Hi I’m trying to import local STEP files from my PC. I can not find the STEP-Importer anymore. Got it removed ?
If so, how can I import my STEP files then?
@ma161mol are you referring to the CAD converter extension?
https://docs.omniverse.nvidia.com/extensions/latest/ext_cad-converter.html
if so, you should be able to use the two methods described on that page to import your stp files (i think it was still accessible in version 2022.2.0)
I think so. But when i want to Save the World it only saves the last imported File and not every single import I did
hmm, saving seems to be working for me on multiple STP files (tested on 2023.1.0). is it possible for you to mock up a few basic STP files and record your process? were there any log messages that would’ve indicated issue with saving?
I’m going to update to a newer Version. And will write again if it worked for me or not.
sounds good. sorry i don’t have older versions at the moment 😔
this was my process, nothing out of the ordinary, i don’t think:
