I need to use CAN communication, but it doesn’t work when I connect it through a CAN to USB device. how should I connect the CAN communication interface to Jetson Thor.
Please find more the instruction from Controller Area Network (CAN) — NVIDIA Jetson Linux Developer Guide
Hi JACK452,
Are you using the devkit or custom board for Thor?
Please refer to the link shared from kayccc first and let us know what’s the exact connections in your case.
e.g. do you connect them as following on Thor
And you connect USB-to-CAN between host PC(USB) and Thor(CAN)?
Thank you, the problem has been solved
