eGPU Failing in Ubuntu 22 (X freezes)
Hi
I have a Dell Precision 5760 with Ubuntu 22.04 and Linux 5.15.0-46 connected to an Aorus Gamebox with a GTX 3090 and around 1 minute after booting the external monitor disconnects and x-freezes.
My theory is that there is something wrong related to power since I can hear the fan going off right before the computer freezes.
nvidia-detector
nvidia-driver-515
LOGS:
16:20:19 systemd-logind: Power key pressed.
16:20:05 cat: [0905/162005.155361:ERROR:directory_reader_posix.cc(42)] opendir /home/jpichardo/.config/BraveSoftware/Brave-Browser/Crash Reports/attachments/8451266a-508c-4f4b-a1a4-8d96c2dd927a: No such file or directory (2)
16:20:04 boltd: [00395979-e610-AORUS GAMING BOX           ] udev: device changed: authorized -> authorized
16:20:04 kernel: thunderbolt 0-301: GIGABYTE AORUS GAMING BOX
16:20:04 boltd: [00395979-e610-AORUS GAMING BOX           ] connected: authorized (/sys/devices/pci0000:00/0000:00:0d.2/domain0/0-0/0-1/0-301)
16:19:58 kernel: PKRU: 55555554
16:19:58 kernel: CR2: ffffaf01cb690000 CR3: 0000000128c16006 CR4: 0000000000770ee0
16:19:58 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
16:19:58 kernel: FS:  00007f3d8fdb5a80(0000) GS:ffff9325af680000(0000) knlGS:0000000000000000
16:19:58 kernel: R13: ffffaf01c4c2fb00 R14: ffff931e61dfb008 R15: ffffffffffffffff
16:19:58 kernel: R10: 0000000000000001 R11: ffffffffffffffff R12: 0000000000000002
16:19:58 kernel: RBP: 00000000000006bc R08: 0000000000000001 R09: 0000000080000000
16:19:58 kernel: RDX: ffffaf01cb690000 RSI: 00000000000006bc RDI: ffff931e6e6f7c20
16:19:58 kernel: RAX: 0000000000000001 RBX: ffff931e6e6f7c20 RCX: 0000000000000001
16:19:58 kernel: RSP: 0018:ffffaf01c4c2f900 EFLAGS: 00010202
16:19:58 kernel: Code: 00 c7 44 24 0c 04 00 00 00 e8 37 99 01 00 0f ae f8 8b 43 5c 89 ab bc 00 00 00 85 c0 74 19 b8 01 00 00 00 66 90 48 8b 54 c3 58 <89> 2a 89 c2 48 83 c0 01 39 53 5c 77 ee 48 83 c4 18 5b 5d c3 0f 1f
16:19:58 kernel: RIP: 0010:_nv000141kms+0xd5/0x110 [nvidia_modeset]
16:19:58 kernel: ---[ end trace 939b10a52ec988f2 ]---
16:19:58 kernel:  int3403_thermal ecdh_generic nls_iso8859_1 nvidia(POE) cfg80211 mei joydev hid_multitouch mc cros_ec pmt_class soundcore intel_soc_dts_iosf i2c_algo_bit typec mac_hid ecc int340x_thermal_zone acpi_thermal_rel sparse_keymap acpi_pad acpi_tad drm_kms_helper cec rc_core fb_sys_fops syscopyarea sysfillrect sysimgblt parport_pc ppdev lp parport drm ramoops reed_solomon pstore_blk mtd pstore_zone efi_pstore ip_tables x_tables autofs4 usbhid r8153_ecm cdc_ether usbnet r8152 mii hid_sensor_custom hid_sensor_hub intel_ishtp_loader intel_ishtp_hid hid_generic nvme nvme_core rtsx_pci_sdmmc crc32_pclmul ahci libahci i2c_i801 thunderbolt rtsx_pci i2c_smbus intel_ish_ipc intel_lpss_pci intel_lpss intel_ishtp vmd idma64 intel_pmt xhci_pci xhci_pci_renesas i2c_hid_acpi i2c_hid wmi hid video pinctrl_tigerlake
16:19:58 kernel: Modules linked in: xt_conntrack nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack_netlink nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xfrm_user xfrm_algo nft_counter xt_addrtype nft_compat nf_tables libcrc32c nfnetlink br_netfilter bridge stp llc ccm rfcomm snd_ctl_led cmac overlay algif_hash algif_skcipher af_alg bnep snd_soc_sof_sdw snd_soc_intel_hda_dsp_common snd_soc_intel_sof_maxim_common sch_fq_codel ipmi_devintf ipmi_msghandler snd_soc_rt711 snd_soc_rt715 snd_soc_rt1308_sdw msr regmap_sdw evdi(OE) nvidia_uvm(POE) dell_rbtn dell_laptop snd_soc_dmic snd_sof_pci_intel_tgl snd_sof_intel_hda_common mei_hdcp soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda intel_rapl_msr snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp snd_soc_core coretemp snd_compress snd_hda_codec_hdmi ac97_bus snd_pcm_dmaengine snd_seq_midi
16:19:58 kernel:  </TASK>
16:19:58 kernel: Call Trace:
16:19:58 kernel: Hardware name: Dell Inc. Precision 5760/0XKFJ4, BIOS 1.2.0 06/15/2021
16:19:58 kernel: CPU: 10 PID: 2149 Comm: Xorg Tainted: P           OE     5.15.0-46-generic #49-Ubuntu
16:19:58 kernel: Oops: 0002 [#1] SMP NOPTI
16:19:58 kernel: PGD 100000067 P4D 100000067 PUD 1001e0067 PMD 0
16:19:58 kernel: #PF: error_code(0x0002) - not-present page
16:19:58 kernel: BUG: unable to handle page fault for address: ffffaf01cb690000
16:19:57 Xorg: (EE) client bug: timer event16 hold: scheduled expiry is in the past (-1729ms), your system is too slow
16:19:57 boltd: [0031b089-184b-AORUS GAMING BOX           ] udev: device changed: authorized -> authorized
16:19:57 kernel: thunderbolt 0-1: GIGABYTE AORUS GAMING BOX
16:19:57 boltd: [0031b089-184b-AORUS GAMING BOX           ] parent is 707b1017-f97c...
16:19:55 ModemManager: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:02.0/0000:09:00.0/usb10/10-2': not supported by any plugin
16:19:53 systemd-udevd: Using default interface naming scheme 'v249'.
