I have successfully installed the Jetson Nano image. The examples are running besides the example 09_camera_jpeg_capture. Unfortunally this example is important for me because we have a 2 camera application which is runnning on 2 Raspi’s and we want to switch this application to the Jetson Nano. As I understood the log the application has a problem to get infos from the cameras. But the cameras are correct installed, because I can run the example 13_multi_camera. Can somebody explain we what the problem could be. Thanks in advance.
below is the error log
./camera_jpeg_capture
[INFO] (NvEglRenderer.cpp:110) Setting Screen width 640 height 480
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
CONSUMER: Waiting until producer is connected…
Error generated. main.cpp, execute:390 Failed to get sensor modes
(Argus) Error InvalidState: (propagating from src/eglstream/FrameConsumerImpl.cpp, function streamEventThread(), line 135)
(Argus) Error InvalidState: (propagating from src/eglstream/FrameConsumerImpl.cpp, function streamEventThreadStatic(), line 177)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
Error generated. main.cpp, threadExecute:123 Stream failed to connect.
Error generated. /usr/src/jetson_multimedia_api/argus/samples/utils/Thread.cpp, threadFunction:132 (propagating)
Bus error (core dumped)
