I’d like to ask the CAN(using pin) bit rate of AGX Jetson Orin devkit.
Related topics
| Read or write the CAN data using Jetson Orin board | 1 | 629 | November 16, 2023 | |
| Jetson Orin CAN communication | 1 | 1487 | August 3, 2022 | |
| Jetson Agx Orin Control BLDC with CANbus | 1 | 538 | March 22, 2023 | |
| I cannot recieve can msgs from a can bus using AGX Orin | 1 | 216 | November 26, 2024 | |
| Jetson ORIN CAN controller test | 3 | 1326 | May 13, 2023 | |
| AGX Orin dev kit CAN no signal on pins | 2 | 203 | February 18, 2025 | |
| How do you enable CAN bus in the AGX Orin | 1 | 5509 | July 18, 2022 | |
| Jetson Orin AGX CAN BUS problem | 7 | 890 | September 10, 2025 | |
| CAN0 data bitrate issue | 11 | 207 | May 20, 2026 | |
| Jetson Agx Orin CAN communication | 8 | 1432 | July 27, 2023 |
