -n home
nvidia 5306 0.0 0.0 7208 5024 pts/8 Ss 03:09 0:00 -bash
nvidia 5310 0.0 0.0 6944 4792 pts/9 Ss+ 03:09 0:00 -bash
nvidia 5314 0.0 0.0 6944 4768 pts/10 Ss+ 03:09 0:00 -bash
nvidia 5323 0.0 0.0 6944 4764 pts/11 Ss+ 03:09 0:00 -bash
nvidia 5334 0.0 0.0 6944 4792 pts/12 Ss+ 03:09 0:00 -bash
nvidia 5350 0.0 0.0 6944 4772 pts/13 Ss+ 03:09 0:00 -bash
nvidia 5363 0.0 0.0 6944 4840 pts/14 Ss+ 03:09 0:00 -bash
nvidia 5381 0.0 0.0 6944 4784 pts/15 Ss+ 03:09 0:00 -bash
nvidia 5407 0.0 0.0 6944 4728 pts/16 Ss+ 03:09 0:00 -bash
nvidia 5428 0.0 0.0 6944 4840 pts/17 Ss+ 03:09 0:00 -bash
nvidia 5460 0.0 0.0 6944 4840 pts/18 Ss+ 03:09 0:00 -bash
nvidia 5500 0.0 0.0 6944 4764 pts/19 Ss+ 03:09 0:00 -bash
nvidia 5557 0.0 0.0 6944 4768 pts/20 Ss+ 03:09 0:00 -bash
nvidia 5608 0.0 0.0 6944 4792 pts/21 Ss+ 03:09 0:00 -bash
nvidia 5671 0.0 0.0 6944 4808 pts/22 Ss+ 03:09 0:00 -bash
nvidia 5737 0.0 0.0 6944 4796 pts/23 Ss+ 03:09 0:00 -bash
nvidia 5813 0.0 0.0 6944 4788 pts/24 Ss+ 03:09 0:00 -bash
nvidia 5902 0.0 0.0 6944 4804 pts/25 Ss+ 03:09 0:00 -bash
nvidia 5977 0.0 0.0 6944 4764 pts/26 Ss+ 03:09 0:00 -bash
nvidia 6061 0.0 0.0 6944 4772 pts/27 Ss+ 03:09 0:00 -bash
nvidia 6147 0.0 0.0 6944 4796 pts/28 Ss+ 03:09 0:00 -bash
nvidia 6235 0.0 0.0 6944 4800 pts/29 Ss+ 03:09 0:00 -bash
nvidia 6320 0.0 0.0 6944 4792 pts/30 Ss+ 03:09 0:00 -bash
nvidia 6422 0.0 0.0 6944 4756 pts/31 Ss+ 03:09 0:00 -bash
nvidia 6519 0.0 0.0 6944 4732 pts/32 Ss+ 03:09 0:00 -bash
nvidia 6626 0.0 0.0 6944 4772 pts/33 Ss+ 03:09 0:00 -bash
nvidia 6735 0.0 0.0 6944 4724 pts/34 Ss+ 03:09 0:00 -bash
nvidia 6849 0.0 0.0 6944 4788 pts/35 Ss+ 03:09 0:00 -bash
nvidia 6976 0.0 0.0 6944 4768 pts/36 Ss+ 03:09 0:00 -bash
nvidia 7109 0.0 0.0 6944 4772 pts/37 Ss+ 03:09 0:00 -bash
nvidia 7232 0.0 0.0 6944 4768 pts/38 Ss+ 03:09 0:00 -bash
nvidia 7364 0.0 0.0 6944 4760 pts/39 Ss+ 03:09 0:00 -bash
nvidia 9970 0.0 0.0 4104 2656 pts/7 S+ 03:09 0:00 /usr/bin/tmux att -t target_tmux
root 10505 0.1 0.0 0 0 ? I 03:10 0:00 [kworker/u24:2-events_unbound]
nvidia 11129 0.0 0.0 7064 5220 pts/40 Ss+ 03:11 0:00 bash
root 11513 0.0 0.0 0 0 ? I 03:11 0:00 [kworker/4:0-mm_percpu_wq]
nvidia 13033 0.0 0.0 3700 484 ? S 03:16 0:00 sleep 180
root 13259 0.0 0.0 14640 7348 ? Ss 03:17 0:00 sshd: nvidia [priv]
nvidia 13270 0.1 0.0 14788 4668 ? S 03:17 0:00 sshd: nvidia@notty
nvidia 13271 0.0 0.0 5496 2936 ? Ss 03:17 0:00 bash
nvidia 13323 0.0 0.0 3700 424 ? S 03:17 0:00 sleep 180
nvidia 13324 1.6 0.2 959020 85912 ? Sl 03:17 0:01 /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/node --dns-result-order=ipv4first /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/bootstrap-fork --type=extensionHost --transformURIs --useHostProxy=false