16:19:53 NetworkManager: <info>  [1662412793.4727] device (enxb42e99f43f46): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
16:19:53 kernel: r8152 10-2:1.0 enxb42e99f43f46: renamed from eth0
16:19:53 mtp-probe: bus: 10, device: 2 was not an MTP device
16:19:53 kernel: r8152 10-2:1.0 eth0: v1.12.12
16:19:53 mtp-probe: checking bus 10, device 2: "/sys/devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:02.0/0000:09:00.0/usb10/10-2"
16:19:53 NetworkManager: <info>  [1662412793.3989] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/7)
16:19:53 kernel: r8152 10-2:1.0: load rtl8153b-2 v1 10/23/19 successfully
16:19:53 kernel: usb 10-2: reset SuperSpeed USB device number 2 using xhci_hcd
16:19:52 mtp-probe: bus: 5, device: 3 was not an MTP device
16:19:52 systemd-logind: Watching system buttons on /dev/input/event23 (Razer Razer Pro Type)
16:19:51 kernel: bus: 5, device: 3 was not an MTP device
16:19:51 kernel: checking bus 5, device 3: "/sys/devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:00.0/0000:07:00.0/usb5/5-2"
16:19:51 kernel: hid-generic 0003:1044:7A49.0013: input,hidraw8: USB HID v1.11 Mouse [HOLTEK USB-HID Device] on usb-0000:07:00.0-2/input2
16:19:51 kernel: input: HOLTEK USB-HID Device as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:00.0/0000:07:00.0/usb5/5-2/5-2:1.2/0003:1044:7A49.0013/input/input53
16:19:51 mtp-probe: checking bus 5, device 2: "/sys/devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:00.0/0000:07:00.0/usb5/5-1"
16:19:51 kernel: usbhid 5-2:1.1: couldn't find an input interrupt endpoint
16:19:51 kernel: hid-generic 0003:1044:7A49.0012: hiddev0,hidraw7: USB HID v1.11 Device [HOLTEK USB-HID Device] on usb-0000:07:00.0-2/input0
16:19:51 kernel: usb 5-2: SerialNumber: 000000000000
16:19:51 mtp-probe: bus: 7, device: 2 was not an MTP device
16:19:51 systemd-logind: Watching system buttons on /dev/input/event30 (Razer Razer Pro Click Keyboard)
16:19:51 kernel: usb 5-2: new full-speed USB device number 3 using xhci_hcd
16:19:51 kernel: hid-generic 0003:1532:0077.0011: input,hidraw6: USB HID v1.11 Keyboard [Razer Razer Pro Click] on usb-0000:08:00.0-1/input2
16:19:51 kernel: input: Razer Razer Pro Click as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:01.0/0000:08:00.0/usb7/7-1/7-1:1.2/0003:1532:0077.0011/input/input52
16:19:51 kernel: hid-generic 0003:1532:0077.0010: input,hidraw5: USB HID v1.11 Keyboard [Razer Razer Pro Click] on usb-0000:08:00.0-1/input1
16:19:51 kernel: input: Razer Razer Pro Click as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:01.0/0000:08:00.0/usb7/7-1/7-1:1.1/0003:1532:0077.0010/input/input51
16:19:51 kernel: hid-generic 0003:1532:0249.000F: input,hidraw4: USB HID v1.11 Keyboard [Razer Razer Pro Type] on usb-0000:07:00.0-1/input2
16:19:51 kernel: input: Razer Razer Pro Click Keyboard as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:01.0/0000:08:00.0/usb7/7-1/7-1:1.1/0003:1532:0077.0010/input/input50
16:19:51 kernel: hid-generic 0003:1532:0249.000D: input,hidraw3: USB HID v1.11 Keyboard [Razer Razer Pro Type] on usb-0000:07:00.0-1/input1
16:19:51 kernel: input: Razer Razer Pro Type as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:00.0/0000:07:00.0/usb5/5-1/5-1:1.1/0003:1532:0249.000D/input/input47
16:19:51 kernel: usb 7-1: Manufacturer: Razer
16:19:51 kernel: input: Razer Razer Pro Type Keyboard as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:00.0/0000:07:00.0/usb5/5-1/5-1:1.1/0003:1532:0249.000D/input/input46
16:19:51 kernel: hid-generic 0003:1532:0249.000C: input,hidraw1: USB HID v1.11 Mouse [Razer Razer Pro Type] on usb-0000:07:00.0-1/input0
16:19:51 kernel: input: Razer Razer Pro Type as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:00.0/0000:07:00.0/usb5/5-1/5-1:1.0/0003:1532:0249.000C/input/input45
16:19:51 kernel: usb 5-1: Manufacturer: Razer
16:19:50 Xorg: (EE) NVIDIA(GPU-1): WAIT (2, 8, 0x8000, 0x00026df8, 0x000271c4)
16:19:50 kernel: usb 5-1: new full-speed USB device number 2 using xhci_hcd
16:19:50 systemd: Reached target Sound Card.
16:19:50 snapd: udevmon.go:149: udev event error: Unable to parse uevent, err: cannot parse libudev event: invalid env data
16:19:50 kernel: input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:01.0/0000:04:00.1/sound/card0/input44
16:19:50 kernel: hub 10-0:1.0: 2 ports detected
16:19:50 kernel: usb usb10: SerialNumber: 0000:09:00.0
16:19:50 kernel: xhci_hcd 0000:09:00.0: Host supports USB 3.1 Enhanced SuperSpeed
16:19:50 kernel: hub 9-0:1.0: 2 ports detected
16:19:50 kernel: usb usb9: SerialNumber: 0000:09:00.0
16:19:50 kernel: xhci_hcd 0000:09:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
16:19:50 kernel: pci 0000:09:00.0: enabling device (0000 -> 0002)
16:19:50 kernel: hub 8-0:1.0: 2 ports detected
16:19:50 kernel: usb usb8: SerialNumber: 0000:08:00.0
16:19:50 kernel: xhci_hcd 0000:08:00.0: Host supports USB 3.1 Enhanced SuperSpeed
16:19:50 kernel: hub 7-0:1.0: 2 ports detected
16:19:50 kernel: usb usb7: SerialNumber: 0000:08:00.0
16:19:50 kernel: xhci_hcd 0000:08:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
16:19:50 kernel: pci 0000:08:00.0: enabling device (0000 -> 0002)
16:19:50 kernel: hub 6-0:1.0: 2 ports detected
16:19:50 kernel: usb usb6: SerialNumber: 0000:07:00.0
16:19:50 kernel: xhci_hcd 0000:07:00.0: Host supports USB 3.1 Enhanced SuperSpeed
16:19:50 kernel: hub 5-0:1.0: 2 ports detected
16:19:50 kernel: usb usb5: SerialNumber: 0000:07:00.0
16:19:50 kernel: xhci_hcd 0000:07:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
16:19:50 kernel: pci 0000:07:00.0: enabling device (0000 -> 0002)
16:19:50 kernel: pcieport 0000:06:03.0: enabling device (0000 -> 0002)
16:19:50 kernel: snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
16:19:50 kernel: pci 0000:04:00.1: D0 power state depends on 0000:04:00.0
16:19:50 kernel: nvidia 0000:04:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
16:19:50 kernel: pcieport 0000:03:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
16:19:50 kernel: pci 0000:02:00.0:   bridge window [mem 0x6110000000-0x613dffffff 64bit pref]
16:19:50 kernel: PCI: No. 2 try to assign unassigned res
16:19:50 kernel: pcieport 0000:00:07.0:   bridge window [mem 0x6110000000-0x613dffffff 64bit pref]
