System info: Debian Unstable 4.19.20-1 (2019-02-12) x86_64
Nsight Graphics version: 2019.2.1.0 (Build 26129631)
I’m hitting a minor issue - I’m unable to connect to a C++ Capture. Many thanks for helping me resolve the issue over in the other post.
Steps to reproduce:
- git clone GitHub - ndsol/VolcanoSamples: Volcano sample code to get started with Vulkan. Keep it simple, short and sweet.
- cd VolcanoSamples
- ./build.cmd
(wait a while, it will clone and build the vulkan loader in out/Debug)
- export LD_LIBRARY_PATH=$PWD/out/Debug
(Required to point NVIDIA Nsight to the correct Vulkan loader. Otherwise Nsight will use a different vulkan loader.)
- cd ~/nvidia-nsight/host/linux-desktop-nomad-x64
- ./nv-nsight-gfx
- Connect
- Select application executable: $(git repo)/out/Debug/01glfw
- Working directory: $(git repo)
- Change Activity to “Generate C++ Capture”
- Additional Options > Vulkan is set to the defaults:
- Force validation: No
- Enable Coherent Buffer Collection: Yes
- Enable Revision Zero Data Collection: Yes
- Allow Unsafe pNext Values: No
- Use Safe Object Lookup: Auto
- C++ Capture Object Set: Only Active
- Reserve Heap Space: 0
- Unweave Threads: No
- Click Launch
- Hit Ctrl+Z, Space to capture a frame
- Export of C++ Capture is complete (100%). Hit OK.
- Tool Chain is the default: Linux Desktop gcc
- Click the Terminate button at the top to stop the running application
- No errors in the console where nv-nsight-gfx was launched back in Step #6
- Click Build
- Build completes successfully. Here’s the Build Log:
mkdir -p int && cd int && cmake -G Unix\ Makefiles -DNV_INSTALL_FOLDER=bin .. && cmake --build . --config Release --target install -- -j13
-- The C compiler identification is GNU 4.8.5
-- The CXX compiler identification is GNU 4.8.5
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
Building 64-bit app.
-- Configuring done
-- Generating done
-- Build files have been written to: CppCaptures/01glfw__2019_05_01__19_02_33/int
Scanning dependencies of target cppcap
[ 4%] Building CXX object CMakeFiles/cppcap.dir/FrameReset00.cpp.o
[ 13%] Building CXX object CMakeFiles/cppcap.dir/Frame0Part00.cpp.o
[ 13%] Building CXX object CMakeFiles/cppcap.dir/CommandList00.cpp.o
[ 17%] Building CXX object CMakeFiles/cppcap.dir/Application.cpp.o
[ 21%] Building CXX object CMakeFiles/cppcap.dir/FrameSetup00.cpp.o
[ 26%] Building CXX object CMakeFiles/cppcap.dir/Helpers.cpp.o
[ 30%] Building CXX object CMakeFiles/cppcap.dir/ReadOnlyDatabase.cpp.o
[ 34%] Building CXX object CMakeFiles/cppcap.dir/PerfMarkersSetup.cpp.o
[ 39%] Building CXX object CMakeFiles/cppcap.dir/Main.cpp.o
[ 43%] Building CXX object CMakeFiles/cppcap.dir/ThreadPool.cpp.o
[ 47%] Building CXX object CMakeFiles/cppcap.dir/Resources00.cpp.o
[ 52%] Building CXX object CMakeFiles/cppcap.dir/ReplayProcedures.cpp.o
[ 56%] Building CXX object CMakeFiles/cppcap.dir/PerfMarkersReset.cpp.o
[ 60%] Building CXX object CMakeFiles/cppcap.dir/Threading.cpp.o
[ 65%] Building CXX object CMakeFiles/cppcap.dir/VulkanAllocator.cpp.o
[ 69%] Building CXX object CMakeFiles/cppcap.dir/VulkanBootstrap.cpp.o
[ 73%] Building CXX object CMakeFiles/cppcap.dir/VulkanReplay.cpp.o
[ 78%] Building CXX object CMakeFiles/cppcap.dir/WinResourcesReset.cpp.o
[ 82%] Building CXX object CMakeFiles/cppcap.dir/WinResourcesSetup.cpp.o
[ 86%] Building CXX object CMakeFiles/cppcap.dir/function_overrides.cpp.o
[ 91%] Building CXX object CMakeFiles/cppcap.dir/WindowSystem_Xcb.cpp.o
[ 95%] Building CXX object CMakeFiles/cppcap.dir/LinuxApplication.cpp.o
[100%] Linking CXX executable 01glfw__2019_05_01__19_02_33
[100%] Built target cppcap
Install the project...
-- Install configuration: ""
-- Installing: 01glfw__2019_05_01__19_02_33/bin/01glfw__2019_05_01__19_02_33
- Click Execute
- The captured frame displays ok
- Close the window of the frame-capture
- Click “Connect…”
- Click Activity > Frame Profiler
- Click Launch
It starts running, attempting to connect, then a dialog pops up:
Connection Error
Connection error detected communicating with target application.
Shutting down connection.
