Bug Report - eGPU Core X Chroma with NVIDIA GPU over Thunderbolt 3(4?)
Using RAZER Core X Chroma eGPU enclosure with Thunderbolt 4 capable cable.
I am seeing this problem, it appears that the enclosure disconnected (crashed?) suddenly, leaving the GPU in a strange state:
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57d:0:0:0x00000023
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to tear down display engine channel
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to free DMA context
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to unmap memory
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to free DMA memory
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
here is the beginning of these messages:
[Mon Jun 12 12:59:22 2023] input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card2/input41
[Mon Jun 12 12:59:22 2023] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card2/input42
[Mon Jun 12 12:59:22 2023] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card2/input43
[Mon Jun 12 12:59:22 2023] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card2/input44
[Mon Jun 12 12:59:22 2023] hid-sensor-hub 001F:8087:0AC2.000A: hid_field_extract() called with n (192) > 32! (kworker/1:0)
[Mon Jun 12 12:59:23 2023] serial 0000:00:16.3: LSR safety check engaged!
[Mon Jun 12 12:59:24 2023] serial 0000:00:16.3: LSR safety check engaged!
[Mon Jun 12 12:59:24 2023] usb 5-2: current rate 16000 is different from the runtime rate 48000
[Mon Jun 12 12:59:25 2023] ax88179_178a 9-1:1.0 enx98bb1e1ef97c: ax88179 - Link status is: 1
[Mon Jun 12 12:59:25 2023] IPv6: ADDRCONF(NETDEV_CHANGE): enx98bb1e1ef97c: link becomes ready
[Mon Jun 12 12:59:25 2023] thunderbolt 1-1: new device found, vendor=0x127 device=0x2
[Mon Jun 12 12:59:25 2023] thunderbolt 1-1: Razer Core X Chroma
[Mon Jun 12 12:59:26 2023] wlp0s20f3: authenticate with 80:d0:4a:02:dc:78
[Mon Jun 12 12:59:26 2023] wlp0s20f3: send auth to 80:d0:4a:02:dc:78 (try 1/3)
[Mon Jun 12 12:59:26 2023] wlp0s20f3: authenticated
[Mon Jun 12 12:59:26 2023] wlp0s20f3: associate with 80:d0:4a:02:dc:78 (try 1/3)
[Mon Jun 12 12:59:26 2023] wlp0s20f3: RX AssocResp from 80:d0:4a:02:dc:78 (capab=0x1511 status=0 aid=4)
[Mon Jun 12 12:59:26 2023] wlp0s20f3: associated
[Mon Jun 12 12:59:26 2023] wlp0s20f3: Limiting TX power to 30 (30 - 0) dBm as advertised by 80:d0:4a:02:dc:78
[Mon Jun 12 12:59:26 2023] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[Mon Jun 12 12:59:26 2023] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[Mon Jun 12 12:59:27 2023] vboxdrv: Found 8 processor cores/threads
[Mon Jun 12 12:59:27 2023] vboxdrv: TSC mode is Invariant, tentative frequency 2995200124 Hz
[Mon Jun 12 12:59:27 2023] vboxdrv: Successfully loaded version 7.0.6_Ubuntu r155176 (interface 0x00330004)
[Mon Jun 12 12:59:27 2023] VBoxNetFlt: Successfully started.
[Mon Jun 12 12:59:27 2023] VBoxNetAdp: Successfully started.
[Mon Jun 12 12:59:27 2023] NFSD: Using nfsdcld client tracking operations.
[Mon Jun 12 12:59:27 2023] NFSD: no clients to reclaim, skipping NFSv4 grace period (net f0000000)
[Mon Jun 12 12:59:27 2023] rfkill: input handler disabled
[Mon Jun 12 12:59:32 2023] thunderbolt 1-101: new device found, vendor=0x127 device=0x3
[Mon Jun 12 12:59:32 2023] thunderbolt 1-101: Razer Core X Chroma
[Mon Jun 12 12:59:32 2023] usb 4-7: USB disconnect, device number 5
[Mon Jun 12 12:59:41 2023] pcieport 0000:00:07.2: pciehp: Slot(0-1): Link Down
[Mon Jun 12 12:59:41 2023] xhci_hcd 0000:57:00.0: remove, state 1
[Mon Jun 12 12:59:41 2023] usb usb9: USB disconnect, device number 1
[Mon Jun 12 12:59:41 2023] usb 9-1: USB disconnect, device number 2
[Mon Jun 12 12:59:41 2023] xhci_hcd 0000:57:00.0: xHCI host controller not responding, assume dead
[Mon Jun 12 12:59:41 2023] ax88179_178a 9-1:1.0 enx98bb1e1ef97c: unregister 'ax88179_178a' usb-0000:57:00.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet
[Mon Jun 12 12:59:41 2023] ax88179_178a 9-1:1.0 enx98bb1e1ef97c: Failed to read reg index 0x0002: -19
[Mon Jun 12 12:59:41 2023] ax88179_178a 9-1:1.0 enx98bb1e1ef97c: Failed to write reg index 0x0002: -19
[Mon Jun 12 12:59:42 2023] ax88179_178a 9-1:1.0 enx98bb1e1ef97c (unregistered): Failed to write reg index 0x0002: -19
[Mon Jun 12 12:59:42 2023] ax88179_178a 9-1:1.0 enx98bb1e1ef97c (unregistered): Failed to write reg index 0x0001: -19
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:57:00.0: USB bus 9 deregistered
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:57:00.0: remove, state 1
[Mon Jun 12 12:59:42 2023] usb usb3: USB disconnect, device number 1
[Mon Jun 12 12:59:42 2023] usb 3-2: USB disconnect, device number 2
[Mon Jun 12 12:59:42 2023] thunderbolt 1-101: device disconnected
[Mon Jun 12 12:59:42 2023] thunderbolt 1-1: device disconnected
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:57:00.0: Host halt failed, -19
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:57:00.0: Host not accessible, reset failed.
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:57:00.0: USB bus 3 deregistered
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:56:00.0: remove, state 4
[Mon Jun 12 12:59:42 2023] usb usb8: USB disconnect, device number 1
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:56:00.0: USB bus 8 deregistered
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:56:00.0: xHCI host controller not responding, assume dead
[Mon Jun 12 12:59:42 2023] usb usb2: USB disconnect, device number 1
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:56:00.0: Host halt failed, -19
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:56:00.0: Host not accessible, reset failed.
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:56:00.0: USB bus 2 deregistered
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:55:00.0: remove, state 4
[Mon Jun 12 12:59:42 2023] usb usb10: USB disconnect, device number 1
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:55:00.0: USB bus 10 deregistered
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:55:00.0: xHCI host controller not responding, assume dead
[Mon Jun 12 12:59:42 2023] usb usb6: USB disconnect, device number 1
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:55:00.0: Host halt failed, -19
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:55:00.0: Host not accessible, reset failed.
[Mon Jun 12 12:59:42 2023] xhci_hcd 0000:55:00.0: USB bus 6 deregistered
[Mon Jun 12 12:59:42 2023] pcieport 0000:51:04.0: Runtime PM usage count underflow!
[Mon Jun 12 12:59:42 2023] NVRM: GPU at PCI:0000:52:00: GPU-34525e39-4f43-a748-dd21-b6b56a25f02a
[Mon Jun 12 12:59:42 2023] NVRM: Xid (PCI:0000:52:00): 79, pid='<unknown>', name=<unknown>, GPU has fallen off the bus.
