Software Version
[√] DRIVE OS 6.0.5\ Drive Works 5.8
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[√] Linux
QNX
other
Hardware Platform
[√] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[√] 1.9.1.10844
other
Host Machine Version
[√] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
I now try to run the CGF sample with the guide of CGF sample demo:
(Compute Graph Framework SDK Reference: Demo Pipeline Introduction )
It tell us that Use the following command to launch the demo:
"sudo ./run_cgf.sh -p /usr/local/driveworks/src/cgf/graphs/descriptions/systems/CGFDemo.system.json -s /usr/local/driveworks/src/cgf/graphs/CGFDemo.stm"I
But I can not find “CGFDemo.system.json”(the 1st parameter) at the corresponding path int the docker container or in the target device.
VickNV
March 15, 2023, 8:30pm
3
Thank you for bringing this to our attention. We understand that the CGFDemo.system.json file is missing from the specified path in the Compute Graph Framework SDK Reference. We are currently investigating this issue and will update you as soon as possible. We apologize for any inconvenience this may have caused.
Thanks and I am looking forward for your further reply.
Dear @McGrady ,
Could you check sudo ./run_cgf.sh -p /usr/local/driveworks/src/cgf/graphs/descriptions/systems/CGFDemo.app.json -s /usr/local/driveworks/src/cgf/graphs/CGFDemo__standardSchedule.stm
It shows the message bellow:
20221026_044231
20221026_044231
DW_TOP_PATH=/usr/local/driveworks-5.8
RR_TOP_PATH=/usr/local/driveworks-5.8/bin
CGF_SYS_PATH=
RR_LOG_PATH=/usr/local/driveworks-5.8/bin/config/LogFolder
DATA_PATH=/usr/local/driveworks-5.8/data/apps/cgf/onofframp
Current DISPLAY is :0.0
|--> Tuning message queue
|--> Tuning network stack
LD_LIBRARY_PATH: /usr/local/driveworks-5.8/bin:/usr/local/driveworks-5.8/src/cgf/nodes::/usr/local/driveworks-5.8/lib
/usr/local/driveworks-5.8/bin/config/LogFolder dir exists
total 22676
drwxr-xr-x. 3 root root 4096 Oct 26 03:16 .
drwxr-xr-x. 9 root root 4096 Oct 26 03:15 ..
-r-xr-xr-x. 1 root root 1691504 Jan 1 2000 LoaderLite
-r-xr-xr-x. 1 root root 393776 Jan 1 2000 ScheduleManager
drwxr-xr-x. 3 root root 4096 Oct 26 03:21 config
-r-xr-xr-x. 1 root root 5758 Jan 1 2000 cpu_gpu1.stm
-r-xr-xr-x. 1 root root 5758 Jan 1 2000 cpu_gpu2.stm
-r-xr-xr-x. 1 root root 2944 Jan 1 2000 cpu_simple.stm
-r-xr-xr-x. 1 root root 15464 Jan 1 2000 get_ssm_state
-r-xr-xr-x. 1 root root 5777 Jan 1 2000 gpu_multistream_multiprocess.stm
-r-xr-xr-x. 1 root root 35312 Jan 1 2000 launcher
-r-xr-xr-x. 1 root root 48160 Jan 1 2000 libFaultHandler.so
-r-xr-xr-x. 1 root root 8560 Jan 1 2000 libconnection_helper.so
-r-xr-xr-x. 1 root root 45880 Jan 1 2000 libdnn_pool_plugin.so
-r-xr-xr-x. 1 root root 47512 Jan 1 2000 libsample_can_plugin.so
-r-xr-xr-x. 1 root root 47928 Jan 1 2000 libsample_gps_plugin.so
-r-xr-xr-x. 1 root root 48032 Jan 1 2000 libsample_imu_plugin.so
-r-xr-xr-x. 1 root root 57280 Jan 1 2000 libsample_nv_lidar_plugin.so
-r-xr-xr-x. 1 root root 57576 Jan 1 2000 libsample_nv_radar_plugin.so
-r-xr-xr-x. 1 root root 19984 Jan 1 2000 libsample_sfm_vehicleio_plugin.so
-r-xr-xr-x. 1 root root 51944 Jan 1 2000 libsample_vehicleio_plugin.so
-r-xr-xr-x. 1 root root 405760 Jan 1 2000 sample_calibration_camera
