Hi !
I have encountered a problem with the Camera V2.1 on my Jetson Nano 2Gb.
I have 3 cameras V2.1 but none of them are working.
Here is the commands that i’ve found on the forum, maybe it can helps you !
Waiting for a solution to make this camera working !
Thanks for advance
Looks like unable communicate with sensor via i2c bus. It could be cable or some HW issue.
Did you try the latest release BSP?
Where can I find it ?
Thanks for answer
Get the version by below command. I would suggest using the J4.6.1
cat /etc/nv_tegra_release
R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t210ref, EABI: aarch64, DATE …
So I think that I have the good version (J4.6.1 as you said) ?
system
Closed
June 1, 2022, 1:14am
8