16:19:50 kernel: pci_bus 0000:03: busn_res: [bus 03-2b] end is updated to 2b
16:19:50 kernel: pci 0000:06:03.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
16:19:50 kernel: pci_bus 0000:09: busn_res: [bus 09-2b] end is updated to 09
16:19:50 kernel: pci 0000:06:02.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
16:19:50 kernel: pci_bus 0000:08: busn_res: [bus 08-2b] end is updated to 08
16:19:50 kernel: pci 0000:06:01.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
16:19:50 kernel: pci_bus 0000:07: busn_res: [bus 07-2b] end is updated to 07
16:19:50 kernel: pci 0000:06:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
16:19:50 kernel: pci_bus 0000:04: busn_res: [bus 04-2b] end is updated to 04
16:19:50 kernel: pci 0000:03:01.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
16:19:50 kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
16:19:50 kernel: pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
16:19:50 kernel: pcieport 0000:00:07.0: ASPM: current common clock configuration is inconsistent, reconfiguring
16:19:50 kernel: pci 0000:02:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
16:19:50 kernel: pcieport 0000:00:07.0: pciehp: Slot(0): Link Up
16:19:50 kernel: pci_bus 0000:03: busn_res: [bus 03-2b] is released
16:19:50 kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=io+mem:owns=io+mem
16:19:50 kernel: snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD buf size -1
16:19:49 acpid: input device has been disconnected, fd 11
16:19:49 snapd: udevmon.go:149: udev event error: Unable to parse uevent, err: cannot parse libudev event: invalid env data
16:19:49 acpid: input device has been disconnected, fd 10
16:19:49 acpid: input device has been disconnected, fd 12
16:19:49 acpid: input device has been disconnected, fd 14
16:19:49 acpid: input device has been disconnected, fd 15
16:19:49 acpid: input device has been disconnected, fd 16
16:19:49 kernel: xhci_hcd 0000:07:00.0: USB bus 5 deregistered
16:19:49 kernel: usb 5-2: USB disconnect, device number 3
16:19:49 acpid: input device has been disconnected, fd 23
16:19:48 kernel: usb 5-1: USB disconnect, device number 2
16:19:48 kernel: xhci_hcd 0000:07:00.0: remove, state 1
16:19:48 kernel: usb usb6: USB disconnect, device number 1
16:19:48 kernel: xhci_hcd 0000:07:00.0: remove, state 4
16:19:48 kernel: thunderbolt 0-1: device disconnected
16:19:48 boltd: [0031b089-184b-AORUS GAMING BOX           ] disconnected (/sys/devices/pci0000:00/0000:00:0d.2/domain0/0-0/0-1)
16:19:48 acpid: input device has been disconnected, fd 32
16:19:48 kernel: usb 7-1: USB disconnect, device number 2
16:19:48 kernel: xhci_hcd 0000:08:00.0: remove, state 1
16:19:48 kernel: usb usb8: USB disconnect, device number 1
16:19:48 kernel: xhci_hcd 0000:08:00.0: remove, state 4
16:19:48 kernel: usb usb9: USB disconnect, device number 1
16:19:48 kernel: xhci_hcd 0000:09:00.0: remove, state 4
16:19:48 NetworkManager: <info>  [1662412788.1901] device (enxb42e99f43f46): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
16:19:48 kernel: xhci_hcd 0000:09:00.0: xHCI host controller not responding, assume dead
16:19:48 kernel: usb 10-2: USB disconnect, device number 2
16:19:48 kernel: xhci_hcd 0000:09:00.0: remove, state 1
16:19:48 kernel: NVRM: A GPU crash dump has been created. If possible, please run
NVRM: nvidia-bug-report.sh as root to collect this data before
NVRM: the NVIDIA kernel module is unloaded.
16:19:48 kernel: pcieport 0000:06:03.0: can't change power state from D3cold to D0 (config space inaccessible)
16:19:48 kernel: NVRM: GPU 0000:04:00.0: GPU has fallen off the bus.
16:19:48 kernel: hrtimer: interrupt took 181116742 ns
16:19:45 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.126" (uid=1000 pid=5729 comm="/opt/brave.com/brave/brave --type=gpu-process --en" label="unconfined")
16:19:40 guake: Guake tabs saved to /home/jpichardo/.config/guake/session.json
16:19:38 systemd: Started VTE child process 7764 launched by guake process 6630.
16:19:38 guake: Spawning new terminal at /home/jpichardo/Documents/projects/classdojo
16:19:37 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.126" (uid=1000 pid=5729 comm="/opt/brave.com/brave/brave --type=gpu-process --en" label="unconfined")
16:19:36 guake: Guake tabs saved to /home/jpichardo/.config/guake/session.json
16:19:36 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.126" (uid=1000 pid=5729 comm="/opt/brave.com/brave/brave --type=gpu-process --en" label="unconfined")
16:19:24 gnome-shell: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x60000b
16:19:24 systemd: Started VTE child process 6713 launched by guake process 6630.
16:19:24 guake: Spawning new terminal at /home/jpichardo
16:19:24 systemd: Started VTE child process 6710 launched by guake process 6630.
16:19:24 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.68" (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:19:24 systemd: Started VTE child process 6691 launched by guake process 6630.
16:19:24 systemd: Started Application launched by gsd-media-keys.
16:19:23 guake: Guake initialized
16:19:23 systemd: Started VTE child process 6639 launched by guake process 6630.
16:19:23 guake: Spawning new terminal at /home/jpichardo
16:19:23 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.68" (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:19:23 guake: Gtk 3.24.33
16:19:23 systemd: Started Application launched by gsd-media-keys.
16:19:21 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.126" (uid=1000 pid=5729 comm="/opt/brave.com/brave/brave --type=gpu-process --en" label="unconfined")
16:19:20 gnome-shell: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55939db0b850] is on because it needs an allocation.
16:19:15 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.126" (uid=1000 pid=5729 comm="/opt/brave.com/brave/brave --type=gpu-process --en" label="unconfined")
16:18:55 Xorg: (EE) event30 - Razer Razer Pro Click: client bug: event processing lagging behind by 25ms, your system is too slow
16:18:49 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.68" (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:18:39 systemd: systemd-timedated.service: Deactivated successfully.
