Can Nsight be installed and directly used in TX2?
I have used SDK in the host computer to install Nsight Eclipse 10.0 and tested the remote debugging feature in TX2 successfully.
But when I installed the Nsight manually in the TX2 via (sudo apt install nvidia-nsight --fix-missing) and tried to test the nsight’s debugging feature in the same TX2. It reported the CUDA version incompatibility problem and stop the execution. I wonder whether I need to use another way to install Nsight in the TX2 device (not only installed in the host machine). One of posts disagreed to install nsight manually or in TX2. Is it true? Can it be fixed.
This is for course use. It would be convenient for students to use it even if host machine and TX2 devices are not in the same LAN.
Sorry for the late reply.
Nsight cannot be used on the Jetson platform. It’s required an x86 environment.
But you can remote access the TX2 with the Nsight.
I use root login, so I will not use sudo before any command
apt install aptitude
aptitude install install eclipse
or download
aptitude install synaptic
run synaptic
remove default-jre-*
remove default-jdk-*
remove openjdk-11-*
add-apt-repository ppa:openjdk-r/ppa
apt update
apt install openjdk-8-jdk
aptitude install libcanberra-gtk-module
run eclipse
Demo Pic: File sharing and storage made simple
#option 1
gedit /ect/eclipse.ini
remove
–launcher.XXMaxPermSize
256m
#option 2
refer to Bug #1754886 “Eclipse fails to start (java.lang.ClassNotFoundExc...” : Bugs : eclipse package : Ubuntu
When meet java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
cd $HOME/Downloads
wget http://archive.ubuntu.com/ubuntu/pool/universe/e/eclipse/libequinox-osgi-java_3.8.1-8_all.deb
dpkg -x ./libequinox-osgi-java_3.8.1-8_all.deb /
apt install --reinstall libequinox-osgi-java
#option 3
select Java version
update-alternatives --config java
update-alternatives --config javac
update-alternatives --config javadoc
java -version
javac -version
javadoc -J-version
#my blogger: http://fatalfeel.blogspot.com/
by Jesse Stone
Cool! Thanks for sharing!
