Hi there,
What are the ways in which the Jetson Nano can communicate with Raspberry Pi 3B? Would the following method work?
Would I be able to use PySerial to exchange data between the 2 devices this way?
Ed
Hi there,
Ed
Yes, you can connect the TTL UART interfaces between Raspberry Pi and Jetson Nano, as long as they share a ground connection, and you set the port parameters at the same speeds.
You can use PySerial to talk to a serial port, assuming you have the right permissions and nothing else uses the port.
So, yes.
@snarky Can you please eloborate this process?
I have my pi running on a battery is used to control the bot using joy stick and also jetson nano running on battery backup. Can I connect wirelessly the pi and jetson nano. I want some detection results to update to pi to stop or start robot accordingly.