[Mon Jun 12 12:59:42 2023] NVRM: GPU 0000:52:00.0: GPU has fallen off the bus.
[Mon Jun 12 12:59:42 2023] NVRM: A GPU crash dump has been created. If possible, please run
                           NVRM: nvidia-bug-report.sh as root to collect this data before
                           NVRM: the NVIDIA kernel module is unloaded.
[Mon Jun 12 12:59:42 2023] snd_hda_codec_hdmi hdaudioC0D0: Unable to sync register 0x4f0800. -5
[Mon Jun 12 12:59:42 2023] snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD buf size -1
[Mon Jun 12 12:59:43 2023] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=io+mem:owns=io+mem
[Mon Jun 12 12:59:43 2023] pci 0000:52:00.0: Removing from iommu group 2
[Mon Jun 12 12:59:43 2023] pci 0000:52:00.1: Removing from iommu group 2
[Mon Jun 12 12:59:43 2023] pci_bus 0000:52: busn_res: [bus 52] is released
[Mon Jun 12 12:59:43 2023] pci 0000:51:01.0: Removing from iommu group 2
[Mon Jun 12 12:59:43 2023] pci 0000:55:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:43 2023] pci_bus 0000:55: busn_res: [bus 55] is released
[Mon Jun 12 12:59:43 2023] pci 0000:54:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:43 2023] pci 0000:56:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:43 2023] pci_bus 0000:56: busn_res: [bus 56] is released
[Mon Jun 12 12:59:43 2023] pci 0000:54:01.0: Removing from iommu group 3
[Mon Jun 12 12:59:43 2023] pci 0000:57:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:43 2023] pci_bus 0000:57: busn_res: [bus 57] is released
[Mon Jun 12 12:59:43 2023] pci 0000:54:02.0: Removing from iommu group 3
[Mon Jun 12 12:59:43 2023] pci_bus 0000:54: busn_res: [bus 54-57] is released
[Mon Jun 12 12:59:43 2023] pci 0000:53:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:43 2023] pci_bus 0000:53: busn_res: [bus 53-79] is released
[Mon Jun 12 12:59:43 2023] pci 0000:51:04.0: Removing from iommu group 3
[Mon Jun 12 12:59:43 2023] pci_bus 0000:51: busn_res: [bus 51-79] is released
[Mon Jun 12 12:59:43 2023] pci 0000:50:00.0: Removing from iommu group 1
[Mon Jun 12 12:59:44 2023] pcieport 0000:00:07.2: pciehp: Slot(0-1): Card present
[Mon Jun 12 12:59:44 2023] pcieport 0000:00:07.2: pciehp: Slot(0-1): Link Up
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: supports D1 D2
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.2 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: Adding to iommu group 1
[Mon Jun 12 12:59:44 2023] pcieport 0000:00:07.2: ASPM: current common clock configuration is inconsistent, reconfiguring
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: supports D1 D2
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: Adding to iommu group 2
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: supports D1 D2
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: Adding to iommu group 3
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: PCI bridge to [bus 51-79]
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: [10de:1f82] type 00 class 0x030000
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: reg 0x14: [mem 0x00000000-0x0fffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: reg 0x1c: [mem 0x00000000-0x01ffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: reg 0x24: [io  0x0000-0x007f]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: reg 0x30: [mem 0x00000000-0x0007ffff pref]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: PME# supported from D0 D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.2 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: Adding to iommu group 2
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: vgaarb: bridge control possible
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[Mon Jun 12 12:59:44 2023] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.1: [10de:10fa] type 00 class 0x040300
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.1: reg 0x10: [mem 0x00000000-0x00003fff]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.1: Adding to iommu group 2
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: PCI bridge to [bus 52-79]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci_bus 0000:52: busn_res: [bus 52-79] end is updated to 52
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: PCI bridge to [bus 53-79]
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci_bus 0000:53: busn_res: [bus 53-79] end is updated to 79
[Mon Jun 12 12:59:44 2023] pci_bus 0000:51: busn_res: [bus 51-79] end is updated to 79
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: bridge window [mem 0x00100000-0x001fffff 64bit pref] to [bus 53-79] add_size 100000 add_align 100000
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: bridge window [mem 0x00100000-0x001fffff] to [bus 53-79] add_size 100000 add_align 100000
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: BAR 15: assigned [mem 0x6000000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: BAR 14: assigned [mem 0xa2000000-0xaeffffff]
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0: BAR 13: assigned [io  0x6000-0x8fff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: BAR 15: assigned [mem 0x6000000000-0x6017ffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: BAR 14: assigned [mem 0xa2000000-0xa37fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: BAR 14: assigned [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: BAR 15: assigned [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: BAR 13: assigned [io  0x6000-0x6fff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0: BAR 13: assigned [io  0x7000-0x8fff]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: BAR 1: assigned [mem 0x6000000000-0x600fffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: BAR 3: assigned [mem 0x6010000000-0x6011ffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: BAR 0: assigned [mem 0xa2000000-0xa2ffffff]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: BAR 6: assigned [mem 0xa3000000-0xa307ffff pref]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.1: BAR 0: assigned [mem 0xa3080000-0xa3083fff]
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.0: BAR 5: assigned [io  0x6000-0x607f]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0: PCI bridge to [bus 52]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0:   bridge window [io  0x6000-0x6fff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0:   bridge window [mem 0xa2000000-0xa37fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:01.0:   bridge window [mem 0x6000000000-0x6017ffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0:   bridge window [io  0x7000-0x8fff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0:   bridge window [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:44 2023] pci 0000:51:04.0:   bridge window [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0:   bridge window [io  0x6000-0x8fff]
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0:   bridge window [mem 0xa2000000-0xaeffffff]
[Mon Jun 12 12:59:44 2023] pci 0000:50:00.0:   bridge window [mem 0x6000000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pcieport 0000:00:07.2: PCI bridge to [bus 50-79]
[Mon Jun 12 12:59:44 2023] pcieport 0000:00:07.2:   bridge window [io  0x6000-0x8fff]
[Mon Jun 12 12:59:44 2023] pcieport 0000:00:07.2:   bridge window [mem 0xa2000000-0xaf1fffff]
[Mon Jun 12 12:59:44 2023] pcieport 0000:00:07.2:   bridge window [mem 0x6000000000-0x602dffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pcieport 0000:50:00.0: enabling device (0000 -> 0003)
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:01.0: enabling device (0000 -> 0003)
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0: enabling device (0000 -> 0003)
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[Mon Jun 12 12:59:44 2023] nvidia 0000:52:00.0: enabling device (0000 -> 0003)
[Mon Jun 12 12:59:44 2023] nvidia 0000:52:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[Mon Jun 12 12:59:44 2023] pci 0000:52:00.1: D0 power state depends on 0000:52:00.0
[Mon Jun 12 12:59:44 2023] snd_hda_intel 0000:52:00.1: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:44 2023] snd_hda_intel 0000:52:00.1: Disabling MSI
[Mon Jun 12 12:59:44 2023] snd_hda_intel 0000:52:00.1: Handle vga_switcheroo audio client
[Mon Jun 12 12:59:44 2023] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:01.0/0000:52:00.1/sound/card0/input45
[Mon Jun 12 12:59:44 2023] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:01.0/0000:52:00.1/sound/card0/input46
[Mon Jun 12 12:59:44 2023] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:01.0/0000:52:00.1/sound/card0/input47