16:18:37 gnome-shell: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55939db0b850] is on because it needs an allocation.
16:18:36 cat: [5691:5691:0905/161836.473947:ERROR:object_proxy.cc(623)] Failed to call method: org.freedesktop.ScreenSaver.GetActive: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NotSupported: This method is not implemented
16:18:36 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.68" (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:18:35 gnome-shell: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55939db0b850] is on because it needs an allocation.
16:18:34 cat: [5691:5691:0905/161834.880153:ERROR:profile_attributes_storage.cc(849)] Failed to PNG encode the image.
16:18:34 gnome-keyring-d: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
16:18:34 systemd: Started Application launched by gnome-shell.
16:18:33 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.seahorse.Application'
16:18:31 systemd: Started snap.code.code.5f1edb30-76d4-4250-a6b7-f7fccf79d941.scope.
16:18:31 gnome-shell: Wrong number of result metas returned by search provider org.gnome.seahorse.Application.desktop: expected 1 but got 0
16:18:31 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.seahorse.Application'
16:18:30 nautilus: Connecting to org.freedesktop.Tracker3.Miner.Files
16:18:30 systemd: Started GNOME Terminal Server.
16:18:30 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.Terminal'
16:18:30 systemd: Starting GNOME Terminal Server...
16:18:30 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.43' (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:18:28 gnome-shell: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
16:18:25 Xorg: (EE) event30 - Razer Razer Pro Click: client bug: event processing lagging behind by 23ms, your system is too slow
16:18:09 systemd: Started Time & Date Service.
16:18:09 dbus-daemon: [system] Successfully activated service 'org.freedesktop.timedate1'
16:18:09 systemd: Starting Time & Date Service...
16:18:09 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.31' (uid=0 pid=1282 comm="/usr/lib/snapd/snapd " label="unconfined")
16:17:58 systemd: Finished Download data for packages that failed at package install time.
16:17:01 cron: pam_unix(cron:session): session closed for user root
16:15:10 systemd: Started Application launched by gnome-session-binary.
16:14:44 gnome-shell: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
16:14:44 Xorg: (WW) Option "xkb_options" requires a string value
16:14:44 systemd-logind: Watching system buttons on /dev/input/event31 (Razer Razer Pro Click Keyboard)
16:14:44 Xorg: (**) Option "Device" "/dev/input/event30"
16:14:44 mtp-probe: bus: 7, device: 2 was not an MTP device
16:14:44 Xorg: (II) Using input driver 'libinput' for 'Razer Razer Pro Click'
16:14:43 systemd-logind: Watching system buttons on /dev/input/event257 (Razer Razer Pro Click)
16:14:43 Xorg: (II) Using input driver 'libinput' for 'Razer Razer Pro Click'
16:14:43 kernel: hid-generic 0003:1532:0077.000B: input,hidraw8: USB HID v1.11 Keyboard [Razer Razer Pro Click] on usb-0000:08:00.0-1/input2
16:14:43 mtp-probe: bus: 7, device: 2 was not an MTP device
16:14:43 kernel: input: Razer Razer Pro Click as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:01.0/0000:08:00.0/usb7/7-1/7-1:1.2/0003:1532:0077.000B/input/input37
16:14:43 kernel: hid-generic 0003:1532:0077.000A: input,hidraw7: USB HID v1.11 Keyboard [Razer Razer Pro Click] on usb-0000:08:00.0-1/input1
16:14:43 kernel: input: Razer Razer Pro Click as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:01.0/0000:08:00.0/usb7/7-1/7-1:1.1/0003:1532:0077.000A/input/input36
16:14:43 kernel: hid-generic 0003:1532:0077.0009: input,hidraw6: USB HID v1.11 Mouse [Razer Razer Pro Click] on usb-0000:08:00.0-1/input0
16:14:43 kernel: input: Razer Razer Pro Click as /devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:04.0/0000:05:00.0/0000:06:01.0/0000:08:00.0/usb7/7-1/7-1:1.0/0003:1532:0077.0009/input/input34
16:14:43 kernel: usb 7-1: Manufacturer: Razer
16:14:42 gnome-shell: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
16:14:12 pkexec: jpichardo: Executing command [USER=root] [TTY=unknown] [CWD=/home/jpichardo] [COMMAND=/usr/lib/update-notifier/package-system-locked]
16:14:10 systemd: geoclue.service: Deactivated successfully.
16:14:10 geoclue: Service not used for 60 seconds. Shutting down..
16:14:10 systemd: Started Application launched by gnome-session-binary.
16:14:08 gnome-shell: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
16:13:54 systemd: systemd-timedated.service: Deactivated successfully.
16:13:47 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.68" (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:13:40 systemd: systemd-localed.service: Deactivated successfully.
16:13:40 nvidia-settings: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
16:13:40 systemd: Started Application launched by gnome-shell.
16:13:39 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.seahorse.Application'
16:13:39 nautilus: Connecting to org.freedesktop.Tracker3.Miner.Files
16:13:39 dbus-daemon: [session uid=1000 pid=1664] Activating service name='org.gnome.seahorse.Application' requested by ':1.43' (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:13:39 gnome-shell: Wrong number of result metas returned by search provider org.gnome.seahorse.Application.desktop: expected 1 but got 0
16:13:39 systemd: Started GNOME Terminal Server.
16:13:39 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.Terminal'
16:13:39 systemd: Starting GNOME Terminal Server...
16:13:39 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.43' (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:13:31 gnome-shell: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55939db0b150] is on because it needs an allocation.
16:13:30 dbus-daemon: [system] Rejected send message, 0 matched rules; type="error", sender=":1.16" (uid=0 pid=1263 comm="/usr/bin/nvidia-powerd " label="unconfined") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.68" (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:13:30 systemd-timesyn: Initial synchronization to time server [2620:2d:4000:1::41]:123 (ntp.ubuntu.com).
16:13:29 systemd: systemd-fsckd.service: Deactivated successfully.
16:13:28 kernel: audit: type=1326 audit(1662412408.851:133): auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3334 comm="slack" exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7ff404f173b7 code=0x50000
16:13:28 slack: SECCOMP auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3334 comm="slack" exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7ff404f173b7 code=0x50000
16:13:26 systemd: Started Application launched by gnome-shell.
16:13:26 gnome-shell: Wrong number of result metas returned by search provider org.gnome.seahorse.Application.desktop: expected 1 but got 0
16:13:26 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.Logs'
16:13:25 gnome-shell: Wrong number of result metas returned by search provider org.gnome.seahorse.Application.desktop: expected 1 but got 0
16:13:25 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.seahorse.Application'
16:13:25 gnome-shell: Timelines with detached actors are not supported. <unnamed>[<Gjs_ui_search_ListSearchResult>:0x55939e57b790] in animation of duration 100ms but not on stage.
