Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.0.7363
other
Host Machine Version
native Ubuntu 18.04
other
First, I would like to mention that I am not sure wether this issue belongs to Tensorflow or Drive AGX but I believe that it is appropriate to seek a solution here. I have seen a couple of similar issue encounters on various forums but none has been able to solve my problem. I am also aware that Tensorflow isn’t officially supported for the AGX.
I am having a problem building Tensorflow from source onto my AGX. I am attempting to build Tensorflow 2.4 . I have Bazel 3.7.2 installed and working well. I am able to run the configuration file inside of tensorflow but my issue does not come up until I attempt to build Tensorflow with CUDA supports. I was able to properly configure the installation without CUDA support. This is my output:
Please specify the CUDA SDK version you want to use. [Leave empty to default to CUDA 10]: 10.2
Please specify the cuDNN version you want to use. [Leave empty to default to cuDNN 7]: 7.6
Please specify the TensorRT version you want to use. [Leave empty to default to TensorRT 6]: 6.3
Please specify the locally installed NCCL version you want to use. [Leave empty to use http://github.com/nvidia/nccl]:
Please specify the comma-separated list of base paths to look for CUDA libraries and headers. [Leave empty to use the default]: /usr/include/linux/
File "third_party/gpus/find_cuda_config.py", line 653, in <module>
main()
File "third_party/gpus/find_cuda_config.py", line 645, in main
for key, value in sorted(find_cuda_config().items()):
File "third_party/gpus/find_cuda_config.py", line 583, in find_cuda_config
result.update(_find_cuda_config(cuda_paths, cuda_version))
File "third_party/gpus/find_cuda_config.py", line 257, in _find_cuda_config
get_header_version)
File "third_party/gpus/find_cuda_config.py", line 244, in _find_header
required_version, get_version)
File "third_party/gpus/find_cuda_config.py", line 233, in _find_versioned_file
actual_version = get_version(file)
File "third_party/gpus/find_cuda_config.py", line 250, in get_header_version
version = int(_get_header_version(path, "CUDA_VERSION"))
ValueError: invalid literal for int() with base 10: ''
Asking for detailed CUDA configuration...
This might also be an issue with Python I think. I tried going ahead and hardcoding the configuration file to force it into accepting the cuda.h file found but I don’t think that method was very effective.
Has anyone encountered an issue like this before? Does anyone know how to fix this? Any advice would be greatly appreciated. Thank you,
Zeus