[Mon Jun 12 12:59:44 2023] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:01.0/0000:52:00.1/sound/card0/input48
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0: pciehp: Slot(4): Card present
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: supports D1 D2
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.2 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: supports D1 D2
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: supports D1 D2
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: Adding to iommu group 3
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: supports D1 D2
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: Adding to iommu group 3
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: PCI bridge to [bus 54-79]
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:44 2023] pci 0000:55:00.0: [1b21:1242] type 00 class 0x0c0330
[Mon Jun 12 12:59:44 2023] pci 0000:55:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[Mon Jun 12 12:59:44 2023] pci 0000:55:00.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:55:00.0: PME# supported from D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:55:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:54:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[Mon Jun 12 12:59:44 2023] pci 0000:55:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: PCI bridge to [bus 55-79]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci_bus 0000:55: busn_res: [bus 55-79] end is updated to 55
[Mon Jun 12 12:59:44 2023] pci 0000:56:00.0: [1b21:1242] type 00 class 0x0c0330
[Mon Jun 12 12:59:44 2023] pci 0000:56:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[Mon Jun 12 12:59:44 2023] pci 0000:56:00.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:56:00.0: PME# supported from D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:56:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:54:01.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[Mon Jun 12 12:59:44 2023] pci 0000:56:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: PCI bridge to [bus 56-79]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci_bus 0000:56: busn_res: [bus 56-79] end is updated to 56
[Mon Jun 12 12:59:44 2023] pci 0000:57:00.0: [1b21:1242] type 00 class 0x0c0330
[Mon Jun 12 12:59:44 2023] pci 0000:57:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[Mon Jun 12 12:59:44 2023] pci 0000:57:00.0: enabling Extended Tags
[Mon Jun 12 12:59:44 2023] pci 0000:57:00.0: PME# supported from D3hot D3cold
[Mon Jun 12 12:59:44 2023] pci 0000:57:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:54:02.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[Mon Jun 12 12:59:44 2023] pci 0000:57:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: PCI bridge to [bus 57-79]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci_bus 0000:57: busn_res: [bus 57-79] end is updated to 57
[Mon Jun 12 12:59:44 2023] pci_bus 0000:54: busn_res: [bus 54-79] end is updated to 57
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: BAR 14: assigned [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: BAR 15: assigned [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: BAR 13: no space for [io  size 0x3000]
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: BAR 13: failed to assign [io  size 0x3000]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: BAR 14: assigned [mem 0xa3800000-0xa74fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: BAR 15: assigned [mem 0x6018000000-0x601e9fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: BAR 14: assigned [mem 0xa7500000-0xab1fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: BAR 15: assigned [mem 0x601ea00000-0x60253fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: BAR 14: assigned [mem 0xab200000-0xaeefffff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: BAR 15: assigned [mem 0x6025400000-0x602bdfffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: BAR 13: no space for [io  size 0x1000]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: BAR 13: failed to assign [io  size 0x1000]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: BAR 13: no space for [io  size 0x1000]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: BAR 13: failed to assign [io  size 0x1000]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: BAR 13: no space for [io  size 0x1000]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: BAR 13: failed to assign [io  size 0x1000]
[Mon Jun 12 12:59:44 2023] pci 0000:55:00.0: BAR 0: assigned [mem 0xa3800000-0xa3807fff 64bit]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0: PCI bridge to [bus 55]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0:   bridge window [mem 0xa3800000-0xa74fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:00.0:   bridge window [mem 0x6018000000-0x601e9fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:56:00.0: BAR 0: assigned [mem 0xa7500000-0xa7507fff 64bit]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0: PCI bridge to [bus 56]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0:   bridge window [mem 0xa7500000-0xab1fffff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:01.0:   bridge window [mem 0x601ea00000-0x60253fffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:57:00.0: BAR 0: assigned [mem 0xab200000-0xab207fff 64bit]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0: PCI bridge to [bus 57]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0:   bridge window [mem 0xab200000-0xaeefffff]
[Mon Jun 12 12:59:44 2023] pci 0000:54:02.0:   bridge window [mem 0x6025400000-0x602bdfffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0: PCI bridge to [bus 54-57]
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0:   bridge window [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:44 2023] pci 0000:53:00.0:   bridge window [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0: PCI bridge to [bus 53-79]
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0:   bridge window [io  0x7000-0x8fff]
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0:   bridge window [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0:   bridge window [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:44 2023] PCI: No. 2 try to assign unassigned res
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0: resource 13 [io  0x7000-0x8fff] released
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0: BAR 13: no space for [io  size 0x3000]
[Mon Jun 12 12:59:44 2023] pcieport 0000:51:04.0: BAR 13: failed to assign [io  size 0x3000]
[Mon Jun 12 12:59:44 2023] pcieport 0000:53:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:44 2023] pcieport 0000:54:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:44 2023] pcieport 0000:54:01.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:44 2023] pcieport 0000:54:02.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:44 2023] pci 0000:55:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:55:00.0: xHCI Host Controller
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:55:00.0: new USB bus registered, assigned bus number 2
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:55:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:55:00.0: new USB bus registered, assigned bus number 3
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:55:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[Mon Jun 12 12:59:44 2023] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[Mon Jun 12 12:59:44 2023] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:44 2023] usb usb2: Product: xHCI Host Controller
[Mon Jun 12 12:59:44 2023] usb usb2: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:44 2023] usb usb2: SerialNumber: 0000:55:00.0
[Mon Jun 12 12:59:44 2023] hub 2-0:1.0: USB hub found
[Mon Jun 12 12:59:44 2023] hub 2-0:1.0: 2 ports detected
[Mon Jun 12 12:59:44 2023] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[Mon Jun 12 12:59:44 2023] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[Mon Jun 12 12:59:44 2023] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:44 2023] usb usb3: Product: xHCI Host Controller
[Mon Jun 12 12:59:44 2023] usb usb3: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:44 2023] usb usb3: SerialNumber: 0000:55:00.0
[Mon Jun 12 12:59:44 2023] hub 3-0:1.0: USB hub found
[Mon Jun 12 12:59:44 2023] hub 3-0:1.0: 2 ports detected
[Mon Jun 12 12:59:44 2023] pci 0000:56:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:56:00.0: xHCI Host Controller
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:56:00.0: new USB bus registered, assigned bus number 6
