Jetson
• DeepStream Version
DeepStream 5.1
JetPack 4.5.1
• TensorRT Version
Appears to be a bug?
The following line of application code
nvjpegdec = gst_element_factory_make ("nvjpegdec", "jpeg-decoder");
Produces the following debug statements
0:00:00.076605881 17615 0x55a809e600 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvjpegdec" named "jpeg-decoder"
0:00:00.077122402 17615 0x55a809e600 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoDecoder@0x55a82b16b0> adding pad 'sink'
0:00:00.077237040 17615 0x55a809e600 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoDecoder@0x55a82b16b0> adding pad 'src'
Bus error (core dumped)
This seems to be identical to L4T 28.1 : Gstreamer 1.0 and BusError on nvjpegdec plugin
which was closed several years ago without a resolution