16:13:25 dbus-daemon: [session uid=1000 pid=1664] Activating service name='org.gnome.seahorse.Application' requested by ':1.43' (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:13:24 nautilus: Connecting to org.freedesktop.Tracker3.Miner.Files
16:13:24 dbus-daemon: [session uid=1000 pid=1664] Activating service name='org.gnome.seahorse.Application' requested by ':1.43' (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:13:24 gpg-agent: listening on: std=6 extra=5 browser=4 ssh=3
16:13:24 systemd: Started GnuPG cryptographic agent and passphrase cache.
16:13:24 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.Terminal'
16:13:24 systemd: Starting GNOME Terminal Server...
16:13:24 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.43' (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:13:24 gnome-shell: unable to update icon for Slack1
16:13:22 systemd: NetworkManager-dispatcher.service: Deactivated successfully.
16:13:21 kernel: audit: type=1326 audit(1662412401.631:132): auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=4214 comm="slack" exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=330 compat=0 ip=0x7ff16d61d4e7 code=0x50000
16:13:21 slack: SECCOMP auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=4214 comm="slack" exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=330 compat=0 ip=0x7ff16d61d4e7 code=0x50000
16:13:21 kernel: audit: type=1326 audit(1662412401.619:131): auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3334 comm="slack" exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7ff404f173b7 code=0x50000
16:13:21 slack: SECCOMP auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3334 comm="slack" exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7ff404f173b7 code=0x50000
16:13:21 gnome-shell: unable to update icon for Slack1
16:13:21 nautilus: Could not delete '.meta.isrunning': No such file or directory
16:13:21 kernel: audit: type=1400 audit(1662412401.503:130): apparmor="DENIED" operation="open" profile="snap.slack.slack" name="/home/jpichardo/.pki/nssdb/cert9.db" pid=3334 comm="ThreadPoolForeg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
16:13:21 ThreadPoolForeg: AVC apparmor="DENIED" operation="open" profile="snap.slack.slack" name="/home/jpichardo/.pki/nssdb/cert9.db" pid=3334 comm="ThreadPoolForeg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
16:13:21 kernel: audit: type=1400 audit(1662412401.487:128): apparmor="DENIED" operation="open" profile="snap.slack.slack" name="/home/jpichardo/.pki/nssdb/pkcs11.txt" pid=3334 comm="ThreadPoolForeg" requested_mask="rac" denied_mask="rac" fsuid=1000 ouid=1000
16:13:21 ThreadPoolForeg: AVC apparmor="DENIED" operation="open" profile="snap.slack.slack" name="/home/jpichardo/.pki/nssdb/pkcs11.txt" pid=3334 comm="ThreadPoolForeg" requested_mask="rac" denied_mask="rac" fsuid=1000 ouid=1000
16:13:21 kernel: audit: type=1420 audit(1662412401.483:125): subj_apparmor=unconfined
16:13:21 kernel: MAC_TASK_CONTEXTS subj_apparmor=unconfined
16:13:21 kernel: USER_AVC pid=1225 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.login1.Manager" member="Inhibit" mask="send" name="org.freedesktop.login1" pid=3334 label="snap.slack.slack" peer_pid=1291 peer_label="unconfined"
 exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
16:13:21 snap: userd.go:93: Starting snap userd
16:13:21 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'io.snapcraft.Settings'
16:13:21 gnome-keyring-d: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
16:13:19 packagekitd: get-details transaction /667_baadeace from uid 1000 finished with success after 139ms
16:13:19 gnome-shell: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
16:13:19 packagekitd: search-file transaction /665_eeacbdee from uid 1000 finished with success after 169ms
16:13:18 snapd: storehelpers.go:722: cannot refresh: snap has no updates available: "bare", "code", "core", "core18", "core20", "datagrip", "firefox", "flutter", "gnome-3-28-1804", "gnome-3-34-1804", "gnome-3-38-2004", "gtk-common-themes", "remmina", "snap-store", "snapd", "snapd-desktop-integration", "spotify"
16:13:17 gnome-shell: clutter_binding_pool_activate: assertion 'key_val != 0' failed
16:13:16 snap-store: Only 0 apps for recent list, hiding
16:13:16 packagekitd: refresh-cache transaction /660_eaaedcbe from uid 1000 finished with success after 1057ms
16:13:15 kernel: audit: type=1400 audit(1662412395.555:123): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/etc/appstream.conf" pid=3017 comm="snap-store" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
16:13:15 snap-store: AVC apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/etc/appstream.conf" pid=3017 comm="snap-store" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
16:13:15 kernel: audit: type=1400 audit(1662412395.359:122): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/etc/PackageKit/Vendor.conf" pid=3017 comm="snap-store" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
16:13:15 snap-store: /etc/PackageKit/Vendor.conf file not found
16:13:15 kernel: MAC_TASK_CONTEXTS subj_apparmor=unconfined
16:13:15 kernel: audit: type=1420 audit(1662412395.107:121): subj_apparmor=unconfined
16:13:15 kernel: kauditd_printk_skb: 14 callbacks suppressed
16:13:15 kernel: USER_AVC pid=1225 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.PolicyKit1.Authority" member="CheckAuthorization" mask="send" name=":1.3" pid=3017 label="snap.snap-store.ubuntu-software" peer_pid=1265 peer_label="unconfined"
16:13:15 kernel: USER_AVC pid=1225 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.3" pid=3017 label="snap.snap-store.ubuntu-software" peer_pid=1265 peer_label="unconfined"
16:13:15 snap-store: plugin fwupd took 3.5 seconds to do setup
16:13:15 systemd: Started Firmware update daemon.
16:13:15 dbus-daemon: [system] Successfully activated service 'org.freedesktop.fwupd'
16:13:12 kernel: MAC_TASK_CONTEXTS subj_apparmor=unconfined
16:13:12 kernel: USER_AVC pid=1225 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="ListNames" mask="send" name="org.freedesktop.DBus" pid=3449 label="snap.slack.slack" peer_label="unconfined"
16:13:12 kernel: USER_AVC pid=1225 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/DBus" interface="org.freedesktop.DBus" member="RequestName" mask="send" name="org.freedesktop.DBus" pid=3449 label="snap.slack.slack" peer_label="unconfined"
16:13:12 gnome-shell: DING: GNOME nautilus 42.2
16:13:12 systemd: Started Virtual filesystem metadata service.
16:13:12 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gtk.vfs.Metadata'
16:13:12 systemd: Starting Virtual filesystem metadata service...