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:56:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:56:00.0: new USB bus registered, assigned bus number 8
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:56:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[Mon Jun 12 12:59:44 2023] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[Mon Jun 12 12:59:44 2023] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:44 2023] usb usb6: Product: xHCI Host Controller
[Mon Jun 12 12:59:44 2023] usb usb6: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:44 2023] usb usb6: SerialNumber: 0000:56:00.0
[Mon Jun 12 12:59:44 2023] hub 6-0:1.0: USB hub found
[Mon Jun 12 12:59:44 2023] hub 6-0:1.0: 2 ports detected
[Mon Jun 12 12:59:44 2023] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[Mon Jun 12 12:59:44 2023] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[Mon Jun 12 12:59:44 2023] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:44 2023] usb usb8: Product: xHCI Host Controller
[Mon Jun 12 12:59:44 2023] usb usb8: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:44 2023] usb usb8: SerialNumber: 0000:56:00.0
[Mon Jun 12 12:59:44 2023] hub 8-0:1.0: USB hub found
[Mon Jun 12 12:59:44 2023] hub 8-0:1.0: 2 ports detected
[Mon Jun 12 12:59:44 2023] pci 0000:57:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:57:00.0: xHCI Host Controller
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:57:00.0: new USB bus registered, assigned bus number 9
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:57:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:57:00.0: new USB bus registered, assigned bus number 10
[Mon Jun 12 12:59:44 2023] xhci_hcd 0000:57:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[Mon Jun 12 12:59:44 2023] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[Mon Jun 12 12:59:44 2023] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:44 2023] usb usb9: Product: xHCI Host Controller
[Mon Jun 12 12:59:44 2023] usb usb9: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:44 2023] usb usb9: SerialNumber: 0000:57:00.0
[Mon Jun 12 12:59:44 2023] hub 9-0:1.0: USB hub found
[Mon Jun 12 12:59:44 2023] hub 9-0:1.0: 2 ports detected
[Mon Jun 12 12:59:44 2023] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[Mon Jun 12 12:59:44 2023] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[Mon Jun 12 12:59:44 2023] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:44 2023] usb usb10: Product: xHCI Host Controller
[Mon Jun 12 12:59:44 2023] usb usb10: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:44 2023] usb usb10: SerialNumber: 0000:57:00.0
[Mon Jun 12 12:59:44 2023] hub 10-0:1.0: USB hub found
[Mon Jun 12 12:59:44 2023] hub 10-0:1.0: 2 ports detected
[Mon Jun 12 12:59:45 2023] usb 9-2: new full-speed USB device number 3 using xhci_hcd
[Mon Jun 12 12:59:46 2023] usb 9-2: New USB device found, idVendor=1532, idProduct=0f1a, bcdDevice= 2.00
[Mon Jun 12 12:59:46 2023] usb 9-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Mon Jun 12 12:59:46 2023] usb 9-2: Product: Razer Core X Chroma
[Mon Jun 12 12:59:46 2023] usb 9-2: Manufacturer: Razer
[Mon Jun 12 12:59:46 2023] input: Razer Razer Core X Chroma as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:04.0/0000:53:00.0/0000:54:02.0/0000:57:00.0/usb9/9-2/9-2:1.0/0003:1532:0F1A.000D/input/input49
[Mon Jun 12 12:59:46 2023] usb 10-1: new SuperSpeed USB device number 2 using xhci_hcd
[Mon Jun 12 12:59:46 2023] usb 10-1: New USB device found, idVendor=0b95, idProduct=1790, bcdDevice= 1.00
[Mon Jun 12 12:59:46 2023] usb 10-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Mon Jun 12 12:59:46 2023] usb 10-1: Product: AX88179
[Mon Jun 12 12:59:46 2023] usb 10-1: Manufacturer: ASIX Elec. Corp.
[Mon Jun 12 12:59:46 2023] usb 10-1: SerialNumber: 0098BB1E1EF97C
[Mon Jun 12 12:59:46 2023] hid-generic 0003:1532:0F1A.000D: input,hidraw5: USB HID v1.11 Keyboard [Razer Razer Core X Chroma] on usb-0000:57:00.0-2/input0
[Mon Jun 12 12:59:46 2023] input: Razer Razer Core X Chroma Keyboard as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:04.0/0000:53:00.0/0000:54:02.0/0000:57:00.0/usb9/9-2/9-2:1.1/0003:1532:0F1A.000E/input/input50
[Mon Jun 12 12:59:46 2023] input: Razer Razer Core X Chroma as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:04.0/0000:53:00.0/0000:54:02.0/0000:57:00.0/usb9/9-2/9-2:1.1/0003:1532:0F1A.000E/input/input51
[Mon Jun 12 12:59:46 2023] hid-generic 0003:1532:0F1A.000E: input,hidraw6: USB HID v1.11 Keyboard [Razer Razer Core X Chroma] on usb-0000:57:00.0-2/input1
[Mon Jun 12 12:59:46 2023] input: Razer Razer Core X Chroma as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:04.0/0000:53:00.0/0000:54:02.0/0000:57:00.0/usb9/9-2/9-2:1.2/0003:1532:0F1A.000F/input/input52
[Mon Jun 12 12:59:46 2023] hid-generic 0003:1532:0F1A.000F: input,hidraw7: USB HID v1.11 Mouse [Razer Razer Core X Chroma] on usb-0000:57:00.0-2/input2
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:57:00.0: xHCI host controller not responding, assume dead
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:57:00.0: HC died; cleaning up
[Mon Jun 12 12:59:46 2023] pcieport 0000:00:07.2: pciehp: Slot(0-1): Link Down
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:57:00.0: remove, state 1
[Mon Jun 12 12:59:46 2023] usb usb10: USB disconnect, device number 1
[Mon Jun 12 12:59:46 2023] usb 9-2: USB disconnect, device number 3
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0001: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0001: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0006: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): invalid MAC address, using random
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0006: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0005: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0002: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x001f: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x0019: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000d: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to write reg index 0x000e: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x000e: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 (unnamed net_device) (uninitialized): Failed to read reg index 0x0000: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 eth0: register 'ax88179_178a' at usb-0000:57:00.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 06:ea:41:09:0f:81
[Mon Jun 12 12:59:46 2023] usb 10-1: USB disconnect, device number 2
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 eth0: unregister 'ax88179_178a' usb-0000:57:00.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 eth0 (unregistered): Failed to write reg index 0x0002: -19
[Mon Jun 12 12:59:46 2023] ax88179_178a 10-1:1.0 eth0 (unregistered): Failed to write reg index 0x0001: -19
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:57:00.0: USB bus 10 deregistered
[Mon Jun 12 12:59:46 2023] usb usb9: USB disconnect, device number 1
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:57:00.0: Host halt failed, -19
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:57:00.0: Host not accessible, reset failed.
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:57:00.0: USB bus 9 deregistered
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:56:00.0: remove, state 4
[Mon Jun 12 12:59:46 2023] usb usb8: USB disconnect, device number 1
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:56:00.0: USB bus 8 deregistered
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:56:00.0: xHCI host controller not responding, assume dead
[Mon Jun 12 12:59:46 2023] usb usb6: USB disconnect, device number 1
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:56:00.0: Host halt failed, -19
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:56:00.0: Host not accessible, reset failed.
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:56:00.0: USB bus 6 deregistered
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:55:00.0: remove, state 4
[Mon Jun 12 12:59:46 2023] usb usb3: USB disconnect, device number 1
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:55:00.0: USB bus 3 deregistered
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:55:00.0: xHCI host controller not responding, assume dead
[Mon Jun 12 12:59:46 2023] usb usb2: USB disconnect, device number 1
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:55:00.0: Host halt failed, -19
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:55:00.0: Host not accessible, reset failed.
[Mon Jun 12 12:59:46 2023] xhci_hcd 0000:55:00.0: USB bus 2 deregistered
[Mon Jun 12 12:59:46 2023] pcieport 0000:51:04.0: Runtime PM usage count underflow!