-r-xr-xr-x. 1 root root 375272 Jan 1 2000 sample_calibration_imu
-r-xr-xr-x. 1 root root 391912 Jan 1 2000 sample_calibration_lidar
-r-xr-xr-x. 1 root root 384008 Jan 1 2000 sample_calibration_radar
-r-xr-xr-x. 1 root root 353480 Jan 1 2000 sample_calibration_steering
-r-xr-xr-x. 1 root root 411760 Jan 1 2000 sample_calibration_stereo
-r-xr-xr-x. 1 root root 435216 Jan 1 2000 sample_camera
-r-xr-xr-x. 1 root root 396816 Jan 1 2000 sample_camera_replay
-r-xr-xr-x. 1 root root 336840 Jan 1 2000 sample_camera_seek
-r-xr-xr-x. 1 root root 384944 Jan 1 2000 sample_camera_usb
-r-xr-xr-x. 1 root root 112344 Jan 1 2000 sample_canbus_interpreter
-r-xr-xr-x. 1 root root 110776 Jan 1 2000 sample_canbus_logger
-r-xr-xr-x. 1 root root 397752 Jan 1 2000 sample_cgf_camera_interprocess
-r-xr-xr-x. 1 root root 513304 Jan 1 2000 sample_cgf_dwchannel
-r-xr-xr-x. 1 root root 340120 Jan 1 2000 sample_color_correction
-r-xr-xr-x. 1 root root 331792 Jan 1 2000 sample_connected_components
-r-xr-xr-x. 1 root root 105480 Jan 1 2000 sample_datasensor
-r-xr-xr-x. 1 root root 162216 Jan 1 2000 sample_dataspeedBridge
-r-xr-xr-x. 1 root root 326368 Jan 1 2000 sample_dnn_plugin
-r-xr-xr-x. 1 root root 371056 Jan 1 2000 sample_dnn_tensor
-r-xr-xr-x. 1 root root 353656 Jan 1 2000 sample_egomotion
-r-xr-xr-x. 1 root root 427352 Jan 1 2000 sample_fast9_feature_detector
-r-xr-xr-x. 1 root root 475168 Jan 1 2000 sample_feature_descriptor
-r-xr-xr-x. 1 root root 472008 Jan 1 2000 sample_feature_tracker
-r-xr-xr-x. 1 root root 101232 Jan 1 2000 sample_gps_logger
-r-xr-xr-x. 1 root root 46328 Jan 1 2000 sample_hello_world
-r-xr-xr-x. 1 root root 320048 Jan 1 2000 sample_icp
-r-xr-xr-x. 1 root root 295816 Jan 1 2000 sample_image_capture
-r-xr-xr-x. 1 root root 346448 Jan 1 2000 sample_image_pyramid_pva
-r-xr-xr-x. 1 root root 284416 Jan 1 2000 sample_image_streamer_multi
-r-xr-xr-x. 1 root root 287024 Jan 1 2000 sample_image_streamer_simple
-r-xr-xr-x. 1 root root 414032 Jan 1 2000 sample_imagetransformation
-r-xr-xr-x. 1 root root 105568 Jan 1 2000 sample_imu_logger
-r-xr-xr-x. 1 root root 302112 Jan 1 2000 sample_lidar_replay
-r-xr-xr-x. 1 root root 402120 Jan 1 2000 sample_object_detector_tracker
-r-xr-xr-x. 1 root root 411632 Jan 1 2000 sample_pointcloudprocessing
-r-xr-xr-x. 1 root root 306928 Jan 1 2000 sample_radar_replay
-r-xr-xr-x. 1 root root 277424 Jan 1 2000 sample_record
-r-xr-xr-x. 1 root root 303800 Jan 1 2000 sample_render_engine
-r-xr-xr-x. 1 root root 262616 Jan 1 2000 sample_renderer
-r-xr-xr-x. 1 root root 88960 Jan 1 2000 sample_rig
-r-xr-xr-x. 1 root root 47664 Jan 1 2000 sample_sensors_info
-r-xr-xr-x. 1 root root 377528 Jan 1 2000 sample_sfm
-r-xr-xr-x. 1 root root 107000 Jan 1 2000 sample_socket_ipc_clientserver
-r-xr-xr-x. 1 root root 484736 Jan 1 2000 sample_stereo_disparity
-r-xr-xr-x. 1 root root 372032 Jan 1 2000 sample_template_tracker
-r-xr-xr-x. 1 root root 109592 Jan 1 2000 sample_timesensor
-r-xr-xr-x. 1 root root 289696 Jan 1 2000 sample_vehicleio
-r-xr-xr-x. 1 root root 368432 Jan 1 2000 sample_video_rectifier
-r-xr-xr-x. 1 root root 336536 Jan 1 2000 sample_video_rectifierLDC
-r-xr-xr-x. 1 root root 92272 Jan 1 2000 seh_x86
-r-xr-xr-x. 1 root root 118328 Jan 1 2000 sensor_sync_server
