Bypass ISP on AGX developement kit
hi vendor:
I read the Tegra Linux Driver Package Development Guide/camera API matrix.
It reveals that if sensor is with ISP, it is recommended to use v4l2 path and ISP on AGX is bypassed.
All I need to know is:
  1. Is this default kernel config??
  2. where is the corresponding code flow??
  3. there is TEGRA_CID_BYPASS_VI ioctl command in driver, is this means bypass ISP?? I think VI and ISP are different functions
Thanks for suggession
Current L4T camera driver have two mode bypass_mode=0/1,
0: NVCSI->VI->memory (v4l2-ctl --set-ctrl bypass_mode=0) or capture by v4l2src or V4L2 API implement API
1: ARGUS base APP like argus_camera or nvarguscamerasrc …
For YUV sensor have external ISP recommend to use bypass_mode=0
