Nsight not able to run vkcube (or any vulkan executable)
Example,
>ngfx --exe /usr/bin/vkcube --activity "Frame Debugger" --wait-hotkey --verbose
Parsed general options:
    hostname --> localhost
    ssh-user -->
    ssh-pwd -->
    ssh-port --> 22
    exe --> /usr/bin/vkcube
    dir -->
    args -->
    env -->
    project -->
    output-dir --> /home/carlo/Documents/NVIDIA Nsight Graphics
    activity --> Frame Debugger
    platform --> Linux (x86_64)
    verbose --> 1
Launching process...
Preparing to launch...
Launched process: vkcube (pid: 2485446)
/usr/bin/vkcube
Attempting to automatically connect...
Searching for attachable process 2485446 on local socket...
Launch process exited. Searching for attachable child processes...
Failed to connect. The target process may have exited.
Launching process... Failed
Exiting...
Running result: 1
As vkcube doesn’t print anything, this isn’t very insight full (pun intended).
But, by running my own application we find that running an executable from within nsight sees a completely different list of extensions:
Normally my application reports:
Available instance extensions:{ "VK_KHR_device_group_creation", "VK_KHR_display", "VK_KHR_external_fence_capabilities", "VK_KHR_external_memory_capabilities", "VK_KHR_external_semaphore_capabilities", "VK_KHR_get_display_properties2", "VK_KHR_get_physical_device_properties2", "VK_KHR_get_surface_capabilities2", "VK_KHR_surface", "VK_KHR_surface_protected_capabilities", "VK_KHR_wayland_surface", "VK_KHR_xcb_surface", "VK_KHR_xlib_surface", "VK_EXT_acquire_xlib_display", "VK_EXT_debug_report", "VK_EXT_debug_utils", "VK_EXT_direct_mode_display", "VK_EXT_display_surface_counter", "VK_KHR_portability_enumeration" }
but when run from ngfx I get:
Available instance extensions:{ "VK_EXT_debug_report", "VK_EXT_debug_utils", "VK_KHR_portability_enumeration", "VK_EXT_tooling_info" }
making it not even capable to draw to a surface.
How can I fix this?
PS This is on Arch linux, using NVIDIA_Nsight_Graphics_2022.2.1.22100.run
Nevermind - it works with 2022.3.1.22168
I still get
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5KIOWidgets.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5KIOGui.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libKF5KIOCore.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5KIOCore.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5I18n.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libQt5Widgets.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libQt5Widgets.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libQt5Gui.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libKF5CoreAddons.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5CoreAddons.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libQt5Core.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libQt5Core.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `CXXABI_1.3.13' not found (required by /usr/lib/libQt5Core.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libKF5Service.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5Service.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5Solid.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libQt5Network.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libQt5Network.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5IconThemes.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libKF5ConfigWidgets.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5ConfigWidgets.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libKF5WindowSystem.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5WidgetsAddons.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5GuiAddons.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libKF5ConfigCore.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libKF5ConfigCore.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libQt5Xml.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libQt5Xml.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/libQt5WaylandClient.so.5)
kde-open5: /opt/nsight-graphics/host/linux-desktop-nomad-x64/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/lib/libQt5WaylandClient.so.5)
thought, when it tries to open a link that I click on.
Thank you for using Nsight Graphics and thanks for the update on your issue. Glad you tried out the latest version of Nsight Graphics to confirm it is working now. I’ll let the development team know about the other issue you raised which looks to be some GCC linker errors.
Regards,