16:13:12 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.86' (uid=1000 pid=3413 comm="gjs /usr/share/gnome-shell/extensions/ding@rasters" label="unconfined")
16:13:12 dconf worker: SECCOMP auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3334 comm=64636F6E6620776F726B6572 exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7ff404f21539 code=0x50000
16:13:12 kernel: USER_AVC pid=1225 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/" interface="org.freedesktop.DBus.ObjectManager" member="GetManagedObjects" mask="send" name="org.bluez" pid=3334 label="snap.slack.slack" peer_pid=1217 peer_label="unconfined"
16:13:12 dbus-daemon: [session uid=1000 pid=1664] Activating service name='org.gnome.ArchiveManager1' requested by ':1.86' (uid=1000 pid=3413 comm="gjs /usr/share/gnome-shell/extensions/ding@rasters" label="unconfined")
16:13:12 boltd: [00395979-e610-AORUS GAMING BOX           ] udev: device changed: authorized -> authorized
16:13:12 kernel: thunderbolt 0-301: GIGABYTE AORUS GAMING BOX
16:13:12 boltd: [00395979-e610-AORUS GAMING BOX           ] connected: authorized (/sys/devices/pci0000:00/0000:00:0d.2/domain0/0-0/0-1/0-301)
16:13:12 gnome-shell: Registering session with GDM
16:13:12 slack: SECCOMP auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3334 comm="slack" exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=92 compat=0 ip=0x7ff404f173b7 code=0x50000
16:13:12 NetworkManager: <info>  [1662412392.1268] manager: NetworkManager state is now CONNECTED_GLOBAL
16:13:11 gnome-shell: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
16:13:11 kernel: audit: type=1326 audit(1662412391.843:99): auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3334 comm="slack" exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=330 compat=0 ip=0x7ff404f284e7 code=0x50000
16:13:11 slack: SECCOMP auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3334 comm="slack" exe="/snap/slack/64/usr/lib/slack/slack" sig=0 arch=c000003e syscall=330 compat=0 ip=0x7ff404f284e7 code=0x50000
16:13:11 systemd: Starting Firmware update daemon...
16:13:11 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.fwupd' unit='fwupd.service' requested by ':1.98' (uid=1000 pid=3017 comm="/snap/snap-store/582/usr/bin/snap-store --gapplica" label="snap.snap-store.ubuntu-software (enforce)")
16:13:11 gnome-shell: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
16:13:11 systemd: Started Portal service.
16:13:11 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.freedesktop.portal.Desktop'
16:13:11 kernel: audit: type=1326 audit(1662412391.251:98): auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3017 comm="snap-store" exe="/snap/snap-store/582/usr/bin/snap-store" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7ff3c526773d code=0x50000
16:13:11 snap-store: SECCOMP auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3017 comm="snap-store" exe="/snap/snap-store/582/usr/bin/snap-store" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7ff3c526773d code=0x50000
16:13:11 systemd: Started Portal service (GTK/GNOME implementation).
16:13:11 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
16:13:11 systemd: Starting Portal service (GTK/GNOME implementation)...
16:13:11 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.gtk' unit='xdg-desktop-portal-gtk.service' requested by ':1.54' (uid=1000 pid=2912 comm="/usr/libexec/xdg-desktop-portal " label="unconfined")
16:13:10 systemd: Condition check resulted in GNOME Initial Setup being skipped.
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.ScreenSaver'
16:13:10 gsd-media-keys: Failed to grab accelerator for keybinding settings:playback-repeat
16:13:10 rtkit-daemon: Supervising 12 threads of 3 processes of 1 users.
16:13:10 systemd: Started Portal service (GNOME implementation).
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
16:13:10 systemd: Started Locale Service.
16:13:10 dbus-daemon: [system] Successfully activated service 'org.freedesktop.locale1'
16:13:10 kernel: audit: type=1400 audit(1662412390.683:97): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3017 comm="snap-confine" capability=4  capname="fsetid"
16:13:10 systemd: tmp-snap.rootfs_fiw6Yg.mount: Deactivated successfully.
16:13:10 snap-confine: AVC apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3017 comm="snap-confine" capability=4  capname="fsetid"
16:13:10 gnome-shell: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
16:13:10 systemd: tmp-snap.rootfs_CgWCHA.mount: Deactivated successfully.
16:13:10 kernel: audit: type=1400 audit(1662412390.651:96): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3014 comm="snap-confine" capability=4  capname="fsetid"
16:13:10 snap-confine: AVC apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3014 comm="snap-confine" capability=4  capname="fsetid"
16:13:10 systemd: Started Manage, Install and Generate Color Profiles.
16:13:10 dbus-daemon: [system] Successfully activated service 'org.freedesktop.ColorManager'
16:13:10 NetworkManager: <info>  [1662412390.6402] agent-manager: agent[eefe275be834743c,:1.67/org.gnome.Shell.NetworkAgent/1000]: agent registered
16:13:10 kernel: audit: type=1400 audit(1662412390.631:95): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3017 comm="snap-confine" capability=38  capname="perfmon"
16:13:10 systemd: Starting Locale Service...
16:13:10 snap-confine: AVC apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3017 comm="snap-confine" capability=38  capname="perfmon"
16:13:10 systemd: Starting Manage, Install and Generate Color Profiles...
16:13:10 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.86' (uid=1000 pid=2933 comm="/usr/libexec/gsd-keyboard " label="unconfined")
16:13:10 systemd: Reached target GNOME keyboard shortcuts target.
16:13:10 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.ColorManager' unit='colord.service' requested by ':1.83' (uid=1000 pid=2928 comm="/usr/libexec/gsd-color " label="unconfined")
16:13:10 kernel: audit: type=1400 audit(1662412390.591:93): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3014 comm="snap-confine" capability=38  capname="perfmon"
16:13:10 snap-confine: AVC apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3014 comm="snap-confine" capability=38  capname="perfmon"
16:13:10 systemd: Started snap.slack.slack.2daecd46-0e84-48fd-b8d6-1e227d60f0f1.scope.
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.freedesktop.portal.IBus'
16:13:10 systemd: Started IBus Daemon for GNOME.
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Activating service name='org.freedesktop.portal.IBus' requested by ':1.69' (uid=1000 pid=2927 comm="/usr/bin/ibus-daemon --panel disable --xim " label="unconfined")
16:13:10 systemd: Reached target GNOME sound sample caching target.
16:13:10 gnome-session-b: GnomeDesktop-WARNING: Could not create transient scope for PID 2992: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2992 does not exist.
16:13:10 systemd: Started GNOME date & time service.
16:13:10 gnome-session-b: GnomeDesktop-WARNING: Could not create transient scope for PID 2983: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2983 does not exist.
16:13:10 systemd: Started GNOME smartcard service.
16:13:10 gnome-session-b: gnome-session-binary[2581]: GnomeDesktop-WARNING: Could not create transient scope for PID 2992: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2992 does not exist.
16:13:10 systemd: Started GNOME file sharing service.