[Mon Jun 12 12:59:47 2023] snd_hda_codec_hdmi hdaudioC0D0: Unable to sync register 0x4f0800. -5
[Mon Jun 12 12:59:47 2023] snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD buf size -1
[Mon Jun 12 12:59:47 2023] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=io+mem:owns=io+mem
[Mon Jun 12 12:59:47 2023] pci 0000:52:00.0: Removing from iommu group 2
[Mon Jun 12 12:59:47 2023] pci 0000:52:00.1: Removing from iommu group 2
[Mon Jun 12 12:59:47 2023] pci_bus 0000:52: busn_res: [bus 52] is released
[Mon Jun 12 12:59:47 2023] pci 0000:51:01.0: Removing from iommu group 2
[Mon Jun 12 12:59:47 2023] pci 0000:55:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:47 2023] pci_bus 0000:55: busn_res: [bus 55] is released
[Mon Jun 12 12:59:47 2023] pci 0000:54:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:47 2023] pci 0000:56:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:47 2023] pci_bus 0000:56: busn_res: [bus 56] is released
[Mon Jun 12 12:59:47 2023] pci 0000:54:01.0: Removing from iommu group 3
[Mon Jun 12 12:59:47 2023] pci 0000:57:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:47 2023] pci_bus 0000:57: busn_res: [bus 57] is released
[Mon Jun 12 12:59:47 2023] pci 0000:54:02.0: Removing from iommu group 3
[Mon Jun 12 12:59:47 2023] pci_bus 0000:54: busn_res: [bus 54-57] is released
[Mon Jun 12 12:59:47 2023] pci 0000:53:00.0: Removing from iommu group 3
[Mon Jun 12 12:59:47 2023] pci_bus 0000:53: busn_res: [bus 53-79] is released
[Mon Jun 12 12:59:47 2023] pci 0000:51:04.0: Removing from iommu group 3
[Mon Jun 12 12:59:47 2023] pci_bus 0000:51: busn_res: [bus 51-79] is released
[Mon Jun 12 12:59:47 2023] pci 0000:50:00.0: Removing from iommu group 1
[Mon Jun 12 12:59:48 2023] pcieport 0000:00:07.2: pciehp: Slot(0-1): Card present
[Mon Jun 12 12:59:48 2023] pcieport 0000:00:07.2: pciehp: Slot(0-1): Link Up
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: supports D1 D2
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.2 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: Adding to iommu group 1
[Mon Jun 12 12:59:48 2023] pcieport 0000:00:07.2: ASPM: current common clock configuration is inconsistent, reconfiguring
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: supports D1 D2
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: Adding to iommu group 2
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: supports D1 D2
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: Adding to iommu group 3
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: PCI bridge to [bus 51-79]
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: [10de:1f82] type 00 class 0x030000
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: reg 0x14: [mem 0x00000000-0x0fffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: reg 0x1c: [mem 0x00000000-0x01ffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: reg 0x24: [io  0x0000-0x007f]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: reg 0x30: [mem 0x00000000-0x0007ffff pref]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: PME# supported from D0 D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.2 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: Adding to iommu group 2
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: vgaarb: bridge control possible
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[Mon Jun 12 12:59:48 2023] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.1: [10de:10fa] type 00 class 0x040300
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.1: reg 0x10: [mem 0x00000000-0x00003fff]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.1: Adding to iommu group 2
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: PCI bridge to [bus 52-79]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci_bus 0000:52: busn_res: [bus 52-79] end is updated to 52
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: PCI bridge to [bus 53-79]
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci_bus 0000:53: busn_res: [bus 53-79] end is updated to 79
[Mon Jun 12 12:59:48 2023] pci_bus 0000:51: busn_res: [bus 51-79] end is updated to 79
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: bridge window [mem 0x00100000-0x001fffff 64bit pref] to [bus 53-79] add_size 100000 add_align 100000
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: bridge window [mem 0x00100000-0x001fffff] to [bus 53-79] add_size 100000 add_align 100000
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: BAR 15: assigned [mem 0x6000000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: BAR 14: assigned [mem 0xa2000000-0xaeffffff]
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0: BAR 13: assigned [io  0x6000-0x8fff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: BAR 15: assigned [mem 0x6000000000-0x6017ffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: BAR 14: assigned [mem 0xa2000000-0xa37fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: BAR 14: assigned [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: BAR 15: assigned [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: BAR 13: assigned [io  0x6000-0x6fff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0: BAR 13: assigned [io  0x7000-0x8fff]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: BAR 1: assigned [mem 0x6000000000-0x600fffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: BAR 3: assigned [mem 0x6010000000-0x6011ffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: BAR 0: assigned [mem 0xa2000000-0xa2ffffff]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: BAR 6: assigned [mem 0xa3000000-0xa307ffff pref]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.1: BAR 0: assigned [mem 0xa3080000-0xa3083fff]
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.0: BAR 5: assigned [io  0x6000-0x607f]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0: PCI bridge to [bus 52]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0:   bridge window [io  0x6000-0x6fff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0:   bridge window [mem 0xa2000000-0xa37fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:01.0:   bridge window [mem 0x6000000000-0x6017ffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0:   bridge window [io  0x7000-0x8fff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0:   bridge window [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:48 2023] pci 0000:51:04.0:   bridge window [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0:   bridge window [io  0x6000-0x8fff]
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0:   bridge window [mem 0xa2000000-0xaeffffff]
[Mon Jun 12 12:59:48 2023] pci 0000:50:00.0:   bridge window [mem 0x6000000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pcieport 0000:00:07.2: PCI bridge to [bus 50-79]
[Mon Jun 12 12:59:48 2023] pcieport 0000:00:07.2:   bridge window [io  0x6000-0x8fff]
[Mon Jun 12 12:59:48 2023] pcieport 0000:00:07.2:   bridge window [mem 0xa2000000-0xaf1fffff]
[Mon Jun 12 12:59:48 2023] pcieport 0000:00:07.2:   bridge window [mem 0x6000000000-0x602dffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pcieport 0000:50:00.0: enabling device (0000 -> 0003)
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:01.0: enabling device (0000 -> 0003)
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0: enabling device (0000 -> 0003)
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[Mon Jun 12 12:59:48 2023] nvidia 0000:52:00.0: enabling device (0000 -> 0003)
[Mon Jun 12 12:59:48 2023] nvidia 0000:52:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[Mon Jun 12 12:59:48 2023] pci 0000:52:00.1: D0 power state depends on 0000:52:00.0
[Mon Jun 12 12:59:48 2023] snd_hda_intel 0000:52:00.1: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:48 2023] snd_hda_intel 0000:52:00.1: Disabling MSI
[Mon Jun 12 12:59:48 2023] snd_hda_intel 0000:52:00.1: Handle vga_switcheroo audio client
[Mon Jun 12 12:59:48 2023] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:01.0/0000:52:00.1/sound/card0/input53
[Mon Jun 12 12:59:48 2023] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:01.0/0000:52:00.1/sound/card0/input54
[Mon Jun 12 12:59:48 2023] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:01.0/0000:52:00.1/sound/card0/input55
[Mon Jun 12 12:59:48 2023] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:01.0/0000:52:00.1/sound/card0/input56
