Can’t download cuDNN because the survey doesn’t load
When I go to the Nvidia website to download cuDNN, the download button takes me to this survey link:
https://developer.nvidia.com/cudnn-download-survey
But a survey never loads, and as a result, I cannot download cuDNN.
I need the newest version for Windows 64bit.
https://developer.nvidia.com/compute/machine-learning/cudnn/secure/8.0.5/11.1_20201106/cudnn-11.1-windows-x64-v8.0.5.39.zip
I’m tempted to quote Linus Torvalds here, but just say: “NVIDIA, … remove this survey, and just let the developers (who already jumped through the hoop of registering on your site) download the ZIP right away”.
(Is the given link the latest version, or is there some update for cuDNN on CUDA 11.2 ?)
Can you pls try downloading now.
Looks like there was some technical glitch which is resolved now.
Thank you for your patience.
This problem still exists. I can’t download the file, the server shuts the connection before reaching 10%.
i can’t download cuDNN? any help is appreciated
Hi @macavile_96,
We are experiencing an outage at the moment, and are actively working to resolve the issue. Unfortunately we don’t have an ETA for when this will be fixed. I will post here when we are up and running
Thanks for your patience,
Tom K
thanks Tom for prompt response!
You can most likely download your needed version ( as long as you dont need the latest one ) from the archived anaconda versions. You will need 7zip to unzip the files. But, it should work. Thats how I got it to work with tensowflow 2.8 with CUDA 11.2 and Cudnn 8.1
https://anaconda.org/anaconda/cudnn/files
https://anaconda.org/conda-forge/cudnn/files
you would have to unzip it twice. But it should have all the required files.
