How can I use the .stp file in an isaac sim environment?
rgasoto
3
Did you check CAD Importer — Omniverse Extensions documentation ?
There’s no direct cad support, but you can import your stp file with the extension above. It is available in Isaac Sim.
Related topics
| Can I use .stp by importing isaac sim | 5 | 628 | August 15, 2022 | |
| Question of convert in isaac sim | 4 | 159 | March 10, 2025 | |
| [ISAACSIM] Cannot import .stp file in isaacsim | 2 | 112 | May 6, 2025 | |
| Error importing STEP file into Isaac Sim | 6 | 206 | July 2, 2025 | |
| Import issue: not able to import STEP file using Isaac Sim 4.2.0 | 9 | 449 | November 19, 2024 | |
| Failed to Import STEP File | 12 | 408 | May 28, 2025 | |
| Where is the STEP Importer in Isaac Sim 2022.2.0? | 6 | 649 | October 20, 2023 | |
| Isaac Sim , step files | 4 | 2219 | April 5, 2024 | |
| Cannot import STEP file in Isaac Sim 4.2.0 | 3 | 173 | November 25, 2024 | |
| STEP format not available in Omniverse Isaac Sim CAD importer | 9 | 1948 | August 29, 2022 |
