I am building a small optix based test application in which I want to shoot a set of predefined rays from a origin in the scene and see if it actually hits the scene geometry which is in the form:
const std::vector<float3> vertices = triangles;
{ -0.5f, -0.5f, 0.0f },
{ 0.5f, -0.5f, 0.0f },
{ 0.0f, 0.5f, 0.0f },
The ray destination scene coordinates(not-normalized) have this form:
const static double rayDestisnations[10000][3] = { {
{-0.88871406, 0.4593381547, 0.00015, 0.3333333},
{0.344705048422, -0.98711013621, 0.00025},
{0.379915392598, 0.9221173794, 0.00035},
{-0.904980575489, -0.4254647762, 0.00045},
{-0.1521858, -0.8818035, 0.445},
{0.71069432, 0.54358462, 0.445},
{-0.890590706519, 0.079434099, 0.44785},
{0.6031359545, -0.659975472, 0.44795},
{0.001037894335, 0.89855311, 0.44805},
{-0.6046512877, -0.6551593026, 0.4485},
{-0.02804462274, 0.017699385, 0.99945},
{0.007890064872, -0.0289403710094, 0.99955},
{0.0121099887, 0.0235207539794, 0.99965},
{-0.0209751941736, -0.00774459355806, 0.99975},
{0.0160328889884, -0.00655163877853, 0.99985},
{ 0.0099999922, 0.0, 0.99995 }
I have set up an one-row launching grid of length of 10000 and in .cu file I can access each ray destination and create the ray_direction like this:
float3 rayCoord;
rayCoord.x = params.rayCoords[idx.x].x;
rayCoord.y = params.rayCoords[idx.x].y;
rayCoord.z = params.rayCoords[idx.x].z;
float3 ray_origin = params.origin;
ray_direction = (rayCoord - ray_origin);
Then in __raygen__rg()
I run optixTrace:
optixTrace(
params.handle,
ray_origin,
ray_direction,
0.0f, // Min intersection distance
1e16f, // Max intersection distance
0.0f, // rayTime -- used for motion blur
OptixVisibilityMask(255), // Specify always visible
OPTIX_RAY_FLAG_DISABLE_ANYHIT | OPTIX_RAY_FLAG_DISABLE_CLOSESTHIT | OPTIX_RAY_FLAG_TERMINATE_ON_FIRST_HIT,
0, // SBT offset -- See SBT discussion
1, // SBT stride -- See SBT discussion
0, // missSBTIndex -- See SBT discussion
payloadMissed
Since I don’t want to render an image of 10000x1
size, but simply check if any of the rays hits the geometry in my scene,
does function optixTrace()
in this form do actually what I intend to do? All coordinates are in scene coordinates, do I have to transform/normalize the ray_origin and ray_direction?
I am asking this because by moving the origin point to various locations in the scene I get some unexpected miss/hit values and I wonder if I have to treat ray coordinates differently.