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0: pciehp: Slot(4): Card present
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: supports D1 D2
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.2 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: supports D1 D2
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: supports D1 D2
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: Adding to iommu group 3
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: [8086:15d3] type 01 class 0x060400
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: supports D1 D2
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: Adding to iommu group 3
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: PCI bridge to [bus 54-79]
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Mon Jun 12 12:59:48 2023] pci 0000:55:00.0: [1b21:1242] type 00 class 0x0c0330
[Mon Jun 12 12:59:48 2023] pci 0000:55:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[Mon Jun 12 12:59:48 2023] pci 0000:55:00.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:55:00.0: PME# supported from D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:55:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:54:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[Mon Jun 12 12:59:48 2023] pci 0000:55:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: PCI bridge to [bus 55-79]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci_bus 0000:55: busn_res: [bus 55-79] end is updated to 55
[Mon Jun 12 12:59:48 2023] pci 0000:56:00.0: [1b21:1242] type 00 class 0x0c0330
[Mon Jun 12 12:59:48 2023] pci 0000:56:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[Mon Jun 12 12:59:48 2023] pci 0000:56:00.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:56:00.0: PME# supported from D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:56:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:54:01.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[Mon Jun 12 12:59:48 2023] pci 0000:56:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: PCI bridge to [bus 56-79]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci_bus 0000:56: busn_res: [bus 56-79] end is updated to 56
[Mon Jun 12 12:59:48 2023] pci 0000:57:00.0: [1b21:1242] type 00 class 0x0c0330
[Mon Jun 12 12:59:48 2023] pci 0000:57:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[Mon Jun 12 12:59:48 2023] pci 0000:57:00.0: enabling Extended Tags
[Mon Jun 12 12:59:48 2023] pci 0000:57:00.0: PME# supported from D3hot D3cold
[Mon Jun 12 12:59:48 2023] pci 0000:57:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:54:02.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[Mon Jun 12 12:59:48 2023] pci 0000:57:00.0: Adding to iommu group 3
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: PCI bridge to [bus 57-79]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0:   bridge window [io  0x0000-0x0fff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0:   bridge window [mem 0x00000000-0x000fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci_bus 0000:57: busn_res: [bus 57-79] end is updated to 57
[Mon Jun 12 12:59:48 2023] pci_bus 0000:54: busn_res: [bus 54-79] end is updated to 57
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: BAR 14: assigned [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: BAR 15: assigned [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: BAR 13: no space for [io  size 0x3000]
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: BAR 13: failed to assign [io  size 0x3000]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: BAR 14: assigned [mem 0xa3800000-0xa74fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: BAR 15: assigned [mem 0x6018000000-0x601e9fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: BAR 14: assigned [mem 0xa7500000-0xab1fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: BAR 15: assigned [mem 0x601ea00000-0x60253fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: BAR 14: assigned [mem 0xab200000-0xaeefffff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: BAR 15: assigned [mem 0x6025400000-0x602bdfffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: BAR 13: no space for [io  size 0x1000]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: BAR 13: failed to assign [io  size 0x1000]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: BAR 13: no space for [io  size 0x1000]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: BAR 13: failed to assign [io  size 0x1000]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: BAR 13: no space for [io  size 0x1000]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: BAR 13: failed to assign [io  size 0x1000]
[Mon Jun 12 12:59:48 2023] pci 0000:55:00.0: BAR 0: assigned [mem 0xa3800000-0xa3807fff 64bit]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0: PCI bridge to [bus 55]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0:   bridge window [mem 0xa3800000-0xa74fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:00.0:   bridge window [mem 0x6018000000-0x601e9fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:56:00.0: BAR 0: assigned [mem 0xa7500000-0xa7507fff 64bit]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0: PCI bridge to [bus 56]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0:   bridge window [mem 0xa7500000-0xab1fffff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:01.0:   bridge window [mem 0x601ea00000-0x60253fffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:57:00.0: BAR 0: assigned [mem 0xab200000-0xab207fff 64bit]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0: PCI bridge to [bus 57]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0:   bridge window [mem 0xab200000-0xaeefffff]
[Mon Jun 12 12:59:48 2023] pci 0000:54:02.0:   bridge window [mem 0x6025400000-0x602bdfffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0: PCI bridge to [bus 54-57]
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0:   bridge window [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:48 2023] pci 0000:53:00.0:   bridge window [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0: PCI bridge to [bus 53-79]
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0:   bridge window [io  0x7000-0x8fff]
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0:   bridge window [mem 0xa3800000-0xaeffffff]
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0:   bridge window [mem 0x6018000000-0x602bffffff 64bit pref]
[Mon Jun 12 12:59:48 2023] PCI: No. 2 try to assign unassigned res
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0: resource 13 [io  0x7000-0x8fff] released
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0: BAR 13: no space for [io  size 0x3000]
[Mon Jun 12 12:59:48 2023] pcieport 0000:51:04.0: BAR 13: failed to assign [io  size 0x3000]
[Mon Jun 12 12:59:48 2023] pcieport 0000:53:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:48 2023] pcieport 0000:54:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:48 2023] pcieport 0000:54:01.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:48 2023] pcieport 0000:54:02.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:48 2023] pci 0000:55:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:55:00.0: xHCI Host Controller
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:55:00.0: new USB bus registered, assigned bus number 2
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:55:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:55:00.0: new USB bus registered, assigned bus number 3
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:55:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[Mon Jun 12 12:59:48 2023] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[Mon Jun 12 12:59:48 2023] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:48 2023] usb usb2: Product: xHCI Host Controller
[Mon Jun 12 12:59:48 2023] usb usb2: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:48 2023] usb usb2: SerialNumber: 0000:55:00.0
[Mon Jun 12 12:59:48 2023] hub 2-0:1.0: USB hub found
[Mon Jun 12 12:59:48 2023] hub 2-0:1.0: 2 ports detected
[Mon Jun 12 12:59:48 2023] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[Mon Jun 12 12:59:48 2023] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[Mon Jun 12 12:59:48 2023] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:48 2023] usb usb3: Product: xHCI Host Controller