16:13:10 gnome-session-b: Entering running state
16:13:10 systemd: Reached target GNOME accessibility target.
16:13:10 kernel: rfkill: input handler disabled
16:13:10 systemd: Reached target GNOME RFKill support target.
16:13:10 spice-vdagent: vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0 does not exist, exiting
16:13:10 systemd: Started GNOME RFKill support service.
16:13:10 Xorg: (--) NVIDIA(GPU-1):
16:13:10 systemd: Starting Portal service (GNOME implementation)...
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.gnome' unit='xdg-desktop-portal-gnome.service' requested by ':1.54' (uid=1000 pid=2912 comm="/usr/libexec/xdg-desktop-portal " label="unconfined")
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.Shell.Notifications'
16:13:10 systemd: Starting Portal service...
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.freedesktop.portal.Desktop' unit='xdg-desktop-portal.service' requested by ':1.51' (uid=1000 pid=2885 comm="/usr/bin/nautilus --gapplication-service " label="unconfined")
16:13:10 at-spi2-registr: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
16:13:10 dbus-daemon: dbus-daemon[2554]: Successfully activated service 'org.a11y.atspi.Registry'
16:13:10 systemd: Started PackageKit Daemon.
16:13:10 dbus-daemon: [system] Successfully activated service 'org.freedesktop.PackageKit'
16:13:10 systemd: Started Location Lookup Service.
16:13:10 dbus-daemon: [system] Successfully activated service 'org.freedesktop.GeoClue2'
16:13:10 packagekitd: daemon start
16:13:10 systemd: Starting PackageKit Daemon...
16:13:10 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.67' (uid=1000 pid=2605 comm="/usr/bin/gnome-shell " label="unconfined")
16:13:10 systemd: Started Evolution address book service.
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.evolution.dataserver.AddressBook10'
16:13:10 systemd: Started User preferences database.
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'ca.desrt.dconf'
16:13:10 gnome-shell: Telepathy is not available, chat integration will be disabled.
16:13:10 systemd: Starting Evolution address book service...
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.gnome.evolution.dataserver.AddressBook10' unit='evolution-addressbook-factory.service' requested by ':1.46' (uid=1000 pid=2850 comm="/usr/libexec/evolution-calendar-factory " label="unconfined")
16:13:10 polkitd: Registered Authentication Agent for unix-session:1 (system bus name :1.67 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
16:13:10 systemd: Starting Location Lookup Service...
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.evolution.dataserver.Calendar8'
16:13:10 systemd: Starting Evolution calendar service...
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.gnome.evolution.dataserver.Calendar8' unit='evolution-calendar-factory.service' requested by ':1.44' (uid=1000 pid=2834 comm="/usr/libexec/gnome-shell-calendar-server " label="unconfined")
16:13:10 systemd: Started Evolution source registry.
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.gnome.evolution.dataserver.Sources5'
16:13:10 systemd: Starting Evolution source registry...
16:13:10 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.gnome.evolution.dataserver.Sources5' unit='evolution-source-registry.service' requested by ':1.44' (uid=1000 pid=2834 comm="/usr/libexec/gnome-shell-calendar-server " label="unconfined")
16:13:10 gnome-shell: Will monitor session 1
16:13:10 dockerd: time="2022-09-05T16:13:10.024047584-05:00" level=info msg="API listen on /run/docker.sock"
16:13:10 systemd: Started Docker Application Container Engine.
16:13:10 dockerd: time="2022-09-05T16:13:10.007690762-05:00" level=info msg="Daemon has completed initialization"
16:13:09 gnome-shell: ATK Bridge is disabled but a11y has already been enabled.
16:13:09 dockerd: time="2022-09-05T16:13:09.893135476-05:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
16:13:09 NetworkManager: <info>  [1662412389.8788] device (docker0): Activation: successful, device activated.
16:13:09 rtkit-daemon: Supervising 12 threads of 3 processes of 1 users.
16:13:09 NetworkManager: <info>  [1662412389.8770] device (docker0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
16:13:09 rtkit-daemon: Supervising 11 threads of 3 processes of 1 users.
16:13:09 avahi-daemon: Registering new address record for 172.17.0.1 on docker0.IPv4.
16:13:09 NetworkManager: <info>  [1662412389.8607] device (br-57b52fdb0bb9): Activation: successful, device activated.
16:13:09 avahi-daemon: Registering new address record for 172.18.0.1 on br-57b52fdb0bb9.IPv4.
16:13:09 Xorg: (II) NVIDIA(G0): Setting mode "DP-1-0: nvidia-auto-select @2560x1440 +1920+0 {AllowGSYNC=Off, ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
16:13:09 NetworkManager: <info>  [1662412389.7758] manager: (br-57b52fdb0bb9): new Bridge device (/org/freedesktop/NetworkManager/Devices/5)
16:13:09 systemd-udevd: Using default interface naming scheme 'v249'.
16:13:09 kernel: Initializing XFRM netlink socket
16:13:09 kernel: Bridge firewalling registered
16:13:09 kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
16:13:09 dockerd: time="2022-09-05T16:13:09.629782983-05:00" level=info msg="Loading containers: start."
16:13:09 Xorg: (--) NVIDIA(GPU-1):
16:13:09 dockerd: time="2022-09-05T16:13:09.582149331-05:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
16:13:09 kernel: audit: type=1400 audit(1662412389.559:91): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=2632 comm="apparmor_parser"
16:13:09 apparmor_parser: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=2632 comm="apparmor_parser"
16:13:09 gnome-shell: Running GNOME Shell (using mutter 42.2) as a X11 window and compositing manager
16:13:09 dockerd: time="2022-09-05T16:13:09.543928745-05:00" level=info msg="detected 127.0.0.53 nameserver, assuming systemd-resolved, so using resolv.conf: /run/systemd/resolve/resolv.conf"
16:13:09 cups-browsed: AVC apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=2558 comm="cups-browsed" capability=23  capname="sys_nice"
16:13:09 kernel: audit: type=1400 audit(1662412389.535:90): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=2558 comm="cups-browsed" capability=23  capname="sys_nice"
16:13:09 kernel: kauditd_printk_skb: 5 callbacks suppressed
16:13:09 avahi-daemon: Registering new address record for 2600:1700:28e2:c90:318b:bc0d:a3d2:fc36 on wlp0s20f3.*.
16:13:09 systemd: Started Application launched by gnome-session-binary.
16:13:09 gnome-session-b: GnomeDesktop-WARNING: Could not create transient scope for PID 2603: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2603 does not exist.
16:13:09 systemd: Condition check resulted in GNOME Shell on Wayland being skipped.
16:13:09 gnome-keyring-d: SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
16:13:09 systemd: Failed to start Application launched by gnome-session-binary.