nvidia 13335 0.8 0.1 843804 49904 ? Sl 03:17 0:00 /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/node /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/bootstrap-fork --type=fileWatcher
root 13856 0.0 0.0 0 0 ? I 03:18 0:00 [kworker/5:0-events]
root 14286 0.0 0.0 3700 456 ? S 03:19 0:00 sleep 10
root 14294 0.0 0.0 8368 3476 pts/8 S 03:19 0:00 sudo su
root 14295 0.0 0.0 8064 2956 pts/8 S 03:19 0:00 su
root 14296 0.0 0.0 5636 3408 pts/8 S 03:19 0:00 bash
nvidia 14340 0.0 0.0 2060 492 ? S 03:19 0:00 /bin/sh -c "/home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/vs/base/node/cpuUsage.sh" 3511 3516
nvidia 14341 0.0 0.0 5232 2680 ? S 03:19 0:00 /bin/bash /home/nvidia/.vscode-server/bin/abd2f3db4bdb28f9e95536dfa84d8479f1eb312d/out/vs/base/node/cpuUsage.sh 3511 3516
nvidia 14345 0.0 0.0 3700 432 ? S 03:19 0:00 sleep 1
root 14346 0.0 0.0 7232 2644 pts/8 R+ 03:19 0:00 ps -aux
I will add the error log later.
Dear @lizhensheng ,
I tested with helloworld example from slides with same command used in slides.
I had to kill /usr/local/driveworks/bin/launcher process to stop the app and I don’t see any issue when I re-run the app again.
nvidia@tegra-ubuntu:~$ ps -aux | grep cgf
root 4841 0.0 0.0 8368 3496 pts/1 S+ 20:03 0:00 sudo /usr/local/driveworks/bin/launcher --binPath=/usr/local/driveworks/bin --spec=/usr/local/driveworks/apps/helloworld/applications/HelloWorld.app.json --logPath=/usr/local/driveworks-5.14/bin/LogFolder --dwdatapath=/usr/local/driveworks/data --schedule=/usr/local/driveworks/apps/helloworld/HelloWorld__standardSchedule.stm --start_timestamp=0 --loglevel=DW_LOG_ERROR --fullscreen=1 --winSizeW=1280 --winSizeH=800 --disableStmControlLogger=1 --gdb_debug=0 --app_parameter= --useLCM=0 --datapath=/usr/local/driveworks/data/samples/cgf/trafficlightturning-hyperion8 --mapPath=maps/sample/sanjose_loop --path=/usr/local/driveworks/apps/roadrunner-2.0 --virtual=1
root 4842 0.0 0.1 91836 34728 pts/1 S 20:03 0:00 /usr/local/driveworks/bin/launcher --binPath=/usr/local/driveworks/bin --spec=/usr/local/driveworks/apps/helloworld/applications/HelloWorld.app.json --logPath=/usr/local/driveworks-5.14/bin/LogFolder --dwdatapath=/usr/local/driveworks/data --schedule=/usr/local/driveworks/apps/helloworld/HelloWorld__standardSchedule.stm --start_timestamp=0 --loglevel=DW_LOG_ERROR --fullscreen=1 --winSizeW=1280 --winSizeH=800 --disableStmControlLogger=1 --gdb_debug=0 --app_parameter= --useLCM=0 --datapath=/usr/local/driveworks/data/samples/cgf/trafficlightturning-hyperion8 --mapPath=maps/sample/sanjose_loop --path=/usr/local/driveworks/apps/roadrunner-2.0 --virtual=1