[Mon Jun 12 12:59:48 2023] usb usb3: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:48 2023] usb usb3: SerialNumber: 0000:55:00.0
[Mon Jun 12 12:59:48 2023] hub 3-0:1.0: USB hub found
[Mon Jun 12 12:59:48 2023] hub 3-0:1.0: 2 ports detected
[Mon Jun 12 12:59:48 2023] pci 0000:56:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:56:00.0: xHCI Host Controller
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:56:00.0: new USB bus registered, assigned bus number 6
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:56:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:56:00.0: new USB bus registered, assigned bus number 8
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:56:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[Mon Jun 12 12:59:48 2023] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[Mon Jun 12 12:59:48 2023] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:48 2023] usb usb6: Product: xHCI Host Controller
[Mon Jun 12 12:59:48 2023] usb usb6: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:48 2023] usb usb6: SerialNumber: 0000:56:00.0
[Mon Jun 12 12:59:48 2023] hub 6-0:1.0: USB hub found
[Mon Jun 12 12:59:48 2023] hub 6-0:1.0: 2 ports detected
[Mon Jun 12 12:59:48 2023] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[Mon Jun 12 12:59:48 2023] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[Mon Jun 12 12:59:48 2023] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:48 2023] usb usb8: Product: xHCI Host Controller
[Mon Jun 12 12:59:48 2023] usb usb8: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:48 2023] usb usb8: SerialNumber: 0000:56:00.0
[Mon Jun 12 12:59:48 2023] hub 8-0:1.0: USB hub found
[Mon Jun 12 12:59:48 2023] hub 8-0:1.0: 2 ports detected
[Mon Jun 12 12:59:48 2023] pci 0000:57:00.0: enabling device (0000 -> 0002)
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:57:00.0: xHCI Host Controller
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:57:00.0: new USB bus registered, assigned bus number 9
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:57:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:57:00.0: new USB bus registered, assigned bus number 10
[Mon Jun 12 12:59:48 2023] xhci_hcd 0000:57:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[Mon Jun 12 12:59:48 2023] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[Mon Jun 12 12:59:48 2023] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:48 2023] usb usb9: Product: xHCI Host Controller
[Mon Jun 12 12:59:48 2023] usb usb9: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:48 2023] usb usb9: SerialNumber: 0000:57:00.0
[Mon Jun 12 12:59:48 2023] hub 9-0:1.0: USB hub found
[Mon Jun 12 12:59:48 2023] hub 9-0:1.0: 2 ports detected
[Mon Jun 12 12:59:48 2023] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[Mon Jun 12 12:59:48 2023] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[Mon Jun 12 12:59:48 2023] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Mon Jun 12 12:59:48 2023] usb usb10: Product: xHCI Host Controller
[Mon Jun 12 12:59:48 2023] usb usb10: Manufacturer: Linux 6.2.0-20-generic xhci-hcd
[Mon Jun 12 12:59:48 2023] usb usb10: SerialNumber: 0000:57:00.0
[Mon Jun 12 12:59:48 2023] hub 10-0:1.0: USB hub found
[Mon Jun 12 12:59:48 2023] hub 10-0:1.0: 2 ports detected
[Mon Jun 12 12:59:49 2023] usb 10-1: new SuperSpeed USB device number 2 using xhci_hcd
[Mon Jun 12 12:59:49 2023] usb 10-1: New USB device found, idVendor=0b95, idProduct=1790, bcdDevice= 1.00
[Mon Jun 12 12:59:49 2023] usb 10-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Mon Jun 12 12:59:49 2023] usb 10-1: Product: AX88179
[Mon Jun 12 12:59:49 2023] usb 10-1: Manufacturer: ASIX Elec. Corp.
[Mon Jun 12 12:59:49 2023] usb 10-1: SerialNumber: 0098BB1E1EF97C
[Mon Jun 12 12:59:50 2023] usb 9-2: new full-speed USB device number 3 using xhci_hcd
[Mon Jun 12 12:59:50 2023] ax88179_178a 10-1:1.0 eth0: register 'ax88179_178a' at usb-0000:57:00.0-1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 98:bb:1e:1e:f9:7c
[Mon Jun 12 12:59:50 2023] ax88179_178a 10-1:1.0 enx98bb1e1ef97c: renamed from eth0
[Mon Jun 12 12:59:50 2023] usb 9-2: New USB device found, idVendor=1532, idProduct=0f1a, bcdDevice= 2.00
[Mon Jun 12 12:59:50 2023] usb 9-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Mon Jun 12 12:59:50 2023] usb 9-2: Product: Razer Core X Chroma
[Mon Jun 12 12:59:50 2023] usb 9-2: Manufacturer: Razer
[Mon Jun 12 12:59:50 2023] input: Razer Razer Core X Chroma as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:04.0/0000:53:00.0/0000:54:02.0/0000:57:00.0/usb9/9-2/9-2:1.0/0003:1532:0F1A.0010/input/input57
[Mon Jun 12 12:59:50 2023] hid-generic 0003:1532:0F1A.0010: input,hidraw5: USB HID v1.11 Keyboard [Razer Razer Core X Chroma] on usb-0000:57:00.0-2/input0
[Mon Jun 12 12:59:50 2023] input: Razer Razer Core X Chroma Keyboard as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:04.0/0000:53:00.0/0000:54:02.0/0000:57:00.0/usb9/9-2/9-2:1.1/0003:1532:0F1A.0011/input/input58
[Mon Jun 12 12:59:50 2023] input: Razer Razer Core X Chroma as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:04.0/0000:53:00.0/0000:54:02.0/0000:57:00.0/usb9/9-2/9-2:1.1/0003:1532:0F1A.0011/input/input59
[Mon Jun 12 12:59:50 2023] hid-generic 0003:1532:0F1A.0011: input,hidraw6: USB HID v1.11 Keyboard [Razer Razer Core X Chroma] on usb-0000:57:00.0-2/input1
[Mon Jun 12 12:59:50 2023] input: Razer Razer Core X Chroma as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:04.0/0000:53:00.0/0000:54:02.0/0000:57:00.0/usb9/9-2/9-2:1.2/0003:1532:0F1A.0012/input/input60
[Mon Jun 12 12:59:50 2023] hid-generic 0003:1532:0F1A.0012: input,hidraw7: USB HID v1.11 Mouse [Razer Razer Core X Chroma] on usb-0000:57:00.0-2/input2
[Mon Jun 12 12:59:53 2023] ax88179_178a 10-1:1.0 enx98bb1e1ef97c: ax88179 - Link status is: 1
[Mon Jun 12 12:59:53 2023] IPv6: ADDRCONF(NETDEV_CHANGE): enx98bb1e1ef97c: link becomes ready
[Mon Jun 12 12:59:53 2023] usb 2-1: new full-speed USB device number 2 using xhci_hcd
[Mon Jun 12 12:59:53 2023] usb 2-1: New USB device found, idVendor=1532, idProduct=0016, bcdDevice= 1.00
[Mon Jun 12 12:59:53 2023] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Mon Jun 12 12:59:53 2023] usb 2-1: Product: Razer DeathAdder
[Mon Jun 12 12:59:53 2023] usb 2-1: Manufacturer: Razer
[Mon Jun 12 12:59:53 2023] input: Razer Razer DeathAdder as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:04.0/0000:53:00.0/0000:54:00.0/0000:55:00.0/usb2/2-1/2-1:1.0/0003:1532:0016.0013/input/input61
[Mon Jun 12 12:59:53 2023] hid-generic 0003:1532:0016.0013: input,hidraw8: USB HID v1.11 Mouse [Razer Razer DeathAdder] on usb-0000:55:00.0-1/input0
[Mon Jun 12 12:59:57 2023] thunderbolt 0000:00:0d.3: 1: DROM data CRC32 mismatch (expected: 0x5a4d3cd4, got: 0xbb498e7d), continuing
[Mon Jun 12 12:59:57 2023] thunderbolt 1-1: ignoring unnecessary extra entries in DROM
[Mon Jun 12 12:59:57 2023] thunderbolt 0000:00:0d.3: 1: DROM buffer overrun
[Mon Jun 12 12:59:57 2023] thunderbolt 0000:00:0d.3: 1: parsing DROM failed
[Mon Jun 12 13:00:04 2023] thunderbolt 1-1: new device found, vendor=0x127 device=0x2
[Mon Jun 12 13:00:04 2023] thunderbolt 1-1: Razer Core X Chroma
[Mon Jun 12 13:00:05 2023] systemd-journald[286]: File /var/log/journal/f16fa4a6b7204c1f9d0e1887d4d1cc9c/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[Mon Jun 12 13:00:05 2023] rfkill: input handler enabled
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c57d:0:0:0x00000023
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to tear down display engine channel
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to free DMA context
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to unmap memory
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to free DMA memory
[Mon Jun 12 13:00:05 2023] nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
[Mon Jun 12 13:00:06 2023] usb 5-2: current rate 16000 is different from the runtime rate 48000
[Mon Jun 12 13:00:08 2023] rfkill: input handler disabled
[Mon Jun 12 13:00:10 2023] usb 4-10: new full-speed USB device number 7 using xhci_hcd
[Mon Jun 12 13:00:10 2023] usb 4-10: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[Mon Jun 12 13:00:10 2023] usb 4-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
I can also only see the Razor enclosure is shutting down spontaneously without any errors. The nvidia driver is not hotplug capable so it woes.