-r-xr-xr-x. 1 root root 116080 Jan 1 2000 ssm_demo1
-r-xr-xr-x. 1 root root 176936 Jan 1 2000 ssm_demo2
-r-xr-xr-x. 1 root root 182712 Jan 1 2000 ssm_demo3
-r-xr-xr-x. 1 root root 210816 Jan 1 2000 ssm_demo4
-r-xr-xr-x. 1 root root 179160 Jan 1 2000 ssm_demo5
-r-xr-xr-x. 1 root root 120464 Jan 1 2000 ssm_demo6
-r-xr-xr-x. 1 root root 165976 Jan 1 2000 stm_master
-r-xr-xr-x. 1 root root 809184 Jan 1 2000 stm_sample_gpuX
-r-xr-xr-x. 1 root root 809184 Jan 1 2000 stm_sample_gpuY
-r-xr-xr-x. 1 root root 83480 Jan 1 2000 stm_sample_manager
-r-xr-xr-x. 1 root root 14560 Jan 1 2000 stm_test_cpu_simple
-r-xr-xr-x. 1 root root 809240 Jan 1 2000 stm_test_gpuX
-r-xr-xr-x. 1 root root 809296 Jan 1 2000 stm_test_gpuY
-r-xr-xr-x. 1 root root 194400 Jan 1 2000 stm_test_vpu
-r-xr-xr-x. 1 root root 111296 Jan 1 2000 vanillassm
-r-xr-xr-x. 1 root root 5774 Jan 1 2000 vpu_simple.stm
Running command: /usr/local/driveworks-5.8/bin/launcher --binPath=/usr/local/driveworks-5.8/bin --spec=/usr/local/driveworks-5.8/src/cgf/graphs/descriptions/systems/CGFDemo.app.json --logPath=/usr/local/driveworks-5.8/bin/config/LogFolder --path=/usr/local/driveworks-5.8/bin --datapath=/usr/local/driveworks-5.8/data/apps/cgf/onofframp --dwdatapath=/usr/local/driveworks-5.8/data --vdcpath=/usr/local/driveworks-5.8/bin --schedule=/usr/local/driveworks-5.8/src/cgf/graphs/CGFDemo__standardSchedule.stm --start_timestamp=0 --loglevel=DW_LOG_VERBOSE --fullscreen=0 --winSizeW=1920 --winSizeH=1200 --virtual=1 --gdb_debug=0 --app_parameter= > /usr/local/driveworks-5.8/bin/config/LogFolder/launcher.log 2>&1
Check if reset NetworkStack needed
Restore LD_LIBRARY_PATH to
launcher exit status: 33
Do you know what’s the meaning of this error?Preformatted text
Hi, I checked this topic Compute graph framework - DRIVE AGX Orin / DRIVE AGX Orin General - NVIDIA Developer Forums which describe the cgf demo issue in drive sdk 6.0.4, and It’s said by official that cgf demo and gui-edit-tools is not available in 6.0.4.
I wonder if these issues are resolved in the latest 6.0.5 version?
If not, what is the current status availability about cgf library.
Dear @McGrady ,
I could reproduce the same issue via ssh to remote machine(no X11 enabled)
Could you confirm if you are running the application directly on host/target or via remote terminal like ssh or via VNC?
Dear @McGrady ,
We notice below debian files are missing via sdkm installation of DRIVE OS 6.0.6.
driveworks-samples_*~linux*_arm64.deb
driveworks-stm-samples_*~linux*_arm64.deb
driveworks-cgf-samples_*~linux*_arm64.deb
Could you get the debians from docker container(From /drive/extra/driveworks folder in nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:6.0.6.0-0004 ) and install on target. Please run the sample as sudo ./run_cgf.sh on target.
Please see DriveWorks SDK Reference: Getting Started Using the NVIDIA DRIVE OS NGC Docker Container for missing debians.
I had verified the steps and I could run on target successfully
I tryt to run this sample both directly on host/target and via ssh, it comes out the same error
Dear SivaRamaKrishnaNV
I have tried to install the deb package, but the error still exist.
Dear @McGrady ,
Could you check with DRIVE OS 6.0.6 release and confirm?