root 4844 0.2 1.1 40075976 335732 pts/1 Sl 20:03 0:00 /usr/local/driveworks/bin/LoaderLite --swcid=helloworld_process0 --libname=RuntimeGraphlet --modulename=helloworld_process0 --launchspec=/usr/local/driveworks-5.14/bin/LogFolder/dumpLaunchSpec.json --amend= --app_parameter= --autolanechange=0 --base_port= --binPath=/usr/local/driveworks/bin --calibrationOverlayFile= --configOverlayFile= --configOverlayName= --datapath=/usr/local/driveworks/data/samples/cgf/trafficlightturning-hyperion8 --disableParamServiceThread= --disablePrioInit=0 --disableStmControlLogger=1 --disablefaulthandler=0 --ds2_control= --dwdatapath=/usr/local/driveworks/data --enable_max_time_diff_check=0 --end_timestamp=0 --fileBackendEnabled=1 --fiufile= --frame= --ftraceBackendEnabled=0 --fullscreen=1 --instantiate_rig_sensors= --lockstep_deterministic_replay= --logPath=/usr/local/driveworks-5.14/bin/LogFolder --logdebug=0 --loglevel=DW_LOG_ERROR --logprintstats=0 --logremovedup=0 --logremovenl=0 --logremovetag= --loop=0 --mapPath=maps/sample/sanjose_loop --memTraceEnabled=0 --memwatch_frames= --navRoute= --ncuProfileFrames= --networkBackendEnabled=0 --nvtxBackendEnabled=0 --offscreen=0 --path=/usr/local/driveworks/apps/roadrunner-2.0 --preInitSerialize=0 --rc2f= --region= --rig= --schedule=/usr/local/driveworks/apps/helloworld/HelloWorld__standardSchedule.stm --shadow= --spec=/usr/local/driveworks/apps/helloworld/applications/HelloWorld.app.json --start_timestamp=0 --stmControlTracing=1 --stm_discriminator= --time_multiplier= --traceChannelMask=0x0001 --traceFilePath= --traceLevel=10 --useDynamicMap=0 --useNominalTransform=0 --vinOverlayFile= --virtual=1 --virtual_time= --winSizeH=800 --winSizeW=1280 --logspec=file/rfc5424.user.helloworld_process0:/usr/local/driveworks-5.14/bin/LogFolder/helloworld_process0.log --machine_id=machine0
nvidia 5103 0.0 0.0 4728 1888 pts/0 S+ 20:06 0:00 grep --color=auto cgf
nvidia@tegra-ubuntu:~$ sudo kill 4841
[sudo] password for nvidia:
nvidia 5147 0.0 0.0 4728 2004 pts/0 S+ 20:07 0:00 grep --color=auto cgf
I will create a new topic to query the correct way to gracefully exit cgf5.14.
Hi @SivaRamaKrishnaNV
I failed to stop the launcher with “sudo kill pid” command.
Can you share your runHelloworld.sh so I can check my runShell.sh to see if there is any mistakes about exiting gracefully?
Dear @lizhensheng ,
I just launched using launcher command with all input arguments similar to slides. I also notice, error similar to yours [BUG] cgf helloworld example 6.0.8.1 throw NvSciIpcOpenEndpointWithEventService() failed; Returned err: 514 in some runs.
Good to hear that. Let’s try to resolve the issue! Or at least make a workaround.
system
Closed
January 3, 2024, 6:25am
20