Excellent point, I hadn’t considered that the NVIDIA driver was not hotplug capable.
So, it begs the question, is there an NVIDIA driver that is hotplug capable for the GeForce GTX 1650 ? Or, do I have to configure this somehow ?
Adding more info:
beadon@semiauto:~$ hwinfo --gfxcard --short
graphics card:
                       nVidia TU117 [GeForce GTX 1650]
                       Intel TigerLake-LP GT2 [Iris Xe Graphics]
Primary display adapter: #26
beadon@semiauto:~$ sudo lshw -C display
  *-display
       description: VGA compatible controller
       product: TigerLake-LP GT2 [Iris Xe Graphics]
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       logical name: /dev/fb0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
       configuration: depth=32 driver=i915 latency=0 mode=3840x2400 resolution=3840,2400 visual=truecolor xres=3840 yres=2400
       resources: iomemory:600-5ff iomemory:400-3ff irq:216 memory:604c000000-604cffffff memory:4000000000-401fffffff ioport:4000(size=64) memory:c0000-dffff memory:4100000000-4106ffffff memory:4020000000-40ffffffff
  *-display
       product: TU117 [GeForce GTX 1650]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:52:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
       configuration: driver=nvidia latency=0
       resources: iomemory:600-5ff iomemory:600-5ff irq:17 memory:a2000000-a2ffffff memory:6000000000-600fffffff memory:6010000000-6011ffffff ioport:6000(size=128) memory:a3000000-a307ffff
For those following along, one way to update drivers is to use ubuntu’s update-manager, running from the CLI gives us some insight when we switch to the “Additional Drivers” tab, and find that this system is using driver 525 (proprietary) instead of 530 (latest proprietary).
When attempting the upgrade to 530 (proprietary) is see this :
beadon@semiauto:~$ update-manager
(software-properties-gtk:35107): Gtk-WARNING **: 09:26:20.979: Failed to set text '<big><b>Error while applying changes</b></big>
pk-client-error-quark: The following packages have unmet dependencies:
  linux-modules-nvidia-530-6.2.0-20-generic: Depends: nvidia-kernel-common-530 (>= 530.41.03) but it is not installable
  nvidia-driver-530: Depends: nvidia-kernel-common-530 (<= 530.41.03-1) but it is not installable
  linux-modules-nvidia-530-generic-hwe-22.04: Depends: nvidia-kernel-common-530 (>= 530.41.03) but it is not installable
 (268)' from markup due to error parsing markup: Error on line 5 char 59: “=” is not a valid character following a “<” character; it may not begin an element name
(software-properties-gtk:35107): Gtk-WARNING **: 09:26:21.003: Failed to set text '<big><b>Error while applying changes</b></big>
Existing the update manager, and doing the apt install of the missing package will resolve this issue:
sudo apt install nvidia-kernel-common-530
From there I am able to update to the latest using ubuntu’s update manager.
It seems like there is detection in some parts of gnome for DisplayPort, but others require HDMI. I and doing some digging here. What I am seeing is that using HDMI I can see all of the displays enumerated, but what I use DisplayPort only, then only the single laptop monitor is detected. This seems like a gnome desktop / wm display setting issue, and not an NVIDIA driver problem since I have seen one of the DisplayPort connected displays work with the Ubuntu desktop – but only until I disconnected to HDMI … more digging required.
Insights welcome.
It appears there was a very recent release of display drivers to update to v535 ( reference : Linux x64 (AMD64/EM64T) Display Driver | 535.54.03 | Linux 64-bit | NVIDIA ). Notably, there is a bugfix identified as " * Fixed a bug that caused modesets to fail in some Wayland configurations." this might be related.
Currently the nvidia-kernel-common-535 package is not available, I’ll check in with the package maintainer.
Looks like I got another crash here – same setup. This time I was sure that nothing was tampering with the USB-C connector (Thunderbolt). Somehow the link was just dropped. It’s not clear to me why the system dropped the link suddenly.
nvidia-bug-report.log.gz
nvidia-bug-report.log.gz (420.5 KB)
Uncertain how to do a capture, but I am using eGPU Core X Chroma with Nvidia 3080 Ti that suffers random disconnects (two monitors).
using driver 536.23 release date 6/14/23
this condition only started in June 2023 and was curious if this bug may be impacting other NVIDIA products (graphics cards) other than the cited one in this post/series
Yes, I am experiencing this as well. I have attached a USB LED light to the desk to see when this occurs. It appears that the OS determines it is “inactive” or “not responding” and resets the connection. I am not sure how this occurs, but it appears to occur regardless of human presence, so I believe it may be due to some kind of driver condition. Difficult to trace at the moment.
without looking at logs or code. I am testing previous software releases
531.68-desktop-win10-win11-64bit-international-dch-whql.exe - April 2023
  • same results with monitor disconnect
    531.29-desktop-win10-win11-64bit-international-dch-whql.exe
Starting to believe this could be another issue within Windows, the RAZER X CHROMA case
not sure what to do - trying an even older version of NVIDIA code from March 2023
There are a few technologies on my laptops
  • Windows 11
  • NVIDIA graphics drivers
  • Razer CORE X Chroma Case
  • GIGAByte Nvidia 3080 TI card 12GB GDDR6X Express 4.0 ATX Video Card GV-N308TGAMING OC-12GD
Removed the Razer Core X Chroma and connected direct to laptop with the 536.23 driver. one monitor on HDMI for now. Will do a DP to thunderbolt connect for second monitor. Everything is stable.
Somewhere in the chain from laptop → thunderbolt 3 port -->cable run (less than 2 ft cable (thunderbolt male - thunderbolt male) → Core X Chroma → Graphics card
disconnect from the thunderbolt port or somewhere down the line to the graphics card. I put a ticket in with Razer to let hem know but I am about to give up on this CORE X Chroma box as a solution. I will just buy a new system with the graphics card that I want in it like I have for years past instead of deal with the unstable eGPU
I suspect 2 areas :
  1. the thunderbolt connection being unsteady
  2. poor responsiveness in the Chroma X enclosure - causing the OS to force it to “restart” (reconnect, re-establish connections again).
I have a ticket open with Razer, but they’re unwilling to assist since I am using Linux. This makes deeper troubleshooting difficult.
I have switched to Xorg:
started by checking cli:
echo $XDG_SESSION_TYPE
Then , had to manually change the gdm config:
/etc/gdm3/custom.conf
Modified:
[daemon]
# Uncomment the line below to force the login screen to use Xorg
WaylandEnable=false