16:13:09 systemd: whoopsie.service: Deactivated successfully.
16:13:09 sh: /bin/sh: 1: initctl: not found
16:13:09 dbus-update-act: dbus-update-activation-environment: setting SSH_AGENT_LAUNCHER=gnome-keyring
16:13:09 whoopsie: [16:13:09] Using lock path: /var/lock/whoopsie/lock
16:13:09 systemd: Finished Start gnome-keyring for the Secrets Service, and PKCS #11.
16:13:09 gnome-keyring-d: keyring was in an invalid or unrecognized format: /home/jpichardo/.local/share/keyrings/default.keyring
16:13:09 systemd: Finished Rewrite dynamic launcher portal entries.
16:13:09 NetworkManager: <info>  [1662412389.4126] manager: startup complete
16:13:09 systemd: Started Accessibility services bus.
16:13:09 dbus-daemon: [session uid=1000 pid=1664] Successfully activated service 'org.a11y.Bus'
16:13:09 systemd: Starting Accessibility services bus...
16:13:09 dbus-daemon: [session uid=1000 pid=1664] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.22' (uid=1000 pid=2547 comm="/usr/libexec/gnome-session-check-accelerated " label="unconfined")
16:13:09 Xsession: /etc/X11/Xsession.d/90x11-common_ssh-agent: line 9: has_option: command not found
16:13:09 dbus-update-act: dbus-update-activation-environment: setting QT_ACCESSIBILITY=1
16:13:09 kernel: localuser:jpichardo being added to access control list
16:13:09 Xsession: /etc/X11/Xsession.d/30x11-common_xresources: line 16: has_option: command not found
16:13:09 dbus-update-act: dbus-update-activation-environment: setting XAUTHORITY=/run/user/1000/gdm/Xauthority
16:13:09 xhost: localuser:jpichardo being added to access control list
16:13:09 Xsession: /etc/gdm3/Xsession: Beginning session setup...
16:13:08 thermald: You may want to disable thermald on this system if you see issue
16:13:08 systemd: dmesg.service: Deactivated successfully.
16:13:08 avahi-daemon: Registering new address record for 2600:1700:28e2:c90::21 on wlp0s20f3.*.
16:13:08 NetworkManager: <info>  [1662412388.0704] dhcp6 (wlp0s20f3): state changed new lease, address=2600:1700:28e2:c90::21
16:13:08 rtkit-daemon: Supervising 12 threads of 3 processes of 1 users.
16:13:08 systemd-resolve: wlp0s20f3: Bus client set DNS server list to: 192.168.1.254, 2600:1700:28e2:c90::1
16:13:08 avahi-daemon: Withdrawing address record for fe80::562f:538a:f476:12a2 on wlp0s20f3.
16:13:08 NetworkManager: <info>  [1662412388.0669] policy: set 'Pichardo' (wlp0s20f3) as default for IPv6 routing and DNS
16:13:08 rtkit-daemon: Supervising 11 threads of 3 processes of 1 users.
16:13:08 Xorg: (--) NVIDIA(GPU-1):
16:13:07 rtkit-daemon: Supervising 12 threads of 3 processes of 1 users.
16:13:07 pulseaudio: Path rt715 Capture is not a volume or mute control
16:13:07 rtkit-daemon: Supervising 11 threads of 3 processes of 1 users.
16:13:07 prime-supported: /usr/bin/prime-supported: 35: cannot create /var/log/prime-supported.log: Permission denied
16:13:07 Xorg: (**) Option "xkb_layout" "us"
16:13:06 rtkit-daemon: Supervising 9 threads of 3 processes of 1 users.
16:13:06 Xorg: (II) Using input driver 'libinput' for 'Razer Razer Pro Type'
16:13:06 wpa_supplicant: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=9999 txrate=245000
16:13:06 Xorg: (II) modeset(G5): Damage tracking initialized
16:13:06 systemd-resolve: wlp0s20f3: Bus client set DNS server list to: 192.168.1.254
16:13:06 NetworkManager: <info>  [1662412386.8017] device (wlp0s20f3): Activation: successful, device activated.
16:13:06 avahi-daemon: Registering new address record for 192.168.1.162 on wlp0s20f3.IPv4.
16:13:06 NetworkManager: <info>  [1662412386.7968] dhcp4 (wlp0s20f3): state changed new lease, address=192.168.1.162
16:13:06 avahi-daemon: Registering new address record for fe80::562f:538a:f476:12a2 on wlp0s20f3.*.
16:13:06 NetworkManager: <info>  [1662412386.7753] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
16:13:06 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
16:13:06 wpa_supplicant: wlp0s20f3: CTRL-EVENT-CONNECTED - Connection to ac:8f:a9:3f:82:c8 completed [id=0 id_str=]
16:13:06 kernel: iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
16:13:06 wpa_supplicant: wlp0s20f3: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
16:13:06 NetworkManager: <info>  [1662412386.6273] device (p2p-dev-wlp0s20f3): supplicant management interface state: authenticating -> associating
16:13:06 wpa_supplicant: wlp0s20f3: Trying to associate with ac:8f:a9:3f:82:c8 (SSID='Pichardo' freq=5240 MHz)
16:13:06 Xorg: (II) Initializing extension NV-CONTROL
16:13:06 NetworkManager: <info>  [1662412386.5413] device (p2p-dev-wlp0s20f3): supplicant management interface state: scanning -> authenticating
16:13:06 kernel: wlp0s20f3: send auth to ac:8f:a9:3f:82:c8 (try 1/3)
16:13:06 NetworkManager: <info>  [1662412386.5208] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> scanning
16:13:06 wpa_supplicant: wlp0s20f3: WPS-CANCEL
16:13:06 NetworkManager: <info>  [1662412386.5199] Config: added 'psk' value '<hidden>'
16:13:06 wpa_supplicant: wlp0s20f3: WPS-PBC-ACTIVE
16:13:06 NetworkManager: <info>  [1662412386.5197] device (wlp0s20f3): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
16:13:06 wpa_supplicant: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
16:13:06 Xorg: (==) modeset(G1): Silken mouse enabled
16:13:06 acpid: 1 client rule loaded
16:13:06 Xorg: (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
16:13:06 Xorg: (II) NVIDIA:     access.
nvidia-bug-report.log.gz (500.1 KB)
I suspect so, too.
NVRM: Xid (PCI:0000:04:00): 79, pid='<unknown>', name=<unknown>, GPU has fallen off the bus.
The box is still detected so tb connection is fine. Leaves either insufficient power or incorrectly seated in the pcie slot.
Odd thing, it used to not always happen, sometimes it was usable, however now it happens every time.
It’s a prebuilt box connected to a surge protector, wonder if it’s damaged from fabric.
Yes, I guess you’ll have to send it in to not void warranty.
Thank you.
